19410060301
19410060301
    HARTING(浩亭)
19410060301 数据手册
Han®-Eco Description of the Han®-Eco series Han®-Eco – a new hoods and housings series made of thermoplastic material. Han®-Eco is the ideal solution for applications that do not require the full range of product features offered by the Han® B series of hoods and housings, and users want to take advantage of the weight and cost advantages. Like the Han® B standard series, the Han®-Eco series is available in the following sizes: 6 B, 10 B, 16 B and 24 B. Depending on size, versions of the hoods with straight or angled cable exit as well as housings, bulkhead mounting, can be supplied. The cable exits are available with metric threading, a cable gland is implemented. For hoods/housing sizes 6 B and 10 B size of the cable gland is M 32, for 16 B and 24 B the size of cable gland is M 40. Han®-Eco hoods and housings are made of high-performance plastic that is highly resistant to environmental stress and – in combination with the design - provides very good mechanical stability. When the connector is closed and locked, it provides IP 65 protection as defined in DIN EN 60 529. The material also meets demanding flammability requirements of UL 94 Class V 0. Fast, simple assembly is another outstanding product feature. Click-andmate design totally eliminates the need for tools during assembly of the Han®-Eco hoods and housings. The Han®-Eco hoods and housings are compatible with the full range of modules from the Han-Modular® series. One extra module fits into the Han®-Eco hoods and housings compared to the equivalent product in the Han® B Standard series. This special feature applies to all four sizes. A optional PE contact module with screw terminal has been developed specifically for the Han®-Eco hoods and housings to hold the protective ground conductor. Advantages: ❑ weight reduction combined with mechanical strength ❑ fast assembly process without tools ❑ complete range of modules from Han-Modular® series usable Assembly details 29 Han®-Eco Hoods/Housings Features • New hoods/housings series made of thermoplastic material with excellent mechanical properties and high resistance against environmental influence • Weight and cost optimised • Quick assembly without screws and tools („click and mate“) • Capable for applications according protection class II • Available in sizes 6 B, 10 B, 16 B and 24 B • integrated cable glands • Complete range of modules of series Han-Modular® is usable • One extra module fits into the Han®-Eco hoods/ housings compared to equivalent size of Han® B series • Optional PE contact module for hold the protective ground conductor • Same panel cut out as Han® B housings, bulkhead mounting • Not mating compatible with series Han® B 30 Technical characteristics Specifications Hoods/Housings Material Locking element Hoods/Housings sealing Limiting temperatures Degree of protection acc. to DIN EN 60 529 for coupled connector Flammability acc. to UL 94   DIN EN 61 984 Polyamide, fibre-glass reinforced PA NBR -40 °C ... +125 °C IP 65 V0 Han®-Eco Hoods/Housings Size 6 B Plastic hoods for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Hoods side entry 19 41 106 0522 M32 19 41 106 0422 M32 Hoods top entry Plastic housings for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Housings, bulkhead mounting 19 41 006 0301 PE contact modules Identification Part number Drawing Dimensions in mm Han®-Eco PE contact module with screw terminal wire gauge 1.5 mm² ... 16 mm² male module 19 41 001 2600 female module 19 41 001 2700 31 Han®-Eco Hoods/Housings Size 10 B Plastic hoods for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Hoods side entry 19 41 110 0522 M32 19 41 110 0422 M32 Hoods top entry Plastic housings for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Housings, bulkhead mounting 19 41 010 0301 PE contact modules Identification Part number Han®-Eco PE contact module with screw terminal wire gauge 1.5 mm² ... 16 mm² 32 male module 19 41 001 2600 female module 19 41 001 2700 Drawing Dimensions in mm Han®-Eco Hoods/Housings Size 16 B Plastic hoods for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Hoods side entry 19 41 116 0523 M40 19 41 116 0423 M40 Hoods top entry Plastic housings for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Housings, bulkhead mounting 19 41 016 0301 PE contact modules Identification Part number Drawing Dimensions in mm Han®-Eco PE contact module with screw terminal wire gauge 1.5 mm² ... 16 mm² male module 19 41 001 2600 female module 19 41 001 2700 33 Han®-Eco Hoods/Housings Size 24 B Plastic hoods for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Hoods side entry 19 41 124 0523 M40 19 41 124 0423 M40 Hoods top entry Plastic housings for industrial applications / 2 lever locking system Identification Part number Cable entry Drawing Dimensions in mm Housings, bulkhead mounting 19 41 024 0301 PE contact modules Identification Part number Han®-Eco PE contact module with screw terminal wire gauge 1.5 mm² ... 16 mm² 34 male module 19 41 001 2600 female module 19 41 001 2700 Drawing Dimensions in mm Han®-Eco Accessories Identification Part number Drawing Dimensions in mm Han®-Eco Reduction sealing insert size of cable gland: M32 19 41 000 5132 size of cable gland: M40 19 41 000 5142 35
19410060301 价格&库存
很抱歉,暂时无法提供与“19410060301”相匹配的价格&库存,您可以联系我们找货
    • 1+93.24550
    库存:56
    19410060301
      • 1+70.98840
      • 200+28.32840
      • 500+27.37800
      • 1000+26.91360
      • 1+142.635981+18.48834
