2000-409
2000-409
    WAGO(万可电子)
2000-409 数据手册
Printview: Push-in type jumper bar; insulated; 9-way; nominal current 14 A - Item No.: 2000-409 . Push-in type jumper bar; insulated; 9-way; nominal current 14 A Item No.: 2000-409 . Push-in type jumper bar; insulated; 9-way; nominal current 14 A . Marking . Business data Supplier WAGO Item no. 2000-409 GTIN / EAN 4045454721916 Content 1 Order amount 25 Customer item number . Notes Technical data Miscellaneous Color light gray Rated voltage EN (1) [V] 800 [V] Nominal current [A] 14 [A] Nominal current (Ex e II) [A] 12 [A] Fire load [MJ] 0.021 [MJ] Weight [g] 2.627 [g] Width 30.5 mm / 1.201 in Height 19 mm / 0.748 in Length 4.1 mm / 0.161 in WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Push-in type jumper bar; insulated; 9-way; nominal current 14 A - Item No.: 2000-409 Images & drawings . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 2
2000-409 价格&库存
很抱歉,暂时无法提供与“2000-409”相匹配的价格&库存,您可以联系我们找货
