2002-476
2002-476
    WAGO(万可电子)
    Conn Jumper M 6 POS ST Bag
2002-476 数据手册
Data sheet  |  Item number: 2002-476 Staggered jumper; insulated; 6-way; Nominal current 25 A; suitable for 2002 and 2003 Series rail-mounted terminal blocks; light gray www.wago.com/2002-476 Color: Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 400 V Rated impulse voltage (III / 3) 6 kV Rated current 25 A Geometrical Data Width 29.9 mm / 1.177 inch Material Data Color light gray Fire load 0.04 MJ Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.04.2020    Page 1/5 Data sheet  |  Item number: 2002-476 www.wago.com/2002-476 Fire load 0.04 MJ Weight 3  g Commercial data Product Group 22 (TOPJOB S) Packaging type bag Country of origin DE GTIN 4055143692298 Customs Tariff No. 85366990990 Counterpart Downloads Documentation Bid Text 2002-476 Feb 19, 2019 xml 2.7 kB Download Apr 27, 2017 doc 24.6 kB Download Apr 3, 2019 pdf 2.1 MB Download URL Download URL Download X81 - Datei 2002-476 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 2002-476 CAE data WSCAD Universe 2002-476 Installation Notes Jumpered Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.04.2020    Page 2/5 Data sheet  |  Item number: 2002-476 www.wago.com/2002-476 Locate red stripes of the staggered jumpers on the inside. Commoning two potentials in one single jumper slot via extremely slim staggered jumpers. Insert staggered jumper and push down until it hits backstop. Jumpered Locate red stripes of the staggered jumpers on the inside. Insert staggered jumper and push down until it hits backstop. Jumpered Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.04.2020    Page 3/5 Data sheet  |  Item number: 2002-476 www.wago.com/2002-476 Removing a staggered jumper: Insert the operating tool between the staggered jumpers, then lift up the jumper. Jumpered Staggered jumper (seven contacts) Marking a staggered jumper using a felt-tip pen. Individual jumper contacts can be broken off by bending them. The remaining piece of insulation will meet requirements for clearances and creepage distances. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.04.2020    Page 4/5 Data sheet  |  Item number: 2002-476 www.wago.com/2002-476 Staggering jumpers in a single jumper slot. When creating custom staggered jumpers (e. g., for bridging over a terminal block with a different potential), make sure that only one contact lug is in contact with the terminal block. The contact lugs of the customized staggered jumpers contact the terminal blocks via the gaps created in the second jumper. Insert and press the ready-made jumper assembly into the jumper slot until it hits backstop. Product family TOPJOB® S TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 05.04.2020    Page 5/5
2002-476 价格&库存
很抱歉,暂时无法提供与“2002-476”相匹配的价格&库存,您可以联系我们找货
