Data sheet | Item number: 232-262/039-000
THT female header; 0.6 x 1.0 mm solder pin; angled; Locking lever; Pin
spacing 5.08 mm; 2-pole
www.wago.com/232-262/039-000
Color:
L = pole no. x pin spacing
Distance to first solder pin: 2.2 mm
2- to 3-pole female connectors – one latch only
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
For board-to-board and board-to-wire connections
Touch-proof PCB outputs
Easy-to-identify PCB inputs and outputs
With coding fingers
Other variants can be requested via the WAGO sales department or, if necessary, configured at https://configurator.wago.com/: 3.8 mm pin
projection for male headers with straight solder pins,Gold-plated or partially gold-plated contact surfaces,Other pole numbers
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
320 V
Rated impulse voltage (III / 3)
4 kV
Rated voltage (III / 2)
320 V
Rated impulse voltage (III / 2)
4 kV
Rated voltage (II / 2)
630 V
06.12.2018 Page 1/4
630 V
Rated impulse voltage (II / 2)
4 kV
Rated current
12 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
No. of poles
2
Total number of potentials
2
Number of levels
1
Geometrical Data
Pin spacing
5.08 mm (0.2 inch)
Width
25.96 mm / 1.022 inch
Height
16.6 mm / 0.654 inch
Height from the surface
11.6 mm / 0.457 inch
Depth
18.25 mm / 0.719 inch
Solder pin length
5 mm
Solder pin dimensions
0.6 x 1 mm
Drilled hole diameter (tolerance)
1.3(+ 0.1) mm
Plug connection
Contact type (pluggable connector)
Female connector/socket
Connector connection type
for PCBs
Mismating protection
No
Mating direction to the PCB
0 °
Locking of plug-in connection
locking lever
PCB contact
06.12.2018 Page 2/4
PCB contact
PCB contact
THT
Solder pin arrangement
over the entire female connector, in line
Number of solder pins per potential
1
Material Data
Color
orange
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability class per UL94
V0
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.057 MJ
Weight
2.9 g
Environmental Requirements
Limit temperature range
-60 … +85 °C
Commercial data
Country of origin
DE
GTIN
4044918625197
Customs Tariff No.
85366990990
Product Group
3 (Multi Conn. System)
Approvals / Certificates
Ship Approvals
Logo
Approval
Certificate name
ABS
American Bureau of Shipping
14-HG1241537-PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE 000016Z
UL-Approvals
Logo
Approval
Certificate name
UL
UL International Germany GmbH
E45171
06.12.2018 Page 3/4
Compatible products
check
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing
www.wago.com/231-661
Downloads
smartDATA
PCB libraries
TARGET Library for WAGO Pluggable PCB Connectors (Multi-Connection System)
Compatible with TARGET PCB Design Software Version 17.x
DesignSpark Library for WAGO Pluggable PCB Connectors (MULTI CONNECTION
SYSTEM)
1.1.0
Oct 6, 2014
ZIP
7.4 MB
Download
2.1
Oct 6, 2014
ZIP
6.1 MB
Download
ZIP
6.2 MB
Download
URL
Download
Compatible with DesignSpark PCB Version 4.x or higher
EAGLE Library for WAGO Pluggable PCB Connectors (MULTI CONNECTION SYSTEM) 2.1
Nov 17, 2017
Compatible with EAGLE PCB Design Software Version 6.x or higher
CAD data
3D Download 232-262/039-000
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
06.12.2018 Page 4/4
很抱歉,暂时无法提供与“232-262/039-000”相匹配的价格&库存,您可以联系我们找货
