285-195
285-195
    WAGO(万可电子)
    端子块连接器 2 位置 馈通式 灰色 4/0-4 AWG
285-195 数据手册
Data sheet  |  Item number: 285-195 2-conductor through terminal block; 95 mm²; lateral marker slots; only for DIN 35 x 15 rail; POWER CAGE CLAMP; 95,00 mm²; gray www.wago.com/285-195 i Picture differs from the item. Color: Data Electrical data Voltage type 1 AC/DC Voltage type 2 DC Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 1/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Ratings per IEC/EN 60664-1 Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 1000 V Rated surge voltage (III/3) 12 kV Rated current 232 A Rated voltage (III/3) 2 1500 V Rated surge voltage (III/3) 2 12 kV Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology POWER CAGE CLAMP Actuation type Operating tool Connectable conductor materials Copper Solid conductor 25 … 95 mm² / 4 … 4/0 AWG Stranded conductor 25 … 95 mm² / 4 … 4/0 AWG Fine-stranded conductor 25 … 95 mm² / 4 … 4/0 AWG Strip length 35 mm / 1.38 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Wiring type Side-entry wiring Geometrical Data Width 25 mm / 0.984 inch Height from upper-edge of DIN-rail 101 mm / 3.976 inch Depth 107 mm / 4.213 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Side marking Material Data Color gray Insulation material Polyamide 66 (PA66) Fire load 3.564 MJ Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 2/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Fire load 3.564 MJ Weight 264.3 g Commercial data Product Group 1 (Rail Mounted Terminal Blocks) Packaging type BOX Country of origin PL GTIN 4044918452564 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7707 CSA DEKRA Certification B.V. C22.2 No. 158 1151144 KEMA/KEUR DEKRA Certification B.V. EN 60947 71101911 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 20HG1941090PDA BV Bureau Veritas S.A. EN 60947 07436/E0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 3/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 LR Lloyds Register EN 60947 91/20112 (E9) UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 Counterpart Compatible products ferrule Item no.: 216-413 Ferrule; Sleeve for 25 mm² / AWG 4; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-413 Item no.: 216-414 Ferrule; Sleeve for 35 mm² / AWG 2; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-414 Item no.: 216-424 Ferrule; Sleeve for 35 mm² / AWG 2; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-424 Item no.: 216-425 Ferrule; Sleeve for 50 mm² / AWG 1; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-425 Item no.: 216-435 Ferrule; Sleeve for 50 mm² / AWG 1; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-435 Jumper Item no.: 285-495 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/285-495 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 4/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Item no.: 285-495 Jumper; insulated; gray www.wago.com/285-495 Carrier rail Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Protective Warning Marker Item no.: 285-170 Protective warning marker; with high-voltage symbol, black; yellow www.wago.com/285-170 Item no.: 285-175 Protective warning marker; yellow www.wago.com/285-175 Item no.: 249-117 Screwless end stop; 10 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-117 Item no.: 249-197 Screwless end stop; 14 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-197 Item no.: 285-168 Fixing element; for 95 mm² high-current terminal blocks; orange www.wago.com/285-168 assembling Marking accessories Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-005 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-115 /000-005 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 5/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 209-185 Adaptor; gray www.wago.com/209-185 Item no.: 249-105 Group marker carrier; gray www.wago.com/249-105 Item no.: 285-442 Adaptor; gray www.wago.com/285-442 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 6/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 WMB marking card; as card; not stretchable; plain; snap-on type; light green /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012 type; orange Item no.: 793-5501/000-014 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-014 type; brown Item no.: 793-5501/000-017 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-017 type; green Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet potential distribution Item no.: 285-407 Power tap; for 95 mm² high-current tbs; 10,00 mm²; gray www.wago.com/285-407 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 7/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Power tap; for 95 mm² high-current tbs; 10,00 mm²; gray Item no.: 855-951/250-000 Current and voltage tap up to 95 mm²; Primary rated current: 250 A; Secondary rated current: 1 A; Rated power: 0.2 VA; Accuracy class: 0.5; fused www.wago.com/855-951 /250-000 Item no.: 285-172 Allen wrench; with a partially insulated shaft www.wago.com/285-172 Item no.: 285-173 Allen wrench; with a partially insulated shaft; with anti-rotation protection www.wago.com/285-173 tools protection Item no.: 285-169 Finger guard; touchproof cover protects unused conductor entries and jumper slots; for 95 mm² high- www.wago.com/285-169 current tbs; yellow Downloads Documentation Bid Text 285-195 Feb 19, 2019 xml 3.3 kB Download Jan 4, 2018 doc 24.1 kB Download Apr 3, 2019 pdf 2.1 MB Download URL Download EPLAN Data Portal 285-195 URL Download WSCAD Universe 285-195 URL Download ZUKEN Portal 285-195 URL Download GAEB X81 - Datei 285-195 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 285-195 CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 8/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 ZUKEN Portal 285-195 URL Download Installation Notes Installation Snapping a terminal block onto the DIN-rail. Removing a terminal block from the assembly. Conductor termination For the optimal clamping force: Always observe the printed strip length! Conductor termination – step 1 Rotate the T-wrench counter-clockwise to the stop . Next, push in the orange locking tab. The clamp is locked open for hands-free wiring. Bend conductor. Cut conductor to length (conductor end must be straight). Strip conductor. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 9/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Conductor termination – step 2 Conductor termination – step 3 Insert a stripped conductor into the clamping unit until it hits backstop. Hold in this position. A short counter-clockwise rotation releases the locking tab. When unlocked, the Twrench rotates clockwise, securely clamping the conductor. Commoning Commoning with an adjacent jumper: Insert the jumper above the conductor entry hole – prior to conductor termination. The nominal cross-section remains unchanged. Removing jumper via operating tool. Cover Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 10/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Protective warning marker may indicate: Notice: Power is still on even after switching off the main switch! Yellow, detachable finger guards provide touch-proof safety by shielding jumper contact slots and/or unused conductor entries. Voltage tap Reliably and easily tap directly into the power supply. Insert the unwired tap before opening the clamping unit. Safety Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 11/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 Risk of Injury! Do not insert fingers in the conductor entry! Testing Testing via touch-proof 4 mm Ø test plugs (not available from WAGO, but offered by industry suppliers such as, Multi-Contact Deutschland GmbH). Testing Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 12/13 Data sheet  |  Item number: 285-195 www.wago.com/285-195 WMB markers or self-adhesive, printable marking strips can be accommodated on 35, 50 and 95 mm² high-current terminal blocks. Marker carrier for marking strips (2009-110) or 2 x WMB markers for 285‑13x, 285‑15x and 285‑19x terminal blocks Product family POWER CAGE CLAMP Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 15.08.2020    Page 13/13
285-195 价格&库存
很抱歉,暂时无法提供与“285-195”相匹配的价格&库存,您可以联系我们找货
    • 1+295.83629
    库存:288
    285-195
      库存:15
