IPR1-12-D
IPR1-12-D
    SAMTEC(申泰)
    CONN HSG 24POS 2.54MM
IPR1-12-D 数据手册
F-219 SUPPLEMENT IPR1–06–D T1M74-L–01–F MRTD–06–24–L–03.3 (2.54 mm) .100" IPR1, T1M74-L, T1M74-R, MRTD, MRTDT SERIES DISCRETE WIRE COMPONENTS & TOOLING SPECIFICATIONS PINS PER ROW D –02, –03, –04, –05, –06, –08, –10, –12, –15 = Double Row TYPE For complete specifications see www.samtec.com?IPR1, www.samtec.com?T1M74-L or www.samtec.com?T1M74-R RECOGNITIONS IPR1 For complete scope of recognitions see www.samtec.com/quality = Body, Loose TOOLING • Mini Applicator (20-24 AWG): CAT-MC-174-2024-XX-01 • Mini Applicator (26-30 AWG): CAT-MC-174-2630-XX-01 Insulator Material: Nylon 66 Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -40 °C to +105 °C (PVC) ® -55 °C to +125 °C (*Teflon ) Wire: 20 to 30 AWG RoHS Compliant: Yes *DuPont™ Teflon ® is a registered trademark of the E.I. du Pont de Nemours and Company or its affiliates. = Contact, Full Reel (15,300 Parts per Reel) (5.08) .200 (19.33) .761 (1.57) .062 DIA (3.81) .150 (3.17) .125 Insulator Material: Nylon MRTD = Double Row PVC Cable MRTDT = Double Row *Teflon® Cable (20, 24, 28 & 30 AWG only) PINS PER ROW WIRE GAUGE –02, –03, –04, –05, –06, –08, –10, –12, –15 –20 –20C♦ –22 –24 –24C♦ –26 –28 –28C♦ –30 (Standard sizes) 01 (5.08) .200 (7.62) .300 No. of positions x (2.54) .100 + (3.81) .150 RECOGNITIONS (2.54) .100 For complete scope of recognitions see www.samtec.com/quality = 10 µ" (0.25 µm) Gold on contact T1M74-R (9.65) .380 SPECIFICATIONS –L = 20 to 24 AWG (1.91) .075 TYPE = Gold flash on contact –02 = Contact, Loose (17.53) .690 • Extraction Tool: CAT-EX-74-01 For complete specifications see www.samtec.com?MRTD or www.samtec.com?MRTDT (7.62) .300 –F = 26 to 30 AWG T1M74-L (8.38) .330 • Hand Tool: CAT-HT-174-2030-13 Mates with: MMSD(T) –01 –D (Standard sizes) No. of positions x (2.54) .100 + (3.81) .150 FILE NO. E111594 PLATING OPTION WIRE GAUGE TYPE PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact Contact Material: Phosphor Bronze ASSEMBLY LENGTH PINOUT –“XX.X” Leave blank for single ended cable assembly. = Assembly Length in Inches Single ended = (76.2 mm) 03.0" min. Double ended = (84.0 mm) 03.3" min. Note: ♦ C specifies color coded cable. See website for color coding. END 1 –L1 = Plastic Transfer Latch up, straight APPLICATION MRTD (2.54) .100 (2.54) .100 (17.53) .690 (9.14) .360 MMSD FILE NO. E111594 Note: Teflon ® cable is intended for crimp only. Contact Samtec for solderable cable applications. MRTD/MRTDT –L4 = Plastic Transfer Latch down, straight END 2 Note: Acceptable panel thickness of (0.84 mm) .0329" to (2.28 mm) .0897" Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
IPR1-12-D 价格&库存
很抱歉,暂时无法提供与“IPR1-12-D”相匹配的价格&库存,您可以联系我们找货
