SELF MATING
HERMAPHRODITIC STRIP
(2.00 mm) .0787" PITCH • LS2 SERIES
LS2
LS2
Mates:
LS2
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal
Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
3.2 A per pin
(6 adjacent pins powered)
Voltage Rating:
475 VAC mated with LS2
Operating Temp Range:
-55 °C to +125 °C
1
NO. PINS
PER ROW
05, 10, 15,
20, 25, 30
LEAD
STYLE
–01
=Throughhole
–02
= Surface
Mount
PLATING
OPTION
–F
D
TAIL
OPTION
–01 only
= Gold flash
on contact,
Matte Tin on tail
–RA1
= Right-angle
(Shroud Down)
–L
–RA2
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Right-angle
(Shroud Up)
OPTION
–K
= (6.30 mm)
.248" DIA
Polyimide
Film Pick &
Place Pad
(–02 only)
–TR
= Tape &
Reel
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact
Samtec for
quantity
breaks)
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
No. of positions x
(2.00) .0787 + (1.57) .062
(5.27)
.208
APPLICATION
Through-Hole
(-01)
=(9.65 mm)
.380"
(6.35)
.250 (8.38)
.330
Surface Mount
(-02)
=(13.71 mm)
.540"
(6.83)
.269
STYLE —02
No. of positions x
—RA1
(5.27)
.208
—RA2
ALSO AVAILABLE
MOQ Required
(6.35)
.250
Alignment pin
Other platings
Other stack heights
STYLE —01
—RA1
—RA2
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
samtec.com?LS2
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“LS2-120-02-S-D”相匹配的价格&库存,您可以联系我们找货
