F-224 SUPPLEMENT
MIT–019–01–F–D
MIT–038–01–F–D
MIT–057–01–L–D
MIT SERIES
(0.635 mm) .025"
MIXED TECHNOLOGY HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?MIT
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
275 VAC
Max Cycles:
100
RoHS Compliant:
Yes
Board Mates:
MIS
Standoffs:
SO
Integral metal plane
for power or ground
76 signal lines
per linear inch
Choice of
mated heights
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (019-057)
Board Stacking:
For applications requiring more
than two connectors per board
contact ipg@samtec.com
Polarized
MIT
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
—019,
—038, —057
(38 total positions per bank)
FILE NO. E111594
ALSO AVAILABLE
LEAD
STYLE
POSITIONS
PER ROW
Specify
LEAD
STYLE
FROM
chart
PLATING
OPTION
–F
= Gold Flash on Signal Pins and
Ground Plane, Matte Tin on tails
–L
• 11 mm, 16 mm, 18.75 mm
and 22 mm stack height
• 30 µ" (0.76 µm) Gold
• Differential Pair and
“Partitionable” (combine
differential & single-ended
banks in same connector)
available.
• 76, 95, 114 and 133
positions per row
MATED HEIGHT*
–01
MIT LEAD
STYLE
–01
(5.00)
.197
–02
(8.00)
.315
*Processing conditions will affect
mated height. See SO Series for
board space tolerances.
PACKAGING
–K
Leave blank for
tray packaging
= (7.00 mm)
.275" DIA
Polyimide film
Pick &
Place Pad
–TR
=Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
–C*
= Electro-Polished Selective
50 µ" (1.27 µm) min Au over
150 µ" (3.81 µm) Ni on Signal Pins
in contact area, 10 µ" (0.25 µm) min
Au over 50 µ" (1.27 µm) Ni on
Ground Plane in contact area,
Matte Tin over 50 µ" (1.27 µm) min
Ni on all solder tails
*Note:
–C Plating passes 10 year
MFG testing
(No. of Positions/19) x (12.70) .500 + (11.43) .450
(12.70) .500
02
(5.97)
.235
(7.11)
.280
(0.635) .025
(0.20) .008
01
LEAD
STYLE
(7.11)
.280
(1.40)
.055
A
(0.58) .023 x (0.38) .015
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
OPTION
= 10 µ" (0.25 µm) Gold on
Signal Pins and Ground Plane,
Matte Tin on tails
(MOQ Required)
MIS
LEAD
STYLE
D
(0.38)
.015
–01
–02
A
(4.27) .168
(7.26) .286
Note: Rugged through-hole ground plane soldered to board
(requires paste-over-hole, not press-fit) for added retention to PCB.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“MIT-114-03-F-D-K”相匹配的价格&库存,您可以联系我们找货
