858-304
858-304
    WAGO(万可电子)
858-304 数据手册
Printview: Socket with industrial relay; Coil voltage: DC 24 V; 4 changeover contacts - Item No.: 858-304 . Socket with industrial relay; Coil voltage: DC 24 V; 4 changeover contacts Item No.: 858-304 . Socket with industrial relay; Coil voltage: DC 24 V; 4 changeover contacts . Marking . Business data Supplier WAGO Item no. 858-304 GTIN / EAN 4045454902902 Content 1 Order amount 1 Customer item number . Notes Short description:WAGO DIN-rail mount 858 Series relay sockets are designed for conventional industrial relays with standard pin spacing. The sockets accommodate 33.5 to 35.5mm high relays equipped with 2 or 4 changeovers. All socket contacts have two Push-in CAGE CLAMP® termination points for either 2 x 0.34mm² to 1.5mm² or 1 x 2.5mm² cross-section. Push-in CAGE CLAMP® COMPACT allows direct insertion of solid conductors and ferruled conductors from 20 AWG/0.5mm² and larger. Speedy Socket Service: rapidly replace relays without removing conductors. Technical data Miscellaneous Conformity marking CE Pollution degree (1) 2 Rated voltage EN (1) [V] 250 [V] Rated surge voltage (1) [kV] 2.5 [kV] Pull-in time (typ.) [ms] 25 [ms] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Socket with industrial relay; Coil voltage: DC 24 V; 4 changeover contacts - Item No.: 858-304 Technical data Mechanical life 20 x 106 switching operations Drop-out time (typ.) [ms] 25 [ms] Nominal input current IN 36.9 mA Operating power 0.9 W Input voltage range VN -20 % ... +10 % Max. switching voltage 250 VAC Max. switching power (resistive) 1250 VA AC, DC see load limit curve Recommended minimum load 12 V AC/DC / 100 mA Bounce time (typ) [ms] 4 [ms] Dielectric strength, contact-coil (AC, 1 min) [kVrms
858-304 价格&库存
很抱歉,暂时无法提供与“858-304”相匹配的价格&库存,您可以联系我们找货
    • 1+253.96225
    库存:66
    858-304
    • 1+308.745481+40.01930
    • 10+274.9510910+35.63890
    • 25+262.5446225+34.03078
    • 50+253.5263250+32.86184
    • 100+244.81204100+31.73230
    • 250+233.74216250+30.29744
    库存:234
    858-304
