Emboss Tape
XH CONNECTOR
Radial Tape
2.5mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
1
• Current rating: 3A AC, DC (AWG #22)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,000 V AC/minute
• Applicable wire: AWG #30 to #22
• Applicable PC board thickness: 1.6 mm
5
JS
T
The XH connector was developed based
on the high reliability and versatility of our
NH series connectors. The connector is very
small with a mounting height of 9.8mm.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
• Original folded beam contact
• Box-shaped shrouded header
• Header with a boss
• Interchangeability
• Conforming to the HA terminal
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
2 J50014297
〈Through-hole type (viewed from soldening side)〉
Top entry type
5.75
2.5
±0.05
Side entry type
2.5 ±0.05
(2.5min)
(2.5min)
14.3
6.1
(9.2 min)
2 circuits:φ1 ±0.05
3 circuits or more:φ0.9 +0.1
(3.4min)
9.8
11.5
φ0.9 +0.1
Top entry type with a boss
2.5 ±0.05
5.75
1.6±0.05
9.8
4.35
±0.05
2 ±0.05
3.4 min
2.5 min
φ1.7 +0.1
φ1.1+0.2
±0.05
2 circuits:φ1
+0.1
3 circuits or more:φ0.9 0
+0.1
φ0.9 0
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions
should be larger. The dimensions above should serve as a guideline. Contact JST for details.
11
〈SMT type (viewed from component side)〉
Side entry type
End face of wafer on the mating side
2.3
2. The dimensions above should serve as a guideline. Contact JST for details.
1
1.8
3.9
0.2
6.5
1.3
2.5
XH CONNECTOR
Contact
●Shape A
1.95
1.6
1.8
Model No.
Shape
SXH-001T-P0.6N
SXH-001T-P0.6
SXH-002T-P0.6
A
●Shape B
2
B
Applicable Wire
AWG#
mm2
Insulation O.D
(mm)
Q'ty /
reel
5,000
0.13∼0.33
26∼22
1.3∼1.9
0.08∼0.33
28∼22
0.9∼1.9
0.05∼0.13
30∼26
0.9∼1.3
8,000
2.4
2.35
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
6.5
6.5
Contact
Applicator
Dies
Crimping
machine Crimp applicator
SXH-001T-P0.6N
AP-K2N
SXH-001T-P0.6
RoHS compliance
Note:
1. Contact JST if you require gold-plated contacts or contacts made of brass.
2. Contact JST also if you require shielded wires, thin wires or other
special wires.
3. SXH-001T-P0.6N is low-insertion force type contact, for easier insertion/
withdrawal, which would be less resistant to the vibration.
Crimp applicator with dies
MKS-L
MK/SXH-001-06N APLMK SXH001-06N
*MKS-SC
SC/SXH-001-06N APLSC SXH001-06N
MKS-L
MK/SXH-001-06
APLMK SXH001-06
*MKS-SC
SC/SXH-001-06
APLSC SXH001-06
Applicator
Dies
MKS-L
MK/SXH-002-06
APLMK SXH002-06
*MKS-SC
SC/SXH-002-06
APLSC SXH002-06
Crimping
Contact
SXH-002T-P0.6
AP-K2N
Note: *Strip-crimp applicator
Housing
Circuits
7.75
1
2
2
4.1
3
5.7
4
5
6
Circuit No.1 mark
6
2.5
A
7
B
C
8
9
10
●Plugged up
11
12
13
7.75
14
15
16
Model No.
XHP-1
XHP-2
XHP-2(10.0)-U
XHP-3
XHP-4
XHP-5
XHP-6
XHP-6(5.0)-U
XHP-7
XHP-8
XHP-9
XHP-10
XHP-11
XHP-12
XHP-13
XHP-14
XHP-15
XHP-16
XHP-20
5.7
A
Dimensions (mm)
B
C
3.2
4.8
1,000
2.5
5.7
7.3
1,000
10.0
13.2
14.8
1,000
5.0
8.2
9.8
1,000
7.5
10.7
12.3
1,000
10.0
13.2
14.8
1,000
12.5
15.7
17.3
1,000
25.0
28.2
29.8
1,000
15.0
18.2
19.8
1,000
17.5
20.7
22.3
1,000
20.0
23.2
24.8
1,000
22.5
25.7
27.3
1,000
25.0
28.2
29.8
1,000
27.5
30.7
32.3
1,000
30.0
33.2
34.8
1,000
32.5
35.7
37.3
1,000
35.0
38.2
39.8
1,000
37.5
40.7
42.3
1,000
47.5
50.7
52.3
500
Q'ty / bag
Material
PA 6, UL94V-0, natural (white)
Circuit No.1 mark
RoHS compliance
Note:
1. XHP-2(10.0)-U is 2 circuits 10.0mm pitch plugged up.
¨ V approved.
Not UL/CSA/TU
2. XHP-6(5.0)-U is 6 circuits 5.0mm pitch plugged up.
¨ V approved.
Not UL/CSA/TU
A
B
C
7.75
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
4.1
5.7
Circuit No.1 mark
XHP-1-oo(blank)…natural (white)
BK…black R…red E…blue Y…yellow L…lemon yellow
M…green D…orange N…brown FY…vivid yellow
ex.
A
B
XHP-2(10.0)-U-oo(blank)…natural (white)
R…red E…blue
C
2
XH CONNECTOR
Through-hole type shrouded header
The shrouded headers are interchangeable with those of the NR and NRD insulation displacement connectors, and JQ board-to-board connectors.
Top entry type
Circuits
□0.64
2
●plugged up
7
2
3
4
3.4
5
6
2.45
A
7
(2.35)
B
8
5.75
9
Top entry type
10
11
0.64
12
0.64
13
14
7
7
15
16
3.4
3.4
B
(2.35)
A
2.45
Side entry type
RoHS compliance This product displays (LF)(SN) on a label.
Note: B2(10.0)B-XH-A-U is 2 circuits 10.0mm pitch plugged up.
¨ V approved.
Not UL/CSA/TU
0.64
11.5
7
2.5
2.45
Post: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL94V-0, natural (white)
5.75
B
5.75
S( )B-XH-A-1: 7.6
S( )B-XH-A: 9.2
A
Dimensions (mm)
Model No.
Q'ty / box
A
B
Side entry type
Top entry type Side entry type
7.4
2.5
1,000
1,000
S2B-XH-A-1 S2B-XH-A
14.9
10.0
1,000
1,000
9.9
5.0
1,000
S3B-XH-A-1 S3B-XH-A
500
12.4
7.5
500
S4B-XH-A-1 S4B-XH-A
500
14.9
10.0
500
S5B-XH-A-1 S5B-XH-A
500
17.4
12.5
500
S6B-XH-A-1 S6B-XH-A
250
19.9
15.0
500
S7B-XH-A-1 S7B-XH-A
250
22.4
17.5
250
S8B-XH-A-1 S8B-XH-A
250
24.9
20.0
250
S9B-XH-A-1 S9B-XH-A
250
27.4
22.5
250
S10B-XH-A-1 S10B-XH-A
250
29.9
25.0
250
S11B-XH-A-1 S11B-XH-A
200
32.4
27.5
250
S12B-XH-A-1 S12B-XH-A
200
34.9
30.0
250
S13B-XH-A-1 S13B-XH-A
200
37.4
32.5
250
S14B-XH-A-1 S14B-XH-A
100
39.9
35.0
250
S15B-XH-A-1 S15B-XH-A
100
42.4
37.5
200
S16B-XH-A
52.4
47.5
100
Material and Finish
2.5
2.45
Top entry type
B2B-XH-A
B2(10.0)B-XH-A-U
B3B-XH-A
B4B-XH-A
B5B-XH-A
B6B-XH-A
B7B-XH-A
B8B-XH-A
B9B-XH-A
B10B-XH-A
B11B-XH-A
B12B-XH-A
B13B-XH-A
B14B-XH-A
B15B-XH-A
B16B-XH-A
B20B-XH-A
(6.1)
A
ex.
3.4
B
S3B-XH-A(-1)-oo(blank)…natural (white)
Top entry type of glass-filled nylon
0.64
Circuits
Model No.
2
B2B-XH-2
B3B-XH-2
B4B-XH-2
B5B-XH-2
B6B-XH-2
B7B-XH-2
B8B-XH-2
B9B-XH-2
B10B-XH-2
B11B-XH-2
B12B-XH-2
B13B-XH-2
B14B-XH-2
B15B-XH-2
3
7
4
5
3.4
6
2.45
7
8
5.75
A
B
9
6.75
10
11
12
7
13
14
3.4
15
2.5
6.75
B
7.4
1,000
5.0
9.9
1,000
7.5
12.4
500
10.0
14.9
500
12.5
17.4
500
15.0
19.9
500
17.5
22.4
250
20.0
24.9
250
22.5
27.4
250
25.0
29.9
250
27.5
32.4
250
30.0
34.9
250
32.5
37.4
250
35.0
39.9
250
7
3.4
ex.
2.5
.45
0.64
A
B
3
5.75
Q'ty / bag
2.5
Wafer: Glass-filled PA 66, UL94V-0, natural (ivory)
5.75
A
Dimensions (mm)
B
Material and Finish
0.64
2.45
A
B2B-XH-2-oo(blank)…natural (ivory)
C…black R…red E…blue Y…yellow M…green
XH CONNECTOR
0.64
Circuits
Model No.
1
*B1B-XH-AM
B2B-XH-AM
B3B-XH-AM
B4B-XH-AM
B5B-XH-AM
B6B-XH-AM
B7B-XH-AM
B8B-XH-AM
B9B-XH-AM
B10B-XH-AM
B12B-XH-AM
2
7
3
4
6
3.4
2.7
5
(2.35)
4.9
1.5
7
4.35
8
9
5.75
10
12
0.64
A
Dimensions (mm)
B
Q'ty /
box
1,000
2.5
7.4
1,000
5.0
9.9
1,000
7.5
12.4
500
10.0
14.9
500
12.5
17.4
500
15.0
19.9
500
17.5
22.4
250
20.0
24.9
250
22.5
27.4
250
27.5
32.4
250
Material and Finish
1.5
7
3.4
¨ V approved.
Note: *Marked product is not UL/CSA/TU
φ1
2.45
(2.35)
1.6
A
B
2
5.75
ex.
B1B-XH-AM-oo(blank)…natural (white)
M…green
3.4
1.5
7
0.64
2.5
φ1
1.6
A
2.45
(2.35)
2
5.75
B
SMT type shrouded header
0.64
Dimensions (mm)
A
B
Q'ty /
reel
S3B-XH-SM4-TB
5.0
12.5
500
S4B-XH-SM4-TB
7.5
15.0
500
S6B-XH-SM4-TB
12.5
20.0
500
Circuits
Model No.
3
4
6
5.5
Material and Finish
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 6T, UL94V-0, natural (ivory)
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
2.5
Note: The products listed above are supplied on embossed-tape.
A
B
7
(3)
ex.
6
3.75
S3B-XH-SM4-oo-TB(blank)…natural (ivory)
M…green R…red E…blue L…lemon yellow
4
XH CONNECTOR
Through-hole type shrouded header on radial-tape
TV4 type
2-TV4 type
2-TV4 type
B
B
A
6.75
A
2.45
2.5
Circuits
2
3
4
5
6
7
8
2.45
2.5
6.75
Model No.
TV4
2-TV4
B2B-XH-2-TV4
B3B-XH-TV4
B3B-XH-2-TV4
B4B-XH-TV4
B4B-XH-2-TV4
B5B-XH-2-TV4
B6B-XH-2-TV4
B7B-XH-2-TV4
B8B-XH-2-TV4
7
7
φ0.7)
2.8
0.64
6.75
φ0.7)
0.64
Dimensions (mm)
A
B
Q'ty / box
1,000
5.0
9.9
1,000
7.5
12.4
500
10.0
14.9
500
12.5
17.4
500
15.0
19.9
500
17.5
22.4
500
2.8
2.5
7
2.45
7.4
0.64
φ0.7)
ex.
B2B-XH-2-TV4-oo(blank)…natural (TV4 type/white, 2-TV4 type/ivory)
C…black (glass-filled) BK…black R…red E…blue Y…yellow
M…green
Material and Finish
Wafer: TV4 type/ PA 66, UL94V-0, natural (white)
2-TV4 type/ Glass-filled PA 66, UL94V-0, natural (ivory)
Taping specification
Packaging specifications
D
2 and 3 circuits :12.7
4 to 8 circuits : 25.4
6.75
TERMIN
H
ALS &
CONN
ECTORS
R
W
9
6
Distance between the end of the tape and
the first connector's center line (either end)
Leader tape
18
Tail tape
φ4
2 circuits: 5.1
3 to 8 circuits: 3.85
2 circuits: 2.5
3 to 8 circuits: 5
12.7
Note: Conforms to JIC C 0806 of "Tape packaging of components with
unidirectional leads on continuous tapes".
Package type
Distance between folds
Box size
the first connector’s center line (either end)
2, 3 circuits
Quantity
4∼8 circuits
Flat pack (zigzag folded)
24 indexing holes per fold (304.8mm)
316(W)×45(D)×330(H)mm
19.05mm
1,000 pcs. / box
500 pcs. / box
Note: Products of different packaging specifications are also available.
5
