B5B-PH-SM4-TBT(LF)(SN)
    JST
    SMD,P=2mm
    线对板针座 1x5P 立贴 间距:2mm
B5B-PH-SM4-TBT(LF)(SN) 数据手册
Emboss Tape PH CONNECTOR 2.0mm pitch/Disconnectable Crimp style connectors 6 5 Specifications ––––––––––––––––––– 4 3 2 This is a thin, low-profile 2.0mm pitch connector 8.0mm in height after mounting and 4.5mm in width. It is designed to meet the demand for high-density connection of internal wires to printed circuit boards. It is compact, highly reliable and low in cost. • Reliable contact • Fully shrouded header • Printed circuit board retention mechanism • Surface mount model (SMT) • Current rating: 2A AC, DC (AWG #24) • Voltage rating: 100V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10m Ω max. After environmental testing/ 20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/ minute • Applicable wire: AWG #32 to #24 • Applicable PC board thickness: 0.8 to 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 R75087 〈Through-hole type (viewed from soldering side) 〉 Side entry type Top entry type 4.5 2 ±0.05 2 ±0.05 9.6 +0.1 8 +0.1 φ0.7  0 6 φ0.7  0 4.8 7.6 6.25 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 〈SMT type (viewed from component side) 〉 SM4 type Top entry type 1.6 ±0.1 2 ±0.05 5 1.5 (2) 1.6 1 min 2 ±0.05 5.5 max 3.4 9.6 7.6 1 5.5 6.6 8.6 2 max 7.5 min ±0.1 1 ±0.1 3 Circuit No.1 ±0.1 End face of wafer on the mating side 0.2 End face of wafer on the mating side ±0.1 9 min 1.6 ±0.1 SM4 type Side entry type 1 min Circuit No.1 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 1 PH CONNECTOR Contact Applicable wire Model No. 1.5 5.7 1 2.05 SPH-002T-P0.5S SPH-002T-P0.5L SPH-004T-P0.5S 2.08 2.85 mm2 AWG # Insulation O.D. (mm) 0.05 ∼ 0.22 30∼24 0.9∼1.5 0.08 ∼ 0.22 28∼24 0.8∼1.5 0.032∼0.08 32∼28 0.5∼0.9 Q'ty / reel 8,000 10,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) Crimping machine Contact Applicator Dies Crimp applicator MKS-L SPH-002T-P0.5S SPH-002T-P0.5L AP-K2N SPH-004T-P0.5S Crimp applicator with dies MK/SPH-002-05S APLMK SPH002-05S *MKS-SC SC/SPH-002-05S APLSC SPH002-05S MKS-L MK/SPH-002-05L APLMK SPH002-05L *MKS-SC SC/SPH-002-05L APLSC SPH002-05L MKS-L-10 MK/SPH-004-05S APLMK SPH004-05S *MKS-SC-10 SC/SPH-004-05S RoHS compliance Note: 1. Contact JST for gold-plated products. 2. SPH-002T-P0.5L is low-insertion force type contact, for easier insertion/ withdrawal, which would be less resistant to the vibration. The crimp height is different from the standard. 3. Contact JST for details. APLSC SPH004-05S Note: *Strip-crimp applicator Housing Circuits B 1.9 A 2 2 4.5 0.5 Circuit No.1 3 4 5 7 6.35 H JST 8 6 8 9 10 11 0.6 12 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 13 14 15 16 PHR-2-oo(blank)…natural (white) BK…black R…red TR…tomato red BL…blue Y…yellow L…lemon yellow M…green D…orange N…brown P…purple PK…pink H…gray LE…light blue FY…vivid yellow DPK...dark pink Model No. PHR-2 PHR-3 PHR-4 PHR-5 PHR-6 PHR-7 PHR-8 PHR-9 PHR-10 PHR-11 PHR-12 PHR-13 PHR-14 PHR-15 PHR-16 A Dimensions (mm) B Q'ty / box 2.0 5.8 1,000 4.0 7.8 1,000 6.0 9.8 1,000 8.0 11.8 1,000 10.0 13.8 1,000 12.0 15.8 1,000 14.0 17.8 1,000 16.0 19.8 1,000 18.0 21.8 1,000 20.0 23.8 1,000 22.0 25.8 1,000 24.0 27.8 1,000 26.0 29.8 1,000 28.0 31.8 1,000 30.0 33.8 1,000 Material PA 66, UL94V-0, natural (white) RoHS compliance Through-hole type shrouded header Top entry type Circuits 2 3 (2 circuits) (3 circuits or more) 4 4.5 4.5 1.7 B 5 1.7 B 6 7 8 6 6 9 10 1.95 A Circuit No.1 3.4 3.4 11 12 13 14 0.5 2 1.95 0.5 15 A Circuit No.1 16 Model No. Top entry type Side entry type B2B-PH-K-S S2B-PH-K-S B3B-PH-K-S S3B-PH-K-S B4B-PH-K-S S4B-PH-K-S B5B-PH-K-S S5B-PH-K-S B6B-PH-K-S S6B-PH-K-S B7B-PH-K-S S7B-PH-K-S B8B-PH-K-S S8B-PH-K-S B9B-PH-K-S S9B-PH-K-S B10B-PH-K-S S10B-PH-K-S B11B-PH-K-S S11B-PH-K-S B12B-PH-K-S S12B-PH-K-S B13B-PH-K-S S13B-PH-K-S B14B-PH-K-S S14B-PH-K-S B15B-PH-K-S S15B-PH-K-S B16B-PH-K-S S16B-PH-K-S Dimensions (mm) Q'ty / box A B Top entry type Side entry type 2.0 5.9 1,000 1,000 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 400 250 24.0 27.9 250 250 26.0 29.9 250 250 28.0 31.9 250 200 30.0 33.9 250 200 Material and Finish Side entry type Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) 4.8 6 6.25 1.7 B RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 2 1.95 2 0.5 A Circuit No.1 1.6 ex. 3.4 B2B-PH-K-ooS…natural (white) K…black R…red TR…tomato red E…blue Y…yellow L…lemon yellow M…green O…orange N…brown P…purple PK…pink H…gray LE…light blue FY…vivid yellow (blank)…ivory PH CONNECTOR Through-hole type shrouded header〈Low insertion force type〉 Top entry type Circuits (2 circuits) 2 (3 circuits or more) 3 4.5 B 4 4.5 1.7 B 5 1.7 6 6 6 7 8 9 1.95 A Circuit No.1 3.4 3.4 10 11 12 0.5 2 0.5 1.95 13 Circuit No.1 A 14 15 Side entry type 16 Model No. Top entry type Side entry type B2B-PH-KL S2B-PH-KL B3B-PH-KL S3B-PH-KL B4B-PH-KL S4B-PH-KL B5B-PH-KL S5B-PH-KL B6B-PH-KL S6B-PH-KL B7B-PH-KL S7B-PH-KL B8B-PH-KL S8B-PH-KL B9B-PH-KL S9B-PH-KL B10B-PH-KL S10B-PH-KL B11B-PH-KL S11B-PH-KL B12B-PH-KL S12B-PH-KL B13B-PH-KL S13B-PH-KL B14B-PH-KL S14B-PH-KL B15B-PH-KL S15B-PH-KL B16B-PH-KL S16B-PH-KL Q'ty / box Top entry type Side entry type 2.0 5.9 1,000 1,000 4.0 7.9 1,000 1,000 6.0 9.9 1,000 500 8.0 11.9 1,000 500 10.0 13.9 1,000 500 12.0 15.9 500 500 14.0 17.9 500 250 16.0 19.9 500 250 18.0 21.9 500 250 20.0 23.9 500 250 22.0 25.9 400 250 24.0 27.9 250 250 26.0 29.9 250 200 28.0 31.9 250 200 30.0 33.9 250 200 Material and Finish 4.8 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, gray 1.7 B Dimensions (mm) A B 6 6.25 RoHS compliance This product displays (LF)(SN) on a label. 0.5 A Circuit No.1 ex. 3.4 1.6 2 1.95 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. B2B-PH-KL-oo(blank)…gray R…red E…blue S…natural (white) SMT type shrouded header Model No. Top entry type Circuits Top entry type Side entry type B2B-PH-SM4-TB B3B-PH-SM4-TB B4B-PH-SM4-TB B5B-PH-SM4-TB B6B-PH-SM4-TB B7B-PH-SM4-TB B8B-PH-SM4-TB B9B-PH-SM4-TB B10B-PH-SM4-TB B11B-PH-SM4-TB B12B-PH-SM4-TB B13B-PH-SM4-TB B14B-PH-SM4-TB B15B-PH-SM4-TB B16B-PH-SM4-TB S2B-PH-SM4-TB S3B-PH-SM4-TB S4B-PH-SM4-TB S5B-PH-SM4-TB S6B-PH-SM4-TB S7B-PH-SM4-TB S8B-PH-SM4-TB S9B-PH-SM4-TB S10B-PH-SM4-TB S11B-PH-SM4-TB S12B-PH-SM4-TB S13B-PH-SM4-TB S14B-PH-SM4-TB S15B-PH-SM4-TB ― B 2.975 2 (2) 5 A 3 1.9 2 4 6.6 5 6 7 8 Circuit No.1 1.4 2.2 9 10 11 Side entry type 12 13 2.4 14 5.5 15 16 Dimensions (mm) B A Top entry type Side entry type Q'ty / reel 2.0 7.95 7.9 1,000 4.0 9.95 9.9 1,000 6.0 11.95 11.9 1,000 8.0 13.95 13.9 1,000 10.0 15.95 15.9 1,000 12.0 17.95 17.9 1,000 14.0 19.95 19.9 1,000 16.0 21.95 21.9 1,000 18.0 23.95 23.9 1,000 20.0 25.95 25.9 1,000 22.0 27.95 27.9 1,000 24.0 29.95 29.9 1,000 26.0 31.95 31.9 1,000 28.0 33.95 33.9 1,000 30.0 35.95 – 1,000 Material and Finish Circuit No.1 2.95 1.6 2 A 6 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) (2.6) B RoHS compliance This product displays (LF)(SN) on a label. Note: Contact JST for the top entry type headers with suction cap. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-PH-SM4-oo-TB (blank)…natural (ivory) R…red E…blue M…green L…lemon yellow K…black DPK...dark pink 3
B5B-PH-SM4-TBT(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“B5B-PH-SM4-TBT(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 1+5.490951+0.71173
    • 50+4.5882150+0.59472
    • 100+4.04160100+0.52387
    • 300+3.66891300+0.47556
    • 500+3.60266500+0.46698
    • 1000+3.544681000+0.45946
    • 4000+3.503274000+0.45409
    库存:1
      • 100+2.11456
      库存:6110
