QFS-078-04.25-L-D-PC4 . 数据手册
F-215
QFS–026–04.25–L–D–A
TM
QFS–032–04.25–L–D–DP–A
QFS–026–04.25–L–D–A–GP
(0,635 mm) .025"
QFS SERIES
RUGGED GROUND PLANE SOCKET
Increased insertion
depth for rugged applications
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QFS
Insulator Material:
Liquid Crystal Polymer
Contact & Ground
Plane Material:
Phosphor Bronze
Plating:
Au over 50µ" (1,27 µm) Ni
(Tin on Ground Plane Tail)
Current Rating:
Contact:
2.6 A per pin
(1 pin powered per row)
Ground Plane:
15.7 A per ground plane
(1 ground plane powered)
Voltage Rating:
300 VAC mated with QMS
Operating Temp:
-55°C to +125°C
RoHS Compliant: Yes
Processing:
Lead–Free Solderable: Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (026-078)
Board Stacking:
For applications requiring more
than two connectors per board
contact ipg@samtec.com
Board Mates:
QMS
Cable Mates:
6QCD
ALSO
AVAILABLE
(1,60 mm)
.063"
NOMINAL
WIPE
(MOQ Required)
Type
PINS PER ROW
NO. OF PAIRS
QFS
For complete scope of
recognitions see
www.samtec.com/quality
–026, –052, –078
(52 total pins per bank = –D)
–016, –032, –048
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
–L
(16 pairs per bank = –D–DP)
stry
Indu ards
d
Stan
TM
s
ocol
Prot orted
Supp
QMS LEAD STYLE
LEAD
STYLE
A
–04.25
(7,44) .293
10 mm
11 mm
14 mm
–06.25
(9,42) .371
12 mm
13 mm
16 mm
–05.75 –06.75 –09.75
= Guide
Holes
( –04.25
lead style
only)
= Single-Ended
–D–DP
= Differential Pair
(–04.25 lead style only)
(–06.25 lead style only)
= 10µ" (0,25 µm) Gold on Signal
Pins and Ground Plane
(Tin on Signal Pin tails, and
Ground Plane tails)
STACK
HEIGHT
A
No. of Banks x (21,34) .840 + (1,02) .040
(0,635)
(21,34) .840
.025
02
(8,13)
.320
01
(0,89)
.035
APPLICATION
(0,10)
.004
GP = No. of Banks x (21,34) .840 + (12,45) .490
–D
–GP
–D
Ground Plane tails)
*Processing conditions will affect mated height.
(1,02) .040 DIA
Note: Some lengths,
styles and options are
non-standard, non-returnable.
OTHER
OPTION
A
TYPE
–SL
MATED HEIGHT*
SUMIT
TM
ress
PCI/104-Exp
notes at
Download app ppnote
/a
om
www.samtec.c
mtec.com
sa
G
SI
t
Contac
protocols
on
ns
for questio
• Other platings
• Without PCB
Alignment Pins
• Hot Pluggable
• 4 banks
(104 -SE, 64 -DP)
Contact Samtec.
Rated @ 3dB Insertion Loss
with PCB effects* w/o PCB effects**
Single-Ended Signaling
–D 9 GHz / 18 Gbps 8 GHz / 16 Gbps
Differential Pair Signaling –D 8 GHz / 16 Gbps 8.5 GHz / 17 Gbps
Differential Pair Signaling –DP 7.5 GHz / 15 Gbps 9 GHz / 18 Gbps
*Performance data includes effects of a non-optimized PCB.
**Test board losses de-embedded from performance data.
Performance data for other stack heights and complete test data
available at www.samtec.com?QFS or contact sig@samtec.com
QMS/QFS
10 mm Stack Height
RECOGNITIONS
100 GbE
nel
Fibre Chan
XAUI ®
s
PCI Expres
SATA
Integral metal plane
for power or ground
Requires Standoff
SO-1524-03-01-01-L for 15,24 mm
or SO-2215-02-01-01-L for 22 mm
board spacing. Connectors designed
to not fully seat when mated.
(8,13)
.320
INDUSTRY
STANDARD
(0,44)
.017
INTERCONNECTS
TERMINAL
SOCKET
SUMIT™
ASP-129637-01 ASP-129646-01
PCI/104-Express™ ASP-129637-03 ASP-129646-03
PCI/104-Express™ ASP-142781-02 ASP-129646-02
PCI/104-Express™ ASP-142781-03 ASP-129646-03
–D–DP
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
STACK
BANKS HEIGHT
1
3
2
3
15,24 mm
15,24 mm
22 mm
22 mm
QFS-078-04.25-L-D-PC4 . 价格&库存
很抱歉,暂时无法提供与“QFS-078-04.25-L-D-PC4 .”相匹配的价格&库存,您可以联系我们找货
