QSH-090-01-H-D-EM2
QSH-090-01-H-D-EM2
    SAMTEC(申泰)
    .5MM DOUBLE ROW MI SOCKET ASSEMB
QSH-090-01-H-D-EM2 数据手册
QSH–090–01–F–D–RA–GP F-219 QSH–060–01–L–D–RA ® (0.50 mm) .0197" QSH-RA SERIES QSH–020–01–F–D–DP–RA RIGHT-ANGLE GROUND PLANE SOCKET SPECIFICATIONS Board Mates: QTH For complete specifications and recommended PCB layouts see www.samtec.com?QSH-RA or www.samtec.com?QSH-DP-RA Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Weld Tab: Phosphor Bronze Ground Plane: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 2.2 A per pin (2 pins powered) Ground Plane: 21.8 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 220 VAC RoHS Compliant: Yes Weld Tabs Integral metal plane for power or ground PINS PER ROW NO. OF PAIRS QSH Optional Guide Post option available PLATING OPTION 01 OTHER OPTION RA TYPE PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (020-090) –F = Gold Flash on contact, Matte Tin on tails –030, –060, –090 –D = (60 total pins per bank) –L –020, –040, –060 = 10 µ" (0.25 µm) Gold contact, Matte Tin on tails –D–DP = (20 pairs per bank) –GP –D = Guide Post Holes = SingleEnded –D–DP = Differential Pair –K = (6.50 mm) .256" DIA Polyimide film Pick & Place Pad A (with option -GP) NO. OF PINS PER PAIRS ROW B (without option -GP) –020 (13.59) .535 (7.11) .280 (1.59) .063 DIA –040 –060 –060 –090 01 (8.47) .333 Note: Some lengths, styles and options are non-standard, non-returnable. (0.30) .012 (2.03) .080 (0.15) .006 02 (0.64) .025 SQ –GP OPTION SHOWN Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –030 All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. A B (30.80) 1.213 (50.80) 2.000 (70.80) 2.788 (25.72) 1.013 (45.72) 1.800 (65.72) 2.588
QSH-090-01-H-D-EM2 价格&库存
很抱歉,暂时无法提供与“QSH-090-01-H-D-EM2”相匹配的价格&库存,您可以联系我们找货
