F-215 (Rev 07AUG15)
SIR1–15–L–S–A
SIB–120–02–F–S
(2.54 mm) .100"
SIB, SIR1 SERIES
ONE PIECE INTERFACES
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?SIB
SIB
1
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1.27 µm) Ni
Current Rating:
2.6 A per pin
(1 pin powered per row)
Operating Temp Range:
-55°C to +125°C
RoHS Compliant: Yes
NO. OF
POSITIONS
PLATING
OPTION
02
S
OPTION
–LC
–F
02 thru 30
= Locking
Clip
(Manual
placement
required)
= Gold flash on contact,
Matte Tin on tail
(Per Row)
No. of positions x (2.54) .100
(4.45)
.175
(1.13)
.044
(8.51)
.335
Processing:
Lead-Free Solderable: Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-19)
(0.15 mm) .005" max (20-30)
01
(1.42)
.056
(0.38)
.015
– LC
RECOGNITIONS
(2.54)
.100
For complete scope
of recognitions see
www.samtec.com/quality
Note: The SIB Series
is intended for vertical
mating only.
(5.27)
.207
(3.81)
.150
Note: Some sizes, styles and
options are non-standard,
non-returnable.
SPECIFICATIONS
www.samtec.com?SIR1
SIR1
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1.27 µm) Ni
Current Rating:
2.8 A per pin
Weld Tab:
Phosphor Bronze
RoHS Compliant:
Yes
OPTION
–A
= Alignment Pin
= 10µ" (0.25 µm) Gold on contact,
Matte Tin on tail
(Per Row)
–S
= 30µ" (0.76 µm) Gold on contact,
Matte Tin on tail
+ (2.54) .100
–K
= (4.00 mm) .157"
DIA Polyimide
Film Pick &
Place Pad
–TR
(5.08)
.200
Yes
(0.10 mm) .004" max
For complete scope
of recognitions see
S
–L
–03, –05, –10, –15
Processing:
RECOGNITIONS
PLATING
OPTION
NO. OF
POSITIONS
= Tape & Reel
01
(2.54)
.100
(2.54)
.100
(6.00)
.236
(0.25)
.010
(4.45)
.175
+ (1.016) .040
(0.50)
.020
(1.40)
.055
(2.25)
.089
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
non-returnable.
很抱歉,暂时无法提供与“SIB-103-02-F-S”相匹配的价格&库存,您可以联系我们找货
