MWP CONNECTOR
7.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors
Specifications –––––––––––––––––––
• Current rating: 7A AC, DC max.
• Voltage rating: 300V AC, DC max.
• Temperature range: -40˚C to +105˚C
(including temperature rise in applying electrical current)
• Contact resistance: Initial value/7m Ω max.
After environmental testing/10m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #26 to #18
0.13 to 0.75mm2
Insulation O.D./2.1 to 2.5mm
• Waterproof grade: Grade 4 ingress protection of JIS C 0920(IEC 60529 IPX4)
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Note: The current rating varies depending on the number of circuits and the
wire size used in each connector.
The table below lists the current rating as a function of the number of
circuits and wire size.
Current unit: A
Waterproof wire-to-wire connector for
electric power supply.
• Low insertion force contact
• Housing lance
• Inner-housing lock
• Slider locking mechanism
• Interchangeability
Wire size (AWG)
Circuits
#18
#20
#22
#24
#26
1
7
5
4
3
2
2
7
5
4
3
2
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
Assembly layout
14.2
43.9
1
MWP CONNECTOR
Contact
Applicable wire
Model No.
1.4
Pin contact
mm2
AWG #
Pin contact
Socket contact
SSM-01T-P1.4
SSF-01T-P1.4
0.13∼0.5
26∼20
SSM-21T-P1.4
SSF-21T-P1.4
0.3 ∼0.75
22∼18
Insulation O.D. Q'ty /
reel
(mm)
2.1∼2.5
6,000
Material and Finish
17.6
Phosphor bronze, tin-plated (reflow treatment)
4.3
0.5
RoHS compliance
Note: Contact JST for special products.
Crimping
machine Crimp applicator
Contact
MKS-L
SSM-01T-P1.4
Socket contact
SSF-01T-P1.4
SSM-21T-P1.4
AP-K2N
MKS-L
SSF-21T-P1.4
Applicator
Dies
Crimp applicator with dies
MK/SSF/M-01-14 APLMK SSF/M01-14
MK/SSF/M-21-14 APLMK SSF/M21-14
12.6
4.3
Housing
Material: PBT, UL94V-0, white
Receptacle housing(for socket contact)
02R-MWPV-SSRR
7A
6.0
7.7
300V
11.9
12.85
2
7.0
Q'ty /
box
13.9
252
Q'ty /
box
17.9
01P-MWPV-SSR
11.7
7A
6.0
7.7
300V
11.9
12.85
1
Q'ty /
box
02P-MWPV-SSR
144
228
Q'ty /
box
18.7
11.7
13.9
01R-MWPV-SSRR
Plug housing(for pin contact)
6.0
7.7
Current
rating
6.0
7.7
Circuits
Voltage
rating
144
7.0
RoHS compliance
Note: 1. Model ( )P-MWPV-SSR comes with the wire end seal and slider.
2. Model ( )R-MWPV-SSRR comes with the rubber ring, wire end seal and slider.
2
很抱歉,暂时无法提供与“01R-MWPV-SSRR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.382891+1.07576
- 10+5.0896110+0.65314
- 50+4.5436750+0.58308
- 100+4.17383100+0.53562
- 500+4.10339500+0.52658
- 1000+4.050561000+0.51980
- 2000+4.024142000+0.51641
