04SUR04SUR32W300
04SUR04SUR32W300
    JST
    JST (JAPAN SOLDERLESS TERMINALS) - 04SUR04SUR32W300 - Ribbon Cable, IDC Receptacle to IDC Receptacle...
04SUR04SUR32W300 数据手册
IDC 0.8mm SUR CONNECTOR Emboss Tape Disconnectable Insulation displacement connectors (.031") pitch Features ––––––––––––––––––––––– • 3-point grip construction The 3-point insulation grip feature and the strain relief ensure a firm grip on terminated wires and protection of the insulation displacement connection from possible damage. • Super fine wires are applicable Applicable wire is of AWG #32 with only 0.38mm (.015") O.D. With this super fine wire, routing of wires is easy." • Shrouded header The header is fully shrouded, but remains thin. • Twin U-slot insulation displacement section The insulation displacement section connected to each wire consists of two tin-plated slots (twin U-slots), which ensures reliable connection. The world's first 0.8mm (.031") pitch wireto-board insulation displacement connector. Only 3.9mm (.154") depth and 1.75mm (.069") height after mounting on the PC board. Compared to the conventional 1.0mm (.039") pitch SSR connector, occupation space on the board is reduced by 34%. Specifications ––––––––––––––––––– • Current rating: 0.5A AC, DC (AWG #32) • Voltage rating: 30V DC • Temperature range: -25˚C to +85˚C(including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/40m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 200V AC/minute • Applicable wire: AWG #32 Conductor/7 strands, tin-coated copper alloy Insulation O.D./0.38mm (.015") * Contact JST for details. 176 SUR CONNECTOR Receptacle––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 2 4 8 Circuit No.1 H JST 5 1.7(.067) 2.9(.114) 0.8 (.031) 0.8 (.031) A B 1.25(.049) 1.45(.057) 1.65(.065) 14 15 16 17 20 Model No. 02SUR-32S 04SUR-32S 08SUR-32S 14SUR-32S 15SUR-32S 16SUR-32S 17SUR-32S 20SUR-32S Dimensions mm(in.) A B Q'ty / box 0.8(.031) 2.4(.094) 2,000 2.4(.094) 4.0(.157) 2,000 5.6(.220) 7.2(.283) 2,000 10.4(.409) 12.0(.472) 2,000 11.2(.441) 12.8(.504) 2,000 12.0(.472) 13.6(.535) 2,000 12.8(.504) 14.4(.567) 2,000 15.2(.598) 16.8(.661) 2,000 Material and Finish Contact: Copper alloy, tin-plated Housing: Polyamide, UL94V-0, natural (ivory) Shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 2 4 8 Circuit No.1 B A 14 15 2.7(.106) 0.8 (.031) 16 1.75(.069) 17 1.0 (.039) 0.2(.008) 20 Model No. SM02B-SURS-TF SM04B-SURS-TF SM08B-SURS-TF SM14B-SURS-TF SM15B-SURS-TF SM16B-SURS-TF SM17B-SURS-TF SM20B-SURS-TF A Dimensions mm(in.) B Q'ty / reel 0.8(.031) 3.8(.150) 3,500 2.4(.094) 5.4(.213) 3,500 5.6(.220) 8.6(.339) 3,500 10.4(.409) 13.4(.528) 3,500 11.2(.441) 14.2(.559) 3,500 12.0(.472) 15.0(.591) 3,500 12.8(.504) 15.8(.622) 3,500 15.2(.598) 18.2(.717) 3,500 Material and Finish 0.45(.018) 1.0 (.039) Contact: Copper alloy, copper-undercoated, tin/lead plated Wafer: Polyamide, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin/lead plated Note: The products listed above are supplied on embossed-tape. PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– 0.8 ± 0.1(.031 ± .004) 0.5 ± 0.1(.020 ± .004) Header outline 0.7 ± 0.1 (.028 ± .004) 1.2 ± 0.1 (.047 ± .004) 1.75(.069) 2.3 ± 0.1 1.0 ± 0.1 (.091 ± .004) (.039 ± .004) 0.35 ± 0.1 (.014 ± .004) 1.7 ± 0.1(.067 ± .004) 3.9(.154) Note: 1. Tolerances are non-cumulative: ±0.05mm(±.002" ) for all centers. 2. Dimensions above should serve as a guideline. Contact JST for details. 177 SUR CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Feeding direction Feeding direction [80(3.150)dia.] 330 ± 2.0 (12.992 ± .079)dia. Carrier tape [13.0(.512)dia.] 2.5 W1-+ 1.0 (W1-+ .098 .039 ) Connector loaded area Lead tape 20 vacancies min. 400(15.748)min. Tail tape 40(1.575)min. 2.0 ± 0.5 (0.79 ± .020) 2.0 ± 0.1 4.0 ± 0.1 1.55 ± 0.05 (.061 ± .002)dia. (.157 ± .004) (.079 ± .004) F ± 0.1(.004) F ± 0.1(.004) W ± 0.3(.012) 8.0 ± 0.1 (.315 ± .004) Carrier tape 0.3 ± 0.05 (.012 ± .002) Cover tape S ± 0.1(.004) W ± 0.3(.012) 0.3 ± 0.05 (.012 ± .002) Cover tape 1.75 ± 0.1 (.069 ± .004) (20 circuits) 1.75 ± 0.1 (.069 ± .004) (2 to 17 circuits) 2.0 ± 0.1 4.0 ± 0.1 1.55 ± 0.05 (.061 ± .002)dia. (.157 ± .004) (.079 ± .004) Cover tape leader area 8.0 ± 0.1 (.315 ± .004) Circuits F Taping dimensions mm(in.) S 2,4 5.5(.217) 8 7.5(.295) 14 to 17 20 Carrier tape W Reel dimensions mm(in.) W1 Q'ty / reel – 12( .472) 13.5( .531) 3,500 – 16( .630) 17.5( .689) 3,500 11.5(.453) – 24( .945) 25.5(1.004) 3,500 14.2(.559) 28.4(1.118) 32(1.260) 33.5(1.319) 3,500 Note: 1. Specifications conform to JIS C 0806. The tape width, connector recess hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice. 178
04SUR04SUR32W300 价格&库存
很抱歉,暂时无法提供与“04SUR04SUR32W300”相匹配的价格&库存,您可以联系我们找货
