Han® 3 A RJ45
Advantages
l
l
Technical characteristics
RJ45 Ethernet-Data connector suitable for industry
Connector type Han® 3 A Connector RJ45
acc. to IEC 61 076-3-106 variant 5
ool-less field-assembly with HARAX ® rapid
T
termination in IDC technology
Number of contacts
l
Category of transmission Cat. 5
l
Compact design and very robust housing
l
Han
Han® 3 A connector RJ45, 4-poles, Cat. 5
uitable for termination of solid and stranded
S
cables
4
Transmission
performance Category 5 / Class D up to 100 MHz
acc. to ISO/IEC 11 801:2002,
EN 50 173-1
Transmission rate
10/100 Mbit/s
Shielding
fully shielded, 360° shielding contact
Cable termination tool-less with IDC contacts
l
Up to 10 x reconductable
Conductor cross section
stranded
AWG 24/7 - AWG 22/7
solid
AWG 23/1 - AWG 22/1
l
PROFINET compatible
Conductor diameter
l
Min. 500 mating cycles
Cable outer diameter 6.5 mm – 9.5 mm
Degree of protection
IP 65 / IP 67
Temperature range
-40 °C … +70 °C
Housing material
Plastic version
Metal versions
Standard
M-version
Identification
max. 1.6 mm
Part No.
Han® 3 A connector set RJ45, 4-poles
Polycarbonate, UL 94 V0, black
Zinc die-cast, powder coating grey
Zinc die-cast, powder coating black
Drawing
Dimensions in mm
Steckgesicht
nach
IEC 60603.7
incl. housing, cable gland
and instruction manual
Plastic version, black
straight
angled
09 45 125 1100
09 45 125 1104
Metal version Standard, grey
straight
angled
09 45 115 1100
09 45 115 1104
Metal version M, black
straight
angled
09 45 115 1102
09 45 115 1106
Coding pin set
09 45 820 0000
Assembled system cables see catalogue “Intelligent Network Solutions”
Dimensions vaild for plastic version, straight
04
07
很抱歉,暂时无法提供与“09 45 115 1100”相匹配的价格&库存,您可以联系我们找货
