09 70 020 2816
09 70 020 2816
    HARTING(浩亭)
    HARTING - 09 70 020 2816 - Heavy Duty Connector, Staf, Insert, 20 Contacts, 16A, Plug, Solder Pin
09 70 020 2816 数据手册
Staf ® Contents Page Technical characteristics Staf ® . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 09.02 Staf ® 6 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 09.03 Staf ® 14 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 09.04 Staf ® 20 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 09.05 Staf ® 40 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 09.06 Staf 09 . 01 Staf®   Features Features • Degree of protection for hoods/housings for coupled connector: IP 44 Specifications Approvals DIN EN 60 664-1 DIN EN 61 984 , Inserts Number of contacts 6, 14, 20, 40 (2x20) Electrical data acc. to EN 61 984 Rated current Rated voltage 10 A ∼ 25 V / − 60 V Rated voltage acc. to UL/CSA 50 V Insulation resistance ≥ 1010 Ω Material polyamide Limiting temperatures -40 °C ... +100 °C Flammability acc. to UL 94 HB Mechanical working life - mating cycles ≥ 500 Staf Contacts Current carrying capacity The current carrying capacity of the connectors is limited by the thermal load capability of the contact element material including the connections and the insulating parts. The derating curve is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly, without exceeding the allowed maximum temperature. Measuring and testing techniques according to DIN EN 60 512-5 Material Surface - hard-silver plated Contact resistance 3 µm Ag ≤ 2 mΩ Screw terminal - Wire gauge1) - AWG - Tightening/test torque 1.5 mm² 16 0.25 Nm Solder terminal - Wire gauge1) - AWG 2.5 mm² 14 In accordance with the appropriate regulations a wire-end sleeve has to be used at clamps without wire protection (see „Screw terminal“, chapter 00). Operating current Hoods/Housings Accessories Cable clamps Coding of hoods/housings Label acc. to CSA-approval Ambient temperature ➀ Staf® 6 ➁ Staf® 14 ➂ Staf® 20 09 . 02 1) geometric wire gauge copper alloy see chapter 30 / 31 chapter 40 chapter 40 chapter 40 Staf® 6 Size 3 A ∼ 25 / − 60 V 10 A Number of contacts 6         Part number Identification Series Screw terminal Staf® Female Insert (M) Male insert (F) Drawing Dimensions in mm Contact arrangement (view from termination side)     09 70 006 2813 09 70 006 2616     Staf Solder terminal Staf® Contact arrangement (view from termination side)     09 70 006 2812 09 70 006 2615     Mounting example Stock items in bold type 09 . 03 Staf® 14 Size 10 A ∼ 25 / − 60 V 10 A Number of contacts 14         Part number Identification Series Screw terminal Staf® Female Insert (M) Male insert (F) 09 70 014 2811 09 70 014 2614 Drawing 1) Dimensions in mm Distance for contact max. 24 mm Staf Contact arrangement (view from termination side) Solder terminal Staf® 09 70 014 2810 09 . 04 09 70 014 2613 Panel cut out for inserts for use without hoods/housings Stock items in bold type Staf® 20 Size 16 A ∼ 25 / − 60 V 10 A Number of contacts 20         Part number Identification Series Screw terminal Staf® Female Insert (M) Male insert (F) 09 70 020 2817 09 70 020 2622 Drawing 1) Dimensions in mm Distance for contact max. 24 mm Staf Contact arrangement (view from termination side) Solder terminal Staf® 09 70 020 2816 09 70 020 2621 Panel cut out for inserts for use without hoods/housings Stock items in bold type 09 . 05 Staf® 40 Size 32 A ∼ 50 / − 60 V 10 A Number of contacts 40                   Part number Identification Series Screw terminal Staf® 1-20 1-20 Female Insert (M) Male insert (F) 09 70 020 2817 09 70 020 2817 09 70 020 2622 09 70 020 2622 Drawing 1) Dimensions in mm Distance for contact max. 24 mm Staf Contact arrangement (view from termination side) Solder terminal Staf® 1-20 1-20 09 70 020 2816 09 70 020 2816 09 70 020 2621 09 70 020 2621 Panel cut out for inserts for use without hoods/housings 09 . 06 Stock items in bold type
09 70 020 2816 价格&库存
很抱歉,暂时无法提供与“09 70 020 2816”相匹配的价格&库存,您可以联系我们找货
  • 1+288.865021+37.36910
  • 5+265.804745+34.38590
  • 10+248.5968710+32.15980
  • 25+227.6329825+29.44780
  • 50+219.3347750+28.37430
    • 1+347.263751+44.92387
