09458000183
09458000183
    HARTING(浩亭)
    连接器 适配器 用于 ix Industrial® 系列
09458000183 数据手册
ls? a n g i d s e'll n a a Dat ether w el of Tog new lev e! ea v c e n i a h rm ac o f r e p The new top performer for data and signals HARTING ix Industrial® More compact. More robust. More powerful. HARTING ix Industrial® Increased miniaturisation. Your advantages at a glance. The HARTING ix Industrial® is our answer to the challenges that will be presented by Industry 4.0 and the IoT. Successful miniaturisation ensures the HARTING ix Industrial® will be a top performer in your application. The ix Industrial® interface demonstrates its capabilities in Industrial Ethernet (type A) as well as in signals and serial BUS systems (type B). One standard – Two mating faces. Millions of possible applications. With the two mating face types A and B (both standardised according to IEC 61076-3-124), you are always on the right track: with no mix-ups and no malfunctions. 70% less size compared to the RJ45 Reduce the size of your printed circuit board, gain space, miniaturise your hoods and housings, and minimise weight by taking advantage of Captain ix. Robust socket with THR shield contacts. With ix Industrial®, you get outstanding stability on the printed circuit board. HARTING ix Industrial® Shown in actual size A closer look at the ix Industrial® portfolio: Visit us at the HARTING eShop. Resistant to shock and vibration, designed for 5000 mating cycles It shakes, rattles and vibrates. Captain ix secures your connection: fewer outages and more secure communication. Kat. 6A performance for 1/10 Gbit/s PoE/PoE+ capability. Captain ix offers you a future-proof Ethernet connection with top performance. 1/10 GBit/s Two snap-in metal hooks ensure that the socket receptacle and the plug connector are safely connected. It clicks in! You know the connection is secure when you hear the click when plugging in. Unplugged accidentally? Impossible! Continuous 360° shielding and robust cable attachment. Captain ix protects your connection from electromagnetic radiation: less susceptibility to interference results in better connections. 360° schielding HARTING ix Industrial® HARTING ix Industrial® Compact. Robust. Powerful. e s ec u r A : n s! s s io M y m i tion a lway c co n n e Plan for tomorrow today: with the more compact, robust and powerful HARTING ix Industrial® interface. The new HARTING ix Industrial® connector is a clear commitment to miniaturisation. Standardised according to IEC 61076-3-124, this connector sets a new benchmark for modularisation and digitisation: one form factor, two mating faces – with type A for Ethernet and type B for signals and serial BUS systems. The ix Industrial® provides you with a solution today that ensures your investment into the future. HARTING ix Industrial® Product overview Images Advantages Type A (data) A A PCB sockets A Type B (signal) B T HR shield contacts are used to secure the robust socket permanently onto the PCB. Type A (data) Type B (signal) ix Industrial® type A, angled vertical, solder termination, roll of 400 pieces 09 45 281 2560 ix Industrial® type A, angled vertical, solder termination, 1 piece 09 45 281 2560 333 ix Industrial® type A, angled horizontal, solder termination, roll of 550 pieces 09 45 281 2561  ix Industrial® type A, angled horizontal, solder termination, 1 piece Available in: Q2/2019 T heir compatibility with the reflow soldering process means: a) They can be integrated into the existing infrastructure, b) Less time is needed for on-board processing.  ix Industrial® type A, vertical, solder termination, 1 piece 09 45 281 2562 333  ix Industrial® type B, angled vertical, solder termination, roll of 400 pieces 09 45 281 9000 It is not possible to mistakenly plug in the wrong connector, because of the A / B coding of the mating face.  ix Industrial® type B, angled vertical, solder termination, 1 piece 09 45 281 9000 333  ix Industrial® type B, angled horizontal, solder termination, roll of 550 pieces 09 45 281 9001  ix Industrial® type B, angled horizontal, solder termination, 1 piece Available in: Q2/2019 B 09 45 281 2561 333 09 45 281 2562 B A Product number  ix Industrial® type A, vertical, solder termination, roll of 450 pieces B Connectors Description  uitable for various conS ductor cross-sections. IDC insulation displacement terminal connection (can be assembled in the field) for easy installations. 09 45 281 9001 333  ix Industrial® type B, vertical, solder termination, roll of 450 pieces 09 45 281 9002  ix Industrial® type B, vertical, solder termination, 1 piece 09 45 281 9002 333  ix Industrial® type A, AWG 28 – 22, Cat. 6A , solder termination, 100 pieces 09 45 181 2560 XL  ix Industrial® type A, AWG 28 – 26, Cat. 6A , IDC, 100 pieces 09 45 181 2561 XL  ix Industrial® type A, AWG 24, Cat. 6A , IDC, 100 pieces 09 45 181 2562 XL  ix Industrial® type B, AWG 28 – 22, ­solder termination, 100 pieces 09 45 181 9000 XL  ix Industrial® type B, AWG 28 – 26, IDC, 100 pieces 09 45 181 9001 XL  ix Industrial® type B, AWG 24, IDC, 100 pieces 09 45 181 9002 XL HARTING ix Industrial® Product overview Images Type A (data) Pre-assembled system cables save time and money. Type B (signal)  00 % tested 1 and functional system cables help avoid sources of error. Adapter Tool Description Product number  ix Industrial® type A copper cable (round), PVC, pre-assembled on both sides, number of wire cores: 8, wire layout: 4x 2x AWG 28/7, Cat. 6A The ix Industrial® interface can easily be integrated by combining it with other mating faces. Combinations of mating faces are available on request, including ix-M12, ix-D-Sub, etc. Type A (data) System cable ix-ix System cable ix-RJ45 xxx 002 003 004 005 007 010 015 020 025 030 050 075 100 Length: 0.2 0.3 0.4 0.5 0.7 1.0 1.5 2.0 2.5  ix Industrial® type B copper cable (round), PVC, pre-assembled on both sides, number of wire cores: 10, wire layout: 10x AWG 26 xxx 003 005 010 015 020 030 050 075 100 Length: 0.3 0.5 1.0 1.5 2.0 3.0 5.0 xxx 3.0 5.0 7.5 10.0 33 48 111 1A20 xxx 7.5 10.0  ix Industrial® type B copper cable (round), PUR, pre-assembled on both sides, number of wire cores: 10, wire layout: 10x AWG 26 33 48 111 1A21 xxx 003 005 010 015 020 030 050 075 100 Length: m 0.2 0.3 0.4 0.5 0.7 3.0 5.0 7.5 10.0  ix Industrial® type A copper cable (round), PVC, pre-assembled on both sides, number of wire cores: 8, wire layout: 4x 2x AWG 28/7, Cat. 6A XXX 09 48 261 2749 xxx 002 003 004 005 007 010 015 020 025 030 050 075 100 Length: m 0.2 A 09 48 262 6749 xxx 0.3 0.4 0.5 0.7 1.0 1.5 2.0 2.5 3.0 5.0 7.5 10.0 Adapter PCB: preLink® PCB to ix Industrial® 20 82 008 0001 ix Industrial® assembly tool 09 45 800 0181 ix Industrial® FLUKE channel adapter Available in: Q2/2019 09 45 800 0183  reLink® technology paired with the p robustness of the ix Industrials® for connecting cables easily.  ual-function assembly tool for the IDC D press-fit process and crimping the cable holder.  atchet mechanism to optimally apply R force.  Compatible with the DSX CableAnalyzer™ series. Testing Accessories Advantages T ests ix Industrial® cable assemblies quickly and conveniently. Complies with the strictest requirements. HARTING ix Industrial® Machinery & robotics Energy Automation Data networks Transportation HARTING ix Industrial® HARTING Technology Group info@HARTING.com www.HARTING.com BD/2019-04-6/2.5 98 32 023 0201 Version 3 HARTING.com ​- the gateway to your country website.
09458000183 价格&库存
很抱歉,暂时无法提供与“09458000183”相匹配的价格&库存,您可以联系我们找货
