19396160548
19396160548
    HARTING(浩亭)
    CONN HOOD SIDE ENTRY SZ16B M40
19396160548 数据手册
Han® HP Direct B Sizes 6 B, 10 B, 16 B, 24 B Features Technical characteristics •  Housings systen without using a bulkheasd mounting housing on the device side • Hoods in size 6 B, 10 B, 16 B and 24 B •  Suitable for all contact inserts Han® B •  Top and side entry from M20 to M40 all sizes •  Optional coding by two coding elements • Panel cut-outs compatible with standard Han® B panel cut-outs Specifications DIN EN 61 984 DIN EN 60 664-1 Hoods Material Colour Surface - top coat aluminium die-cast RAL 7037 (grey) powder coated Locking element Screw locking Marerial M6 stainless steel Tightening torque 4 Nm Housing seal NBR Mounting Flange Material Colour zinc die-cast unpainted Surface electrically conductive Coding element Material Color polycarbonat red -40 °C ... +125 °C Limit temperature Protection degree acc. to DIN EN 60 529 in locked position IP66 / IP68 / IP69K HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com Han® 2016-08-16 Data Sheet 1159 Han® HP Direct B Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Drawing Han® 6 HP Direct B Hood top entry 19 39 606 0445 19 39 606 0446 19 39 606 0447 19 39 606 0448 M20 M25 M32 M40 Panel cut out Han® 6 HP Direct B Hood side entry 19 39 606 0545 19 39 606 0546 19 39 606 0547 19 39 606 0548 M20 M25 M32 M40 Panel cut out Han® 10 HP Direct B Hood top entry 19 39 610 0445 19 39 610 0446 19 39 610 0447 19 39 610 0448 M20 M25 M32 M40 Panel cut out Han® 10 HP Direct B Hood side entry 19 39 610 0545 19 39 610 0546 19 39 610 0547 19 39 610 0548 M20 M25 M32 M40 Panel cut out Dimensions in mm Han® HP Direct B Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Drawing Han® 16 HP Direct B Hood top entry 19 39 616 0445 19 39 616 0446 19 39 616 0447 19 39 616 0448 M20 M25 M32 M40 Panel cut out Han® 16 HP Direct B Hood side entry 19 39 616 0545 19 39 616 0546 19 39 616 0547 19 39 616 0548 M20 M25 M32 M40 Panel cut out Han® 24 HP Direct B Hood top entry 19 39 624 0445 19 39 624 0446 19 39 624 0447 19 39 624 0448 M20 M25 M32 M40 Panel cut out Han® 24 HP Direct B Hood side entry 19 39 624 0545 19 39 624 0546 19 39 624 0547 19 39 624 0548 M20 M25 M32 M40 Panel cut out Dimensions in mm Han® HP Direct B Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Mountimh Flange Set 2 pieces 09 39 000 9902 Coding element Set 4 pieces 09 39 000 9903 Drawing Dimensions in mm
19396160548 价格&库存
很抱歉,暂时无法提供与“19396160548”相匹配的价格&库存,您可以联系我们找货
  • 1+841.308401+108.01404
