2000-410
2000-410
    WAGO(万可电子)
    10 位置 接线板 - 交叉连接 跳接器 扁平引脚
2000-410 数据手册
Printview: Push-in type jumper bar; insulated; 10-way; nominal current 14 A - Item No.: 2000-410 . Push-in type jumper bar; insulated; 10-way; nominal current 14 A Item No.: 2000-410 . Push-in type jumper bar; insulated; 10-way; nominal current 14 A . Marking . Business data Supplier WAGO Item no. 2000-410 GTIN / EAN 4045454721923 Content 1 Order amount 25 Customer item number . Notes Technical data Miscellaneous Color light gray Rated voltage EN (1) [V] 800 [V] Nominal current [A] 14 [A] Nominal current (Ex e II) [A] 12 [A] Fire load [MJ] 0.023 [MJ] Weight [g] 2.927 [g] Width 34 mm / 1.339 in Height 19 mm / 0.748 in Length 4.1 mm / 0.161 in WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Push-in type jumper bar; insulated; 10-way; nominal current 14 A - Item No.: 2000-410 Images & drawings . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 2
2000-410 价格&库存
很抱歉,暂时无法提供与“2000-410”相匹配的价格&库存,您可以联系我们找货
  • 1+68.183091+8.86359
  • 10+57.9716310+7.53613
  • 25+54.3378325+7.06375
  • 50+51.7425650+6.72637
  • 100+49.27263100+6.40529
  • 250+46.18842250+6.00435
  • 500+43.98510500+5.71792
  • 1000+41.887891000+5.44529
库存:278
2000-410
    • 36+25.12511
    库存:37
