2010-115
2010-115
    WAGO(万可电子)
    WAGO - 2010-115 - Terminal Block Marker, Protective Warning Marker, Wago TOBJOB S 2010 Series Termin...
2010-115 数据手册
TOPJOB® S Through/Ground Conductor/Shield and Ex Terminal Blocks 10 (16) mm² 2010 Series 1 0.5 … 10 (16) mm²1 AWG 20 … 6 800 V/8 kV/3 2 600 V, 65 AU 600 V, 65 A2 IN 57 A (76 A) 0.5 … 10 (16) mm²1 AWG 20 … 6 800 V/8 kV/3 2 600 V, 65 AU 600 V, 65 A2 IN 57 A (76 A) Terminal block width 10 mm / 0.394 in. L 17 … 19 mm / 0.71 in.3 Terminal block width 10 mm / 0.394 in. L 17 … 19 mm / 0.71 in.3 21   1 Conductor sizes: 0.5 mm² … 16 mm² “s + f-st”; Push-in conductor sizes: 2.5 mm² … 16 mm² “s” and 2.5 mm² … 10 mm² “insulated ferrule, 18 mm” 2 800 V = rated voltage 8 kV = rated surge voltage 3 = pollution degree (see Section 14) 3 Strip length, see packaging or instructions. 36,9 mm/ 1.45 in 36,9 mm/ 1.45 in 4 Suitable for Ex i applications 30,8 mm/1.21 in 67,8 mm/2.67 in Item No. 6 See application notes for: Ex e/Ex i separator plate, page 19 Step-down jumper, page 23 Star point jumper, page 103 TOPJOB® S connector, page 98 52,2 mm/2.06 in 89 mm/3.5 in Pack. Unit Item No. Pack. Unit 2-conductor through terminal block 2010-1201 5 gray 4 2010-1204 4 5 blue 4 2010-1202 5 orange 4 25 25 25 3-conductor through terminal block 2010-1301 5 gray 4 2010-1304 4 5 blue 4 2010-1302 5 orange 4 25 25 25 2-conductor ground terminal block 2010-1207 5 green-yellow 4 25 3-conductor ground terminal block 2010-1307 5 green-yellow 4 25 2-conductor shield terminal block 2010-1208 5 white 25 Item-Specific Accessories End and intermediate plate, 1 mm thick orange 2010-1292 gray 2010-1291 Ex e/Ex i separator, orange, 6 3 mm thick 120 mm 209-191 Item-Specific Accessories 100 (4x25) 100 (4x25) End and intermediate plate, 1 mm thick orange 2010-1392 gray 2010-1391 5 Suitable for Ex e II applications 550 V, 51 A for 2-conductor terminal blocks 550 V, 50 A for 3-conductor terminal blocks (see Section 14) Commoning with step-down jumpers An end plate must be inserted between the terminal blocks to be jumpered. Step-down jumper 2016-499 commons 16/10 mm² AWG 16/8 (2016/2010 Series) terminal blocks with 10/6/4/2.5 mm² AWG 8/10/12/14 (2010/2006/2004/2002 Series) terminal blocks. 100 (4x25) Step-down jumpers are simply pushed down for full insertion, similar to other push-in type jumper bars. 100 (4x25) 50 (2x25) 2010 Series Accessories Appropriate marking systems: WMB/Marking strips (see Section 13) Push-in type jumper bar, insulated, IN 57 A, light gray 2-way 2010-402 3-way 2010-403 4-way 2010-404 5-way 2010-405 50 50 50 50 Push-in type jumper bar, insulated, IN 57 A, light gray from 1 to 3 2010-433 from 1 to 4 2010-434 from 1 to 5 2010-435 50 (2x25) 50 (2x25) 50 (2x25) (2x25) (2x25) (2x25) (2x25) Protective warning marker, with high-voltage symbol, black, for 5 terminal blocks 50 (2x25) yellow 2010-115 Finger guard, touchproof cover protects unused conduc- Note: The total current flowing shall not exceed the rating tor entries of the step-down jumper/push-in type jumper bar. yellow 2010-100 100 (4x25) ® Modular TOPJOB S connector, 6 can be snapped together, for jumper contact slot 50 (2x25) gray 2010-511 Test plug adapter, for 4 mm Ø test plug gray 2009-174 100 (4x25) Star point jumper, insulated, WMB Multi marking system, 6 IN = IN terminal block, light gray 10 strips with 10 markers per card, 1-3-5 stretchable 5 … 5.2 mm 2010-405/011-000 50 (2x25) plain 793-5501 Marking strip, plain, Step-down jumper, insulated, 6 11 mm wide, IN 57 A 50 (2x25) 50 m roll light gray 2016-499 white 2009-110 Certification organizations can be found in the overview on page 622. 5 1 1
2010-115 价格&库存
很抱歉,暂时无法提供与“2010-115”相匹配的价格&库存,您可以联系我们找货
  • 1+10.412661+1.34763
    • 1+303.18846
    库存:5
    2010-115
      • 10+7.79060
      库存:20
      2010-115
        • 1+92.97474
        库存:50
