Surface Mount Terminal Blocks with Push-Buttons
Pin Spacing 4 mm, 8 mm
2060 Series
t4VSGBDFNPVOUUFSNJOBMCMPDLTXJUI$"(&$-".1®S
connection and push-buttons
t%JSFDUQVTIJOPGTPMJEDPOEVDUPST
t1VTICVUUPOGPSDPOOFDUJPOPGTUSBOEFEDPOEVDUPST
and for removal of all wire types
t"UPUBMIFJHIUPGPOMZNNIFMQTNJOJNJ[F
shadowing in LED applications
tPackaged in tape-and-reel for automated SMT processes
t-BSHFGMBUBSFBGPSFBTZQJDLOQMBDF
t8JSJOHQPSUTXJUICBMDPOZEFTJHOoDSFBUFTMFBEJO
for ease of wiring, even at a slight angle
Technical data:
Pin Spacing
Rating per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Rated voltage, 1-pole
Rated voltage for 2-poles and more
Nominal current UL
Nominal current CSA
4 mm
0.157 in
IEC/EN 60664-1
III
III
II
3
2
2
63 V 160 V 320 V
2.5 kV 2.5 kV 2.5 kV
9A
9A
9A
U/Y
600 V
250 V
9A
6A
8 mm
0.314 in
IEC/EN 60664-1
III
III
II
3
2
2
63 V 160 V 320 V
9A
9A
9A
U/Y
600 V
9A
6A
Conductor data:
Connection technology
Conductor size: solid
Conductor size: fine-stranded
AWG
Strip length
Conductor entry angle
CAGE CLAMP®S
0.20 – 0.75 mm2
0.20 – 0.75 mm2
24 – 18
6 – 7 mm / 0.24 – 0.28 in
0° to PCB
2060 Series accessories:
Material data:
Material group
Insulating material
Flammability rating per UL 94
Lower/Upper temperature limit
Contact material
Contact plating
I
Glass fiber-reinforced polyphthalamide (PPA-GF)
V0
-60ºC/+105ºC*
Copper alloy
Tin-plated
Application notes:
Suitable for lead-free, reflow-soldering profiles acc. to DIN EN 61760-1 and IEC 60068-2-58 up to max. 260ºC peak
temperature. Due to customer specific variables (e.g., component configuration and orientation, type of soldering machine, solder paste), it is recommended that trial runs are conducted to ensure product and process compatibility under
actual manufacturing conditions.
Recommendation for stencil: Material thickness, 150 µm. Stencil layout identical to pad layout.
Depending on reflow soldering temperatures and times, color deviations may occur for light gray connectors.
These deviations will have no impact on functionality.
*For applications requiring upper temperature limit higher than 105ºC, contact factory. Restrictions may apply.
Operating Tools
Shorting Bar
Interconnecting Link
233-335
2000-402
2060-90x
2060 Series
Pin spacing 4 mm / 0.157 in
0.2 - 0.75 mm2
Pin spacing 8 mm / 0.314 in
AWG 24 - 18
1p
160 V/2.5 kV/2 9 A
2 - 3p
600 V/9 A U
250 V/9 A U
600 V/6 A Y
250 V/6 A Y
0.2 - 0.75 mm2
AWG 24 - 18
630 V/6 kV/2 9 A
600 V/9 A U
600 V/6 A
L = (pole no. x pin spacing) - 0.1 mm
Pole No.
Item No.
1
2
3
1
2
3
2060-401/998-404
2060-402/998-404
2060-403/998-404
2060-421/998-404
2060-422/998-404
2060-423/998-404
R = Feed direction
A = (pole no. x pin spacing) + 4 mm
Pack Unit/
Pieces per Reel
Surface mount terminal blocks with push-buttons
in tape-and-reel packaging
Reel diameter: 330 mm
Inserting solid conductors via
push-in termination.
1500
1000
750
1500
1000
750
Pole No.
Item No.
Pack Unit/
Pieces per Reel
2
2060-802/998-404
1000
Inserting/removing fine-stranded conductors by lightly pressing on push-button
(e.g., using a 233-335 operating tool or a ball point pen).
Group arrangement is possible without altering pad layout.
2000-402 Shorting Bar -- used to complete the circuit at the end
of a string of linear LED modules, e.g., insert with WAGO logo
facing upward, and at a slight angle so the bottom of the housing
clears the bottom edge of the terminal block wire entry opening.
很抱歉,暂时无法提供与“2060-423/998-404”相匹配的价格&库存,您可以联系我们找货
