2092-3403/200-000
2092-3403/200-000
    WAGO(万可电子)
    插件,P=7.5mm
    接线端子 1x3P 间距:7.5mm 排数:1 每排Pin数:3
2092-3403/200-000 数据手册
Data sheet | Item number: 2092-3403/200-000 THR male header; 1.4 mm Ø solder pin; straight; Pin spacing 7.5 mm; 3-pole; light gray https://www.wago.com/2092-3403/200-000 Dimensions in mm L = (pole no. – 1) x pin spacing + 7.2 mm A = 3.6 mm THT solder pin A = 2.4 mm THR solder pin Page 1/4 Version 03.10.2022 Continued on next page Data sheet | Item number: 2092-3403/200-000 https://www.wago.com/2092-3403/200-000 • Assembly of female connectors without loss of poles, allowing different functions to be divided within one male header (≥ 4 poles) • Coding pins inserted into the header interface prevent mismating, allowing subsequent coding in panel feedthrough applications • The female connector is fully shrouded by the male header's housing, providing vibration resistance up to 20 g Safety information 1 The picoMAX® Pluggable Connection System includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Variants: Direct marking Other versions (or variants) can be requested from WAGO Sales or configured at https:// configurator.wago.com/. . Ratings per IEC/EN 60664-1 Approvals per UL 1059 Nominal voltage (III/3) 400 V Rated voltage UL (Use Group B) 300 V Rated impulse voltage (III/3) 6 kV Rated current UL (Use Group B) 15 A Rated voltage (III/2) 630 V Rated voltage UL (Use Group D) 300 V Rated impulse voltage (III/2) 6 kV Rated current UL (Use Group D) 10 A Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 6 kV Rated current 16 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Polluti­ on degree 2 Total number of potentials 3 Number of connection types 1 Pole number 3 Number of levels 1 . . . . Pin spacing 7.5 mm / 0.295 inches Width 22.2 mm / 0.874 inches Height 21.9 mm / 0.862 inches Height from the surface 19.5 mm / 0.768 inches Depth 14.4 mm / 0.567 inches Solder pin length 2.4 mm Solder pin diameter 1.4 mm Plated through-hole diameter (THR) 1.6 (+0.1) mm Variable coding Yes Anti-rotation protection Yes . . Page 2/4 Version 03.10.2022 Continued on next page Data sheet | Item number: 2092-3403/200-000 https://www.wago.com/2092-3403/200-000 Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection No Plugging without loss of pin spacing Yes Mating direction to the PCB 90 ° Locking of plug-in connection Locking latch PCB contact THR Note (material data) Information on material data can be found here Color light gray Material group I Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating Tin Fire load 0.053 MJ Weight 2.3 g Limit temperature range -60 … +100 °C Processing temperature -35 … +60 °C PU (SPU) 100 Stück Packaging type Box Country of origin VKOrg Germany DE GTIN 4050821396529 Customs tariff number VKOrg Germany 85366990990 . . . . . Approvals and certificates General approvals Approval Standard Certificate name CSA DEKRA Certification B.V. C22.2 2362521 cURus Underwriters Laboratories Inc. UL 1059 E45172 KEMA/KEUR DEKRA Certification B.V. EN 61984 71-102261 REV.2 UL Underwriters Laboratories Inc. UL 1977 E45171 . Page 3/4 Version 03.10.2022 Continued on next page Data sheet | Item number: 2092-3403/200-000 https://www.wago.com/2092-3403/200-000 Downloads Environmental Product Compliance Compliance Search Environmental Product Compliance 2092-3403/200-000 . Documentation Additional Information Technical Section 03.04.2019 pdf 1949.09 KB pdf 392.38 KB . CAD/CAE-Data CAD data CAE data 2D/3D Models 2092-3403/200-000 ZUKEN Portal 2092-3403/200-000 . . Installation notes Coding Coding a male header (via coding key car­ rier and two keys for male header, see symbol). . Subject to changes. Please also observe the further product documentation! Current addresses can be found at: w w w.wago.com Page 4/4 Version 03.10.2022
2092-3403/200-000 价格&库存
很抱歉,暂时无法提供与“2092-3403/200-000”相匹配的价格&库存,您可以联系我们找货
2092-3403/200-000
    2092-3403/200-000
      • 137+6.67424
      • 430+6.31151
      • 1720+6.03341
      • 4300+5.75532
      • 12900+5.57396
      库存:200
      2092-3403/200-000
        库存:200
