24 02 004 0000
    HARTING(浩亭)
    HARTING - 24 02 004 0000 - Switch, 4 Ports, Industrial, Unmanaged Fast Ethernet, DIN Rail, RJ45 x 4,...
24 02 004 0000 数据手册
Ha-VIS eCon 2000 Fast Ethernet Basic 3 to 8 Ethernet ports RJ45 and FOC English Unmanaged Plug & Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0°C ... +55°C / Industrial temp.: -40 ... +70° Energy Efficient Ethernet ■ Fast Ethernet Non-Blocking Switch architecture in accordance with IEEE 802.3 ■ Variants with industrial temperature range of -40°C ... +70°C ■ Wide range power supply 24/48 VDC ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-effi cient Ethernet Target markets Machinery & Robotics Automation Industrial network Infrastructure Wind Energy, Solar Energy Transportation Shipbuilding General Description The Ha-VIS eCon 2000 Fast Ethernet family of unmanaged Ethernet switches is equipped with up to 8 Fast Ethernet ports and allow for cost-effi cient and quick expansion and/or reconstruction of network infrastructures. Due to the extremely fl at design, these switches can be accommodated in installations where space is restricted towards the cable connection at the front. The selection includes various combinations of variants with RJ45 and fi bre optic ports. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (autopolarity and auto-MDI(X)) allow for simple plug & play. All variants are available with the temperature ranges „Industrial“ and „Commercial“. Technical characteristics Switch Features Ethernet ports 10BASE-T / 100BASE-TX EEE / 1000Base-TX EEE Housing width Number of ports 46.5 60 mm 120 mm 3, 4, 5 8 7, 8 Type of connection RJ45 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame Size Auto-MDI(X) 1552 bytes Transfer conditions MAC table size 1k entries Transfer speed 10 / 100 Mbit/s 448 kbit Transfer length 100 m (Twisted Pair, Cat 5) Packet buffer size Non-blocking Yes Quality of Service Yes Energy Efficient Ethernet Yes PROFINET compatible Yes EthernetIP compatible Yes Yes Twisted pair Ethernet ports 100BASE-FX Type of fibre Multi-mode (MM) Type of connection Transfer conditions FOC Wavelength 1310 mm Transfer speed Power supply Transfer length Nominal voltage 24 VDC Permissible voltage range 48 VDC Yes Reverse polarity proof Yes Starting current 1.60 A Overcurrent protection at input Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout Input sensitivity 9 VDC ... 60 VDC Surge protection 100 Mbit/s 2 km 15 km -19 dBm ... -14 dBm -15 dBm ... -8 dBm ≤ ≤ -32 dBm ≤ -34 dBm Environmental conditions 5.60 A Yes (2/4 A) 0.77 W ... 3.1 W 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screwed contact +/-/ Supply circuit (according to 60950) Output power Single-mode (SM) SC Duplex SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches Commercial temperature range Industrial temperature range Storage temperature range 0°C ... +55°C -40°C ... +70°C -40 °C ... +85 °C Relative humidity (operation) 0% ... 95 % (non-condensing) Relative humidity (storage and transport) 0% ... 95 % (non-condensing) Air pressure 2000 m (795 hPa) Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. Housing Enclosure width 46.5 mm 60 mm 120 mm 113.5 mm x 46.5 mm x 27.3 mm 113.5 mm x 60 mm x 27.3 mm 113.5 mm x 120 mm x 27.3 mm 162 g ... 170 g 217 g 372 g ... 386 g Dimensions H x W x D (without pluggable screwed contact and holding bracket) Weight Type of installation 35 mm DIN rail acc. to EN 60 715 Material hoods/housings Anodised aluminium Protection class (with plugged screwed contact) IP 30 Protection class Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Vibrationresonance search IEC 60068-2-27 Shock test III illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illumindated green Link/Activity ("L/A") flashes green EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) Status and diagnostic displays Power ("Pwr") Approvals CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions Link is active Link is active and data is transferred Link speed („Spd“) off 10 Mbit/s Link speed („Spd“) illumindated yellow 100 Mbit/s Drawings Technical characteristics / order information Ports / order information Commercial temp.: 0 °C ... +55 °C Industrial temp.: -40 °C ... +70 °C RJ45 SFP SC Enclosure width Power consumption @ 24 VDC MTBF in million h Switch Part no. 3 - - 46.5 mm 32 mA 3.13 Ha-VIS eCon 2030B-A 24 02 003 0010 Ha-VIS eCon 2030BT-A 24 02 003 0000 4 - - 46.5 mm 37 mA 2.99 Ha-VIS eCon 2040B-A 24 02 004 0010 Ha-VIS eCon 2040BT-A 24 02 004 0000 5 - - 46.5 mm 42 mA 2.86 Ha-VIS eCon 2050B-A 24 02 005 0010 Ha-VIS eCon 2050BT-A 24 02 005 0000 6 - 1x MM (2 km) 120 mm 94 mA 1.24 Ha-VIS eCon 2061B-AD 24 02 006 1110 Ha-VIS eCon 2061BT-AD 24 02 006 1100 6 - 1x SM (15 km) 120 mm 81 mA 1.26 Ha-VIS eCon 2061B-AF 24 02 006 1210 Ha-VIS eCon 2061BT-AF 24 02 006 1200 6 - 2x MM (2 km) 120 mm 129 mA 1.20 Ha-VIS eCon 2062B-AD 24 02 006 2110 Ha-VIS eCon 2062BT-AD 24 02 006 2100 6 - 2x SM (15 km) 120 mm 113 mA 1.23 Ha-VIS eCon 2062B-AF 24 02 006 2210 Ha-VIS eCon 2062BT-AF 24 02 006 2200 8 - - 60 mm 58 mA 2.53 Ha-VIS eCon 2080B-A 24 02 008 0010 Ha-VIS eCon 2080BT-A 24 02 008 0000 Copyright © 2014 HARTING Technology Group All rights reserved Date of issue 02.2015 ICPN Datasheet 0834/01 Switch Part no.
24 02 004 0000 价格&库存
很抱歉,暂时无法提供与“24 02 004 0000”相匹配的价格&库存,您可以联系我们找货
    • 1+1339.27152
    库存:22
    24020040000
    • 1+1390.517361+173.10636
    • 10+1258.6216110+156.68658
    库存:19
    24020040000
      • 1+1328.266441+165.35670
      • 2+1313.286992+163.49190
      • 4+1298.575044+161.66040
      • 5+1293.849385+161.07210
      • 15+1264.9604615+157.47570
