24030042120
24030042120
    HARTING(浩亭)
24030042120 数据手册
Ha-VIS eCon 3000 Fast Ethernet Basic PoE / PoE+ 5 to 8 Ethernet ports RJ45, FOC, and PoE / PoE+ English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C /­­ Industrial temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in accordance with IEEE 802.3at ■ Fast Ethernet Non-Blocking Switch architecture in accordance with IEEE 802.3 ■ Variants with industrial temperature range of -40 °C ... +70 °C ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet ■ Optimised DIN rail bracket Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General description The Ha-VIS eCon 3000 Fast Ethernet PoE family of unmanaged Ethernet switches is equipped with up to 8 Fast Ethernet ports and allow for cost-efficient and quick expansion and/or reconstruction of network infrastructures. The switches work as power sourcing equipment (PSE) and are capable of simultaneously providing the full PoE output of 34.2 watts on up to four ports. The slender design of the switches enables an extremely high packing density on the DIN rail. The selection includes various combinations of variants with RJ45 and fibre optic ports. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch features Ethernet ports 10BASE-Te / 100BASE-TX Enclosure width 25 mm Type of connection RJ45 Number of ports 5, 6, 7, 8 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame size Auto-MDI(X) 1522 bytes MAC table size Transfer conditions 1k entries Transfer speed 10 / 100 Mbit/s Transfer length 100 m (Twisted Pair, Cat 5) Packet buffer size 448 kbit Non-blocking Yes Quality of Service Yes Energy-efficient Ethernet Yes PROFINET-compatible Yes EthernetIP-compatible Yes Yes Twisted pair Ethernet ports 100BASE-FX Type of fibre Multi-mode (MM) Type of connection Transfer conditions FOC Wavelength Power supply Nominal voltage 24 VDC Permissible voltage range 48 VDC 9 VDC ... 60 VDC Surge protection Yes Reverse polarity proof Yes Starting current 3.20 A Overcurrent protection at input Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout 54 VDC 6.40 A Output power Input sensitivity 7.20 A Yes (12 A) 1.92 W ... 3.60 W 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) SELV (circuit breaker 10 A) ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches 100 Mbit/s 2 km 15 km -20 dBm ... -14 dBm -15 dBm ... -8 dBm ≤ -30 dBm ≤ -32 dBm Environmental conditions Commercial temperature range Industrial temperature range Storage temperature range 0 °C ... +55 °C -40 °C ... +70 °C -40 °C ... +85 °C Relative humidity (operation) 0% ... 95 % (non-condensing) Relative humidity (storage and transport) 0% ... 95 % (non-condensing) Air pressure HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany 1310 nm Transfer speed Transfer length Single-mode (SM) SC Duplex 2000 m (795 hPa) Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. Enclosures PoE Number of PoE ports 4 Standard IEEE 802.3af / IEEE 802.3at PoE type PSE Supported mode Alternative A Power supply PSE 48 VDC 54 VDC Weight 480 g ... 508 g 2380 mA Material enclosures 375 mA 638 mA Anodised aluminium / powder-coated steel sheet 15.4 W per port 61.6 W total 34.2 W per port 136.8 W total Protection class (with pluggable screw type terminal block) Maximum current (PoE / PoE+) Supported cabling See 802.3at, section 33.1.4 Alternative A, MDI-X (1/2 = V-, 3/6 = V+) Status and diagnostic displays Power ("Pwr") 142 mm x 25 mm x 107.5 mm 35 mm DIN rail acc. to EN 60 715 1380 mA PoE pinout 25 mm Type of installation Maximum power consumption PSE Maximum output power PSE Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) illuminated green Link/Activity ("L/A") off Supply voltage is applied No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green Link is active Link is active and data is transferred Link speed ("Spd") off 10 Mbit/s Link speed ("Spd") illuminated yellow 100 Mbit/s PoE status off PoE status illuminated green Voltage in PoE range PoE status illuminated blue Voltage in PoE+ range PoE status illuminated red Fault PoE is inactive / low voltage IP30 Protection class III Approvals CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions Drawings Technical characteristics / order information Ports / order information Commercial temp.: 0 °C ... +55 °C Industrial temp.: -40 °C ... +70 °C SC Enclosure width Power consumption @ 24 VDC without PoE MTBF in million h Switch Part no. Switch Part no. RJ45 SFP 4 - 1x MM (2 km) 25 mm 0.12 A 1.19 Ha-VIS eCon 3041B-AD-P 24 03 004 1130 Ha-VIS eCon 3041BT-AD-P 24 03 004 1120 4 - 1x SM (15 km) 25 mm 0.12 A 1.19 Ha-VIS eCon 3041B-AF-P 24 03 004 1230 Ha-VIS eCon 3041BT-AF-P 24 03 004 1220 4 - 2x MM (2 km) 25 mm 0.15 A 1.17 Ha-VIS eCon 3042B-AD-P 24 03 004 2130 Ha-VIS eCon 3042BT-AD-P 24 03 004 2120 4 - 2x SM (15 km) 25 mm 0.15 A 1.17 Ha-VIS eCon 3042B-AF-P 24 03 004 2230 Ha-VIS eCon 3042BT-AF-P 24 03 004 2220 6 - - 25 mm 0.08 A 1.18 Ha-VIS eCon 3060B-A-P 24 03 006 0030 Ha-VIS eCon 3060BT-A-P 24 03 006 0020 6 - 1x MM (2 km) 25 mm 0.13 A 1.15 Ha-VIS eCon 3061B-AD-P 24 03 006 1130 Ha-VIS eCon 3061BT-AD-P 24 03 006 1120 6 - 1x SM (15 km) 25 mm 0.13 A 1.15 Ha-VIS eCon 3061B-AF-P 24 03 006 1230 Ha-VIS eCon 3061BT-AF-P 24 03 006 1220 8 - - 25 mm 0.09 A 1.14 Ha-VIS eCon 3080B-A-P 24 03 008 0030 Ha-VIS eCon 3080BT-A-P 24 03 008 0020 Copyright© 2014 HARTING Technology Group All rights reserved Date of issue 02.2015 ICPN Datasheet 0844/01
24030042120 价格&库存
很抱歉,暂时无法提供与“24030042120”相匹配的价格&库存,您可以联系我们找货
  • 1+5003.732761+627.47770
  • 5+4702.854595+589.74700
