30FHH-SM1-GAN-TF(LF)(SN) 数据手册
FHH CONNECTOR
Emboss Tape
0.5mm pitch/Connectors for FPC
Specifications –––––––––––––––––––
This is 2.0mm height connector with the
double-sided contact for FPC. As FPC with
protrusions is used for this FHH connector,
prevention of incomplete insertion and misinsertion are realized and connection
reliability is improved.
• Current rating: 0.5A AC, DC
• Voltage rating: 50V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 70mΩ max.
After environmental testing/ 60mΩ max.
(variation from initial value)
• Insulation resistance: 500MΩ min.
• Withstanding voltage: 200V AC/minute
• Applicable FPC: Conductor pitch/ 0.5mm
Conductor width/ 0.35mm
Mating part thickness/ 0.3±0.03mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
0.65 ±0.05
1.9 ±0.05
1±0.05
Connector outline
3.15 ±0.1
7.2
0.15
1.76 ±0.05
2
Circuit No.1
0.3
±0.05
0.5 ±0.05
0.5(N-1) ±0.05
Note: N --- Number of circuits
1
6.7
FHH CONNECTOR
Connector
B
Dimensions (mm)
C
A
B
Circuits
Model No.
10
10FHH-SM1-GAN-TF
20FHH-SM1-GAN-TF
30FHH-SM1-GAN-TF
40FHH-SM1-GAN-TF
50FHH-SM1-GAN-TF
60FHH-SM1-GAN-TF
40
50
60
Q’ty / reel
4.5
7.4
8.6
2,000
9.5
12.4
13.6
2,000
14.5
17.4
18.6
2,000
19.5
22.4
23.6
2,000
24.5
27.4
28.6
2,000
29.5
32.4
33.6
2,000
Material and Finish
Contact: Copper alloy, nickel-undercoated, gold-plated (nickel-stripe)
Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Housing: Heat resisting resin, UL94V-0, natural
Cover: Heat resisting resin, UL94V-0, black
7.2
C
2
RoHS compliance This product displays (LF)(SN) on a label.
Note: This products listed above are supplied on embossed-tape.
0.5
A
Lead section dimensions of FPC
0.5(N+1)+1.4 ±0.05
0.5(N+1)
±0.05
0.5(N+1)-0.2 ±0.05
0.5(N-1)
0.35 ±0.03
±0.0.3
0.5 ±0.07
0.5 ±0.03
0.3 ±0.03
4.2 MIN
2.64
±0.1
3.5 min
1.54 ±0.1
0.5
±0.07
R0.2
2
30FHH-SM1-GAN-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“30FHH-SM1-GAN-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
