EH CONNECTOR
Radial Tape
2.5 mm pitch/Disconnectable Crimp style connectors
3
4
EH CONNECTOR
• Current rating: 3 A AC/DC (AWG #22)
• Voltage rating: 250 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 800 VAC/minute
エンボス
• Applicable wire: AWG #32 to #22
• Applicable PC board thickness: 0.8 to 1.6 mm
5
This, the thinnest, 2.5 mm pitch connector, is
8.1 mm in height after mounting and
3.8 mm in width. It is designed to meet the
demand for the high-density connection of
internal wires to printed circuit boards. It is
compact, highly reliable and low in cost.
Compact and slim
Highly reliable contact
Polarizing guides
Easy and effective crimping
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Standards
Radial-tape
Side entry type
2.5
3.8
2.5 min.
2.2 min.
(8.1)
+0.1
φ0.9 0
2.5±0.05
2.5 min.
4.4
+0.1
φ0.9 0
(10.3)
4.2
2.5 min.
+0.1
φ0.9 0
±0.05
6.7 min.
2.5
±0.05
PC board layout and Assembly layout
Top entry type
Recognized E60389
Certified LR20812
R50082349
6.5
(8.6)
2
2.2 min.
H JST
Specifications
Note: 1
. The above figure is the figure viewed from soldering side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Hole dimension differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole
dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details.
Contact
Model No.
SEH-001T-P0.6
*SEH-001T-P0.6L
*SEH-002T-P0.6L
*SEH-003T-P0.6L
5.7
2.05
1.1
Insulation O.D.
(mm)
0.05 to 0.33
30 to 22
1.0 to 1.9
0.13 to 0.33
26 to 22
0.9 to 1.9
0.05 to 0.13
30 to 26
0.9 to 1.3
0.032 to 0.08
32 to 28
0.5 to 1.1
Q'ty/
reel
9,000
10,000
Material and Finish
2
2.85
Applicable wire
AWG #
mm2
Phosphor bronze, tin-plated (reflow treatment)
1.6
RoHS2 compliance
Note: 1. Contact JST for gold-plated products.
2. SEH-00( )T-P0.6L is low-insertion force type contact, for easier
insertion/withdrawal, which would be less resistant to the vibration.
The crimp height is different from the standard contact.
3. *Marked products are not TÜV approved.
4. Contact JST for details.
Contact
Crimping
machine Crimp applicator
SEH-001T-P0.6
SEH-001T-P0.6L
SEH-002T-P0.6L
SEH-003T-P0.6L
AP-K2N
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SEH-001-06
APLMK SEH001-06
MK/SEH-001-06L APLMK SEH001-06L
MK/SEH-002-06L APLMK SEH002-06L
MKS-L-10
MK/SEH-003-06L APLMK SEH003-06L
Note: Contact JST for fully automatic crimping applicator.
1
EH
EH CONNECTOR
CONNECTOR
Housing
エンボス
エンボス
No. of
circuits
2
3
B
4
5
A
0.6
2
3
6
6
3.8
7
8
9
7
10
11
12
6.5
H JST
(2.25) (2.5)
13
14
15
□0.7
Circuit No.1
Dimensions (mm)
A
B
Model No.
EHR-2
EHR-3
EHR-4
EHR-5
EHR-6
EHR-7
EHR-8
EHR-9
EHR-10
EHR-11
EHR-12
EHR-13
EHR-14
EHR-15
Q'ty/
bag
2.5
7.0
1,000
5.0
9.5
1,000
7.5
12.0
1,000
10.0
14.5
1,000
12.5
17.0
1,000
15.0
19.5
1,000
17.5
22.0
1,000
20.0
24.5
1,000
22.5
27.0
1,000
25.0
29.5
1,000
27.5
32.0
1,000
30.0
34.5
1,000
32.5
37.0
1,000
35.0
39.5
1,000
Material and Finish
PA 66, UL94V-0, natural (white)
RoHS2 compliance
Header
Top entry type
(2 circuits)
3.8
3.2
6
4
B
No. of
circuits
Circuit No.1
(2.5)
A
□0.64
3.8
5.1
4
2.5
□0.64
Circuit No.1 (2.5)
(1.6)
A
B
Side entry type
6.7
6
2.2
5.2
4
4.2
□0.64
2.5
Circuit No.1
(2.5)
A
B
2
Dimensions (mm)
A
B
Q'ty/box
Top entry Side entry
type
type
2
B2B-EH
S2B-EH
2.5
7.5
1,000
1,000
3
B3B-EH
S3B-EH
5.0
10.0
1,000
1,000
4
B4B-EH
S4B-EH
7.5
12.5
1,000
1,000
5
B5B-EH
S5B-EH
10.0
15.0
1,000
1,000
6
B6B-EH
S6B-EH
12.5
17.5
1,000
500
7
B7B-EH
S7B-EH
15.0
20.0
1,000
500
8
B8B-EH
S8B-EH
17.5
22.5
500
500
9
B9B-EH
S9B-EH
20.0
25.0
500
500
10
B10B-EH
S10B-EH
22.5
27.5
500
500
11
B11B-EH
S11B-EH
25.0
30.0
500
250
12
B12B-EH
S12B-EH
27.5
32.5
500
250
13
B13B-EH
S13B-EH
30.0
35.0
250
250
14
B14B-EH
S14B-EH
32.5
37.5
250
250
15
B15B-EH
S15B-EH
35.0
40.0
250
250
Material and Finish
3.2
6
(3 circuits or more)
(1.6)
Model No.
Top entry
Side entry
type
type
3.2
Post: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA 66, UL94V-0, natural (white)
RoHS2 compliance This product displays (LF)(SN) on a label.
EH CONNECTOR
EHコネクタ表4
Header
No. of
circuits
● EH-A header
(2 circuits)
3.8
B
B2B-EH-A
B3B-EH-A
B4B-EH-A
B5B-EH-A
B6B-EH-A
B7B-EH-A
B8B-EH-A
B9B-EH-A
B10B-EH-A
B11B-EH-A
B12B-EH-A
B13B-EH-A
B14B-EH-A
B15B-EH-A
2
4
3.3
6
3
5
3.2
6
7
Circuit No.1
(2.5)
A
□0.64
8
(1.6)
10
9
11
3.8
12
13
15
5.1
6
14
3.3
Dimensions (mm)
A
B
Model No.
Q'ty/box
2.5
7.5
1,000
5.0
10.0
1,000
7.5
12.5
1,000
10.0
15.0
1,000
12.5
17.5
1,000
15.0
20.0
1,000
17.5
22.5
500
20.0
25.0
500
22.5
27.5
500
25.0
30.0
500
27.5
32.5
500
30.0
35.0
250
32.5
37.5
250
35.0
40.0
250
Material and Finish
3.2
Circuit No.1
□0.64
2.5
(2.5)
(1.6)
A
B
EH/HRラジアル表1
Header on radial-tape
● TS type
7.5
2.5
4.4
2.2
(1)
TS type
B2B-EH-TS
B3B-EH-TS
B4B-EH-TS
B5B-EH-TS
B6B-EH-TS
B7B-EH-TS
B8B-EH-TS
2
4
φ 0.64
1.5
Model No.
No. of
circuits
3
5.4
6.5
(2 circuits)
Note: 1. The length of the post is different between the EH-A header
and the EH header.
2. The EH-A header has a post length of 3.3 mm on the header, and
it provides easy insertion operation when mating with socket.
5
6
7
8
Dimensions (mm) Q'ty/
box
A
B
TV4 type
B3B-EH-TV4
B4B-EH-TV4
B5B-EH-TV4
B6B-EH-TV4
B7B-EH-TV4
B8B-EH-TV4
1,400
5.0
10.0
1,400
7.5
12.5
700
10.0
15.0
700
12.5
17.5
700
15.0
20.0
700
17.5
22.5
700
Material and Finish
Pin/Post: Brass, copper-undercoated, tin-plated (reflow treatment)
(3 to 8 circuits)
A
4.4
2.5
2.2
Taping specifications
5.6
φ0.64
(1)
6.5
2.5
1.5
B
2 and 3 circuits: 12.7
4 to 8 circuits: 25.4
B
A
6.5
2.5
4.4
2.5
2 circuits: 5.1
3 to 8 circuits: 3.85
(φ0.7 )
2.8
φ4
2.2
□0.64
5.6
● TV4 type
18
9
6
φ 0.64
(φ0.7 )
2 circuits: 2.5
3 to 8 circuits: 5
12.7
Note: Conforms to JIC C 0806 of "Tape packaging of components with
unidirectional leads on continuous tapes".
3
EH
EH CONNECTOR
CONNECTOR
Packaging specifications
エンボス
エンボス
Package type
Distance between folds
Box size
D
H
TERMIN
ALS &
Distance between the end of the tape and
the first connector’s center line (either end)
CONN
ECTORS
Quantity
the first connector's center line (either end)
4
24 indexing holes per fold (304.8 mm)
316(W)×45(D)×330(H)mm
19.05 mm
1,400 pcs./box
700 pcs./box
Note: Products of different packaging specifications are also available.
W
Tail tape
2, 3 circuits
4 to 8 circuits
Flat pack (zigzag folded)
Leader tape
EH CONNECTOR
Model number allocation
Contact
Housing
S EH - 001 T - P 0.6
EH R - 2 -
Form: S…Strip form, B…Loose piece
Series name
Applicable wire range:
Normal type 001…AWG #30 to #22
Low insertion force type 001…AWG #26 to #22
Series name
002…AWG #30 to #26
Part name: Receptacle
003…AWG #32 to #28
Surface finish: T…Tin-plated (reflow treatment)
No. of circuits: 2 to 15
Material: P…Phosphor bronze
Color: None…Natural (White), K…Black, R…Red, TR…Tomato red,
E…Blue, Y…Yellow, L…Lemon yellow, M…Green, O…Orange,
Terminal size
N…Brown, PL…Purple, PK…Pink, H…Gray, LE…Light blue,
Type name: None…Normal type, N…Low insertion force type
Header
FY…Fluorescent yellow
Header
B 2 B - EH -
B 2 B - EH - A -
Shape of assembled product:
B…Top entry type, S…Side entry type
Shape of assembled product: B…Top entry type
Part name: Header
Series name
Part name: Header
Lead length: None…3.2 mm, 2.2…2.2 mm
N…Brown, P…Purple, PK…Pink, H…Gray, LE…Light blue,
Series name
Post length: A…3.3 mm
Color: None…Natural (White), K…Black, R…Red, E…Blue,
Y…Yellow, M…Green
Header (Pin/Post) on radial-tape
B 2 B - EH - T S Shape of assembled product: B…Top entry type
No. of circuits: 2 to 8
Part name: Header
Series name
Packaging style: T…Radial-taping
Taping Pin/Post specifications:
S…Whole post/pin has a round cross section
V4…Make the square post/pin partially round cross section
Color: None…Natural (White), K…Black, R…Red, E…Blue, Y…Yellow,
M…Green, N…Brown
5
