3P-SCS
3P-SCS
    JST
    P=5.8mm
    3P-SCS
3P-SCS 数据手册
CLUSTER SOCKET Three-pole socket for connecting cluster pins This three circuit connector is used to connect cluster pins (2.3 mm in diameter) to the leads of a motor hermetically sealed in a compressor of a refrigerator or a freezer. The contacts and housing are especially designed and made of high-quality materials for high heat resistance and superior durability. Standards –––––––––––––––––––––– 0 1 Recognized E60389 Certified LR20812 * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Contact Applicable wire mm2 AWG # Insulation O.D. (mm) Q´ty/ reel 0.5∼1.25 20∼16 1.9∼3.4 5,000 5 Model No. SCS-41T-2.3 Material and Finish 18 8.3 3 1.5 2.2 Phosphor bronze, tin-plated (reflow treatment) RoHS compliance 0.9 Forφ2.3mm pin Applicable wire mm2 AWG # Insulation O.D. (mm) Q´ty/ reel 0.5∼1.25 20∼16 1.9∼3.2 3,000 3.5 Model No. SCSN-41T-P2.3 SCSN-60T-P2.3 18.3 7.8 4.5 0.7 mm +0.7 mm∼1.05 mm +1.05 mm 3,000 1.8 1.7 Material and Finish 5.8 Phosphor bronze, tin-plated RoHS compliance Note: 1. SCSN-60T-P2.3 is for the use of one wire crimping. Contact JST for details of regarding applicable wires. 2. Before use, the performance of this socket must be tested with the wire that is to be used. One wire crimping 3.5 Contact Crimping machine Crimp applicator SCS-41T-2.3 16.5 5.8 7.8 1 6.2 SCSN-41T-P2.3 AP-K2N SCSN-60T-P2.3 Applicator Dies Crimp applicator with dies MK-L MK/SCS-41-23 APLMK SCS41-23 − − − MKS-L MK/SCSN-41-23 APLMK SCSN41-23 − − − MKS-L MK/SCSN-60-23 APLMK SCSN60-23 − − − CLUSTER SOCKET Housing Model No. 3P-SCS RoHS compliance Material and Finish Q'ty/bag Applicable contact Phenol, UL94V-1, black 500 SCS-41T-2.3 Material and Finish Q'ty/bag Applicable contact 500 SCSN-41T-P2.3 23.1 5.8 18.3 5.8 0.45 9.2 32.4 3-φ2.7 10.05 Model No. 31.6 10.05 22.8 17.6 5.8 5.8 9.3 PBT, UL94HB, natural (white) 3P-CSN PBT RoHS compliance 3-φ2.7 2
3P-SCS 价格&库存
很抱歉,暂时无法提供与“3P-SCS”相匹配的价格&库存,您可以联系我们找货
3P-SCS
    • 1+3.620721+0.46443
    • 10+2.8278610+0.36273
    • 50+2.2816750+0.29267
    • 100+1.91167100+0.24521
    • 500+1.83239500+0.23504
    • 1000+1.779531000+0.22826
    • 2000+1.753102000+0.22487
    库存:245
    3P-SCS
      • 500+1.11780
      库存:17000
      3P-SCS
        • 1000+1.18320
        库存:3708
        3P-SCS
          • 80+5.0078780+0.64236
          • 100+4.17323100+0.53530
          库存:196
