ELR-04V(P)
ELR-04V(P)
    JST
    JST (JAPAN SOLDERLESS TERMINALS) - ELR-04V(P) - Connector Housing, EL Series, Receptacle, 4 Ways, 4....
ELR-04V(P) 数据手册
EL CONNECTOR 4.5 mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications • Current rating: 10 A AC/DC • Voltage rating: 300 V AC/DC • Temperature range: -25℃ to +90℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 7 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 M Ω min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25 mm2 • Applicable panel thickness: 0.8 to 2.0 mm EL CONNECTOR * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. ELコネクタ表1 The contacts for the compact EL connector can be easily inserted into the connector housings. The plug housing and the receptacle housing can be smoothly mated even if they are mechanically distorted. Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. No. of circuits 2 3 4 6 9 12 15 #16 10 10 10 8 6 6 6 #18 6 6 6 5 4 4 4 ●E  asy insertion and secure installation of contacts ● A smooth connection even when pried during mating Standards ● Durable arm lock mechanism Recognized E60389 ● Two contact styles Certified LR20812 R75052 ● Interchangeability with ML connector ELコネクタ表4 ® ® Wire size (AWG) #20 #22 5 4 5 4 5 4 4 3 3 3 3 3 3 3 Current unit : A #24 4 4 4 3 2 2 2 #26 3 3 3 3 2 2 2 ® ® ® Panel layout and Assembly layout A 39.2 ELコネクタ表3 B C D A No. of circuits Dimensions A (mm) 2~4 (Single-line arrangement) 10.4 4 (Double-line arrangement) 15.0 6 14.9 9~15 19.4 No. of Receptacle housing Panel hole dimensions (mm) General tolerance ±0.13 Applicable panel circuits Model No. thickness (mm) A B C D 2 15.0 6.0 6.85 5.2 ELR-02V 3 19.7 6.0 6.85 5.2 ELR-03V 24.2 6.0 6.85 5.2 ELR-04V 4 15.6 10.6 11.6 5.2 ELR-04NV 0.8~2.0 6 19.7 10.2 11.1 5.2 ELR-06V 9 19.7 14.8 15.7 5.2 ELR-09V 12 24.2 14.8 15.7 5.2 ELR-12V 15 28.7 14.8 15.7 5.2 ELR-15V Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 EL CONNECTOR ELコネクタ表2 Contact Applicable wire Model No. 1.3 Pin contact 17.7 7.5 4.3 2.0 3.8 Insulation O.D. Q’ty/reel (mm) Pin contact Socket contact mm2 AWG # SLM-01T-P1.3E SLF-01T-P1.3E 0.13~0.5 26~20 1.3~2.7 SLM-41T-P1.3E SLF-41T-P1.3E 0.5~1.25 20~16 1.9~3.4 *SLM-42T-P1.3E *SLF-42T-P1.3E 0.3+0.3~ 0.5+0.5 22+22~ 20+20 1.7+1.7~ 2.0+2.0 6,000 4,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Note: 1 . Contact denoted by * is used for two wires. 2. Contact JST for special products. 3. Contact JST for brass products. Socket contact SLM-01T-P1.3E 11.3 2.0 SLM-42T-P1.3E 4.3 SLF-42T-P1.3E Dies Crimp applicator with dies MK/SLF/M-01-13E APLMK SLF/M01-13E SLF-01T-P1.3E 17.7 Applicator Crimping machine Crimp applicator Contact AP-K2N MK/SLF/M-42-13E APLMK SLF/M42-13E MKS-L SLM-41T-P1.3E MK/SLF/M-41-13E APLMK SLF/M41-13E SLF-41T-P1.3E Note: Contact JST for fully automatic crimping applicator. Contact position location numbers Contact position numbers are stamped Receptacle housing Plug housing 15 4 3 2 4 1 3 5 2 1 4 4 3 2 1 1 1 3 2 1 3 3 1 3 1 2 1 2 2 1 1 3 4 2 3 1 2 2 4 4 3 2 1 4 2 1 3 2 1 3 2 2 1 Plug housing 2 Receptacle housing 12 14 4 4 8 9 3 6 10 3 10 5 15 4 9 11 6 3 4 14 13 5 9 3 7 8 5 3 13 2 12 2 6 7 1 1 4 8 2 9 4 2 12 1 5 7 1 9 4 11 6 1 1 10 5 7 7 2 10 8 7 11 8 1 8 12 9 2 4 6 3 5 3 6 6 1 11 5 6 6 3 5 2 4 1 2 9 6 3 8 5 2 7 4 1 12 11 10 9 8 7 6 5 4 3 2 1 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 3 6 2 5 1 4 3 6 9 2 5 8 1 4 7 4 3 2 1 8 7 6 5 12 11 10 9 5 4 3 2 1 10 9 8 7 6 15 14 13 12 11 EL CONNECTOR P272 Housing No. of circuits Voltage rating Material: PA 6, UL94V-0, white Current rating Receptacle housing (for pin contact) Plug housing (for socket contact) Q’ty/ bag ELP-02V Q’ty/ bag 10.3 ELR-02V 500 300 V 10 A ELR-02VF Q’ty/ bag 10.3 2 5.6 10.3 24.6 24.6 5.8 ELR-03V 10 A 500 500 Q’ty/ bag ELP-03V Q’ty/ bag 14.8 300 V 14.6 24.6 14.8 3 5.8 500 24.6 24.6 5.6 ELR-04V 500 14.6 5.8 ELP-04V Q’ty/ bag 19.3 19.3 Q’ty/ bag 500 24.6 JST-L 10 A 24.6 Q’ty/ bag ELP-04NV Q’ty/ bag 10.3 300 V 14.6 5.6 ELR-04NV 4 500 5.8 10.3 10.3 24.6 ELR-04NVF 10.3 500 14.6 500 10.3 24.6 24.6 10.3 ELR-06V 8A Q’ty/ bag 14.8 300 V ELP-06V 14.8 6 Q’ty/ bag 500 24.6 9.9 10.3 14.6 500 24.6 RoHS2 compliance 3 EL CONNECTOR P274 Housing No. of circuits Voltage rating Material: PA 6, UL94V-0, white Current rating Receptacle housing (for pin contact) ELR-09V 6A 500 24.6 24.6 Q’ty/ bag ELP-12V 500 24.6 24.6 Q’ty/ bag ELP-15V Q’ty/ bag 500 500 14.8 24.6 14.4 14.6 24.6 RoHS2 compliance Note: 1  . ELR-02VF and ELR-04NVF are exclusively for free hanging. The other circuits can be used either for panel mounted or free hanging. See "Panel layout" for the panel hole dimensions. 2. Contact JST for special products. 4 500 14.6 23.8 6A 14.8 23.8 300 V Q’ty/ bag 14.4 ELR-15V 15 500 14.6 19.3 6A 14.8 19.3 300 V Q’ty/ bag 14.4 ELR-12V 12 ELP-09V 14.8 300 V Q’ty/ bag 14.8 9 Plug housing (for socket contact) P2
ELR-04V(P) 价格&库存
很抱歉,暂时无法提供与“ELR-04V(P)”相匹配的价格&库存,您可以联系我们找货
ELR-04V(P)
    • 1+1.152361+0.14916
    • 10+1.0825210+0.14012
    • 50+0.7245950+0.09379
    • 100+0.65475100+0.08475
    • 500+0.60237500+0.07797
    • 1000+0.576181000+0.07458
    • 2000+0.558722000+0.07232
    库存:225
