734-233
734-233
    WAGO(万可电子)
    插件,P=3.81mm
    接线端子 1x3P 间距:3.81mm 排数:1 每排Pin数:3
734-233 数据手册
Data sheet  |  Item number: 734-233 THT male header; 1.0 x 1.0 mm solder pin; straight; 100% protected against mismating; Pin spacing 3.81 mm; 3-pole; orange www.wago.com/734-233 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/7 Data sheet  |  Item number: 734-233 www.wago.com/734-233 L = (pole no. – 1) x pin spacing + 5.9 mm Item description Horizontal or vertical PCB mounting via straight or angled solder pins 100 % protected against mismating; only mating halves with the same number of poles can be connected together Coding via coding fingers Safety information 1: The MULTI CONNECTION SYSTEM (MCS) is designed without breaking capacity for compliance with DIN EN 61984. When used as intended, MCS Connectors shall not be connected/disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 160 V Rated impulse voltage (III / 3) 2.5 kV Rated voltage (III / 2) 160 V Rated impulse voltage (III / 2) 2.5 kV Rated voltage (II / 2) 320 V Rated impulse voltage (II / 2) Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 2.5 kV Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/7 Data sheet  |  Item number: 734-233 www.wago.com/734-233 Rated impulse voltage (II / 2) 2.5 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Connection data No. of poles 3 Total number of potentials 3 Number of connection types 1 Number of levels 1 Geometrical Data Pin spacing 3.81 mm / 0.15 inch Width 13.52 mm / 0.532 inch Height 14.8 mm / 0.583 inch Height from the surface 10.3 mm / 0.406 inch Depth 8.5 mm / 0.335 inch Solder pin length 4.5 mm Solder pin dimensions 1 x 1 mm Drilled hole diameter (tolerance) 1.4(- … +0.1) mm Plug connection Contact type (pluggable connector) Male connector/plug Connector connection type for PCBs Mismating protection Yes Mating direction to the PCB Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 90 ° Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/7 Data sheet  |  Item number: 734-233 www.wago.com/734-233 Mating direction to the PCB 90 ° PCB contact PCB contact THT Solder pin arrangement over the entire male connector, in line Number of solder pins per potential 1 Material Data Color orange Material group I Insulating material Polyamide 66 (PA 66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.015 MJ Weight 0.8 g Environmental Requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) Packaging type BOX Country of origin DE GTIN 4044918847841 Customs Tariff No. 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. EN 61984 NL-54190 KEMA/KEUR DEKRA Certification B.V. EN 61984 71105522 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/7 Data sheet  |  Item number: 734-233 www.wago.com/734-233 Ship Approvals Logo Approval Additional Approval Text Certificate name DNV GL Det Norske Veritas, Germanischer Lloyd - TAE000016Z LR Lloyds Register IEC 61984 96/20035 (E5) UL-Approvals Logo Approval Additional Approval Text UL Underwriters Laboratories Inc. UL 1977 Certificate name 20150318E45171 Compatible products Coding Item no.: 734-130 Coding key; to be snapped above top level; white www.wago.com/734-130 Item no.: 734-159 Coding key; to be snapped above top level; black www.wago.com/734-159 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 3.6 MB Download URL Download CAD/CAE-Data CAD data 2D/3D Models 734-233 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/7 Data sheet  |  Item number: 734-233 www.wago.com/734-233 CAE data EPLAN Data Portal 734-233 Download PCB Design Symbol and Footprint 734-233 URL Download CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Installation Notes Coding Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/7 Data sheet  |  Item number: 734-233 www.wago.com/734-233 Coding a male header – fitting coding key(s). Product family MCS MINI Show all products from the family Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/7
734-233 价格&库存
很抱歉,暂时无法提供与“734-233”相匹配的价格&库存,您可以联系我们找货
    • 1+2.43760
    • 200+2.31550
    • 400+2.20000
    库存:200
    734-233
    • 1+4.22676
    • 30+4.08101
    • 100+3.78951
    • 500+3.49801
    • 1000+3.35226
