734-142
734-142
    WAGO(万可电子)
    插件,P=3.5mm
    接线端子 间距:3.50mm 1x12P 直插
734-142 数据手册
HEADER STRAIGHT SOLDER PIN, 1X1 MM / 0.039X 0.039 IN PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING PDF Datasheet © 1992 - 2011 CADENAS GmbH HEADER STRAIGHT SOLDER PIN, 1X1 MM / 0.039X 0.039 IN PIN SPACING 3.5 MM / 0.138 IN 100% PROTECTED AGAINST MISMATING 734-132 TO 734-154 ITEM-NO. (ITEM-NO.) 734-142 Measured voltage (Measured voltage / V) 160 PDF Datasheet © 1992 - 2011 CADENAS GmbH Measured shock voltage (Measured shock voltage / kV) 2.5 Pollution degree (Pollution degree) 2 Current intensity (Current intensity / A) 10 RM (PIN SPACING / mm) 3.5 P (NO. OF POLES) 12 Height (Height / mm) 10.3 Width (Width / mm) 44.4 Depth (Depth / mm) 8.5 COLOR (COLOR) lichtgrau Comment (Comment) L = (No. of poles - 1) x Pin Spacing + 5,9 mm Dimensions (Dimensions) 1,4 +0,1 mm
734-142 价格&库存
很抱歉,暂时无法提供与“734-142”相匹配的价格&库存,您可以联系我们找货
  • 2+60.428592+7.84056
  • 10+52.0743310+6.75660
  • 100+33.06557100+4.29023
  • 500+30.20300500+3.91882
  • 1000+29.278771000+3.79890
库存:100
734-142
    • 1+3440.41935
    库存:100
    734-142
    • 15+53.1178615+6.89200
    • 100+33.71675100+4.37472
    • 500+30.80748500+3.99725
    • 1000+29.865511000+3.87503
    库存:100
    734-142
    • 10+91.1798910+11.83052
    库存:10
