DF13-4P-1.25V
DF13-4P-1.25V
    HRS(广濑)
    HIROSE(HRS) - DF13-4P-1.25V - Pin Header, Wire-to-Board, 1.25 mm, 1 Rows, 4 Contacts, Surface Mount,...
DF13-4P-1.25V 数据手册
1.25mm Pitch Miniature Crimping Connector DF13 Series Right Angle Type Straight Type Type ■Features 1. Miniature Size Designed in the low profile at mounting height 5.8mm. (SMT mounting straight type) (For DIP type, the mounting height is to 5.3mm to the straight and 3.6mm at the right angle) Mounting Height(h) Mounting Type DIP 5.3mm SMT 5.8mm DIP 3.6mm SMT Correspond to Automatic Mounting Secure the automatic plain area for the absorption type automatic mounting machine. Straight Type Absorption area 2. Multi-contact The double row type achieves the multi-contact up to 40 contacts, and secures 30% higher density in the mounting area, compared with the single row type. 3. Correspond to Automatic Mounting The header provides the grade with the vacuum absorption area, and secures automatic mounting by the embossed tape packaging. In addition, the tube packaging can be selected. 4. Integral Basic Function Despite Miniature Size The header is designed in a scoop-proof box structure, and completely prevents mis-insertion. In addition, the surface mounting (SMT) header is equipped with the metal fitting to prevent solder peeling. Metal fitting Right Angle Type Absorption area ■Applications Note PC, mobile terminal, miniature type business equipment, and other various consumer equipment, including video camera Figure 1 B242 DF13 Series●1.25mm Pitch Miniature Crimping Connector ■Product Specifications Operating Temperature Range: -35 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2) Current rating 1A Rating Voltage rating 150V AC Operating Moisture Range: 20 to 80% Storage Moisture Range: 40 to 70% Specification Condition Item 1.Insulation Resistance 500M ohms min. 100V DC 2.Withstanding voltage No flashover or insulation breakdown. 500V AC/1 minute 3.Contact Resistance 30m ohms max. 100mA (Note 2) 4.Single Insertion/Extraction Force 0.3N (30gf) min., 3N (300gf) max. Measured at the square steel pin of 0.35±0.002mm 5.Vibration Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. No electrical discontinuity of 1µs or more 6.Humidity (Steady state) Contact resistance: 30m ohms max. Insulation resistance: 500M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 7.Temperature Cycle (-55ç: 30 minutes➝ 5 to 35ç: 10 minutes➝ 85ç: 30 minutes➝ 5 to 35ç: 10 minutes) 5 cycles Contact resistance: 30m ohms max. Insulation resistance: 500M ohms min. 8.Durability (Mating/un-mating) Contact resistance: 30m ohms max. Tin plating: 30 cycles Gold plating: 50 cycles 9.Resistance to Soldering heat No deformation of components affecting performance. Flow: 250ç for 10 seconds Manual soldering: 300ç for 3 seconds Reflow: At the recommended temperature profile Manual soldering: 300ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material Product Part Material Finish Remarks Crimping Socket Insulator Polyamide Beige UL94V-0 Contact Phosphor copper Tin plated or gold plated - Insulator Polyamide Beige UL94V-0 Contact Brass Tin plated - Insulator Polyamide Beige UL94V-0 Crimping Contact for Socket Pin Header (Through hole) Pin Header (SMT Single row) Contact Brass Tin plated or gold plated - Metal Fitting Phosphor copper Tin plated - Insulator Polyamide Beige UL94V-0 Contact Brass Tin-copper plated or gold plated - Metal Fitting Phosphor copper Tin plated - Pin Header (SMT Double row) ■Ordering Information ●Connector DF13 q # - * S - 1.25 C w e r t y q Series Name : DF13 e Number of Contacts t Contact Pitch: 1.25mm w Style Symbol : Blank: With boss r Single row: 2 to 12, 14, 15 y Connection Form / Contact Style. A: Without boss r Double row: 10, 20, 30, 40 V Type C : Crimping socket / DSA : Straight through hole B: With boss, embossed tape type r Connector Type DS : Right angle through hole / V : Straight SMT C: Without boss, embossed tape type t S: Single row socket / P: Single row pin header H : Right angle SMT t DS: Double row socket / DP: Double row pin header ●Contact DF13 # - 2630 SCF A q w e r q Style Symbol Blank: Standard e Packaging Type SCF: Socket Contact/Reel G: Low insertion / extraction r Plating Type w Applicable Cable Size 2630: AWG26 to 30 Blank: Tin plated A : Gold plated 3032: AWG30 to 32 B243 DF13 Series●1.25mm Pitch Miniature Crimping Connector ■Single Row Socket Photo: Contact insertion Number of Contacts Part Number CL No. 536-0001-4 DF13-2S-1.25C 2 536-0002-7 DF13-3S-1.25C 3 536-0003-0 DF13-4S-1.25C 4 536-0004-2 DF13-5S-1.25C 5 536-0005-5 DF13-6S-1.25C 6 536-0006-8 DF13-7S-1.25C 7 536-0007-0 DF13-8S-1.25C 8 Note 1.The quantity is delivered per bag (100 A B RoHS Part Number 1.25 4.15 DF13- 9S-1.25C 2.50 5.40 DF13-10S-1.25C 3.75 6.65 DF13-11S-1.25C Yes 5.00 7.90 DF13-12S-1.25C 6.25 9.15 DF13-13S-1.25C 7.50 10.40 DF13-14S-1.25C 8.75 11.65 DF13-15S-1.25C pcs.). If needed, please select and order Number of Contacts CL No. 536-0008-3 9 536-0009-6 10 536-0010-5 11 536-0011-8 12 536-0012-0 13 536-0013-3 14 536-0014-6 15 the products per bag. ■Double Row Socket Photo: Contact insertion state Part Number DF13-10DS-1.25C DF13-20DS-1.25C DF13-30DS-1.25C DF13-40DS-1.25C Note:The quantity B244 Unit: mm Number of Contacts CL No. A B RoHS 536-0550-2 10 10.40 5.00 536-0555-6 20 16.65 11.25 Yes 536-0560-6 30 22.90 17.50 536-0565-0 40 29.15 23.75 is delivered per bag (100pcs). If needed, please select and order the products per bag. A 10.00 11.25 12.50 13.75 15.00 16.25 17.50 Unit: mm B RoHS 12.90 14.15 15.40 16.65 Yes 17.90 19.15 20.40 DF13 Series●1.25mm Pitch Miniature Crimping Connector ■Single Row Straight Pin Header (Through hole) [Specific No.] – **, (**) Blank: Tin plated 20: Tin plated, tube packaging BTube Dimensions 10 5 ●Board Through-hole Diameter:Ø0.6±0.03 Part Number CL No. Number of Contacts A B Tube Packaging Quantity RoHS Part Number CL No. Number of Contacts 115 DF13-2P-1.25DSA(**) 536-0101-9-** 2 1.25 4.15 DF13- 9P-1.25DSA(**) 536-0108-8-** 9 89 DF13-3P-1.25DSA(**) 536-0102-1-** 3 2.50 5.40 DF13-10P-1.25DSA(**) 536-0109-0-** 10 72 DF13-4P-1.25DSA(**) 536-0103-4-** 4 3.75 6.65 DF13-11P-1.25DSA(**) 536-0110-0-** 11 61 Yes DF13-12P-1.25DSA(**) 536-0111-2-** DF13-5P-1.25DSA(**) 536-0104-7-** 5 5.00 7.90 12 52 DF13-6P-1.25DSA(**) 536-0105-0-** 6 6.25 9.15 DF13-13P-1.25DSA(**) 536-0112-5-** 13 46 DF13-7P-1.25DSA(**) 536-0106-2-** 7 7.50 10.40 DF13-14P-1.25DSA(**) 536-0113-8-** 14 41 DF13-8P-1.25DSA(**) 536-0107-5-** 8 8.75 11.65 DF13-15P-1.25DSA(**) 536-0114-0-** 15 Note 1.The quantity at the specific No."None" is delivered per bag (100 pcs.). If needed, please select and Note 2.Order the tube packaging product, multiplying the tube packaging quantity. Unit: mm A B Tube Packaging Quantity RoHS 37 10.00 12.90 34 11.25 14.15 31 12.50 15.40 29 Yes 13.75 16.65 27 15.00 17.90 25 16.25 19.15 23 17.50 20.40 order the products per bag. ■Single Row Right Angle Pin Header (Through hole) [Specific No.] – **, (***) (20): Tin plated tube packaging BTube Dimensions ●Board Through-hole Diameter:Ø0.6±0.03 Part Number CL No. Number of Contacts A B Tube Packaging Quantity RoHS Part Number 2 1.25 4.15 115 DF13-2P-1.25DS(20) 536-0151-7-20 DF13- 9P-1.25DS(20) 3 2.50 5.40 89 DF13-3P-1.25DS(20) 536-0152-0-20 DF13-10P-1.25DS(20) 4 3.75 6.65 72 DF13-4P-1.25DS(20) 536-0153-2-20 DF13-11P-1.25DS(20) Yes DF13-12P-1.25DS(20) 5 5.00 7.90 61 DF13-5P-1.25DS(20) 536-0154-5-20 6 6.25 9.15 52 DF13-6P-1.25DS(20) 536-0155-8-20 DF13-14P-1.25DS(20) 7 7.50 10.40 46 DF13-7P-1.25DS(20) 536-0156-0-20 DF13-15P-1.25DS(20) 8 8.75 11.65 41 DF13-8P-1.25DS(20) 536-0157-3-20 Note 1.Order the tube packaging product, multiplying the tube packaging quantity. CL No. Number of Contacts 9 536-0158-6-20 10 536-0159-9-20 11 536-0160-8-20 12 536-0161-0-20 14 536-0163-6-20 15 536-0164-9-20 Unit: mm A B Tube Packaging Quantity RoHS 10.00 12.90 37 11.25 14.15 34 12.50 15.40 31 Yes 13.75 16.65 29 16.25 19.15 25 17.50 20.40 23 B245 DF13 Series●1.25mm Pitch Miniature Crimping Connector ■Single Row Straight Pin Header (SMT) ■(Three-Wall/Correspond to Vacuum Absorption) 1.8 BPCB mounting pattern Note 1.Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. This pin header is a three-wall type, header has sufficiently large flat areas to allow pick-up with vacuum nozzles of automatic placement equipment. [Specific No.] – **, (**) (21): Tin plated embossed tape packaging (51): Gold plated embossed tape packaging Unit: mm Part Number CL No. Number of Contacts A 1.25 2 536-0401-2-** DF13C- 2P-1.25V(**) 2.50 3 536-0402-5-** DF13C- 3P-1.25V(**) 3.75 4 536-0403-8-** DF13C- 4P-1.25V(**) 5.00 5 536-0404-0-** DF13C- 5P-1.25V(**) 6.25 6 536-0405-3-** DF13C- 6P-1.25V(**) 7.50 7 536-0406-6-** DF13C- 7P-1.25V(**) 8.75 8 536-0407-9-** DF13C- 8P-1.25V(**) 10.00 9 536-0408-1-** DF13C- 9P-1.25V(**) 11.25 10 536-0409-4-** DF13C-10P-1.25V(**) 12.50 11 536-0410-3-** DF13C-11P-1.25V(**) 13.75 12 536-0411-6-** DF13C-12P-1.25V(**) 16.25 14 536-0413-1-** DF13C-14P-1.25V(**) 17.50 15 536-0414-4-** DF13C-15P-1.25V(**) Note 1.Please order the embossed tape packaging product according B246 B C D E F 4.15 5.40 6.65 7.90 9.15 10.40 11.65 12.90 14.15 15.40 16.65 19.15 20.40 7.15 8.40 9.65 10.90 12.15 13.40 14.65 15.90 17.15 18.40 19.65 22.15 23.40 5.65 6.90 8.15 9.40 10.65 11.90 13.15 14.40 15.65 16.90 18.15 20.65 21.90 1.95 3.20 4.45 5.70 6.95 8.20 9.45 10.70 11.95 13.20 14.45 16.95 18.20 2.20 3.45 3.10 4.35 5.60 6.85 8.10 9.35 10.60 11.85 13.10 15.60 16.85 to reel number. (1000 pcs. per reel) Emboss Width 16 16 24 24 24 24 24 24 24 32 32 32 44 RoHS Yes DF13 Series●1.25mm Pitch Miniature Crimping Connector ■Single Row Straight Pin Header (SMT) ■(Four-Wall/Correspond to Vacuum Absorption) 1.8 BPCB mounting pattern [Specific No.] – **, (**) (21): Tin plated embossed tape packaging (51): Gold plated embossed tape packaging Unit: mm Part Number CL No. Number of Contacts A 1.25 2 CL536-0301-8-** DF13A- 2P-1.25H(**) 2.50 3 CL536-0302-0-** DF13A- 3P-1.25H(**) 3.75 4 CL536-0303-3-** DF13A- 4P-1.25H(**) 5.00 5 CL536-0304-6-** DF13A- 5P-1.25H(**) 6.25 6 CL536-0305-9-** DF13A- 6P-1.25H(**) 7.50 7 CL536-0306-1-** DF13A- 7P-1.25H(**) 8.75 CL536-0307-4-** 8 DF13A- 8P-1.25H(**) 10.00 9 CL536-0308-7-** DF13A- 9P-1.25H(**) 11.25 10 CL536-0309-0-** DF13A-10P-1.25H(**) 12.50 11 CL536-0310-9-** DF13A-11P-1.25H(**) 13.75 12 CL536-0311-1-** DF13A-12P-1.25H(**) 16.25 14 CL536-0313-7-** DF13A-14P-1.25H(**) 17.50 15 CL536-0314-0-** DF13A-15P-1.25H(**) Note 1.Please order the embossed tape packaging product according B 4.15 5.40 6.65 7.90 9.15 10.40 11.65 12.90 14.15 15.40 16.65 19.15 20.40 to reel C D Emboss Width RoHS 7.15 5.65 16 8.40 6.90 16 9.65 8.15 24 10.90 9.40 24 12.15 10.65 24 13.40 11.90 24 14.65 13.15 24 Yes 15.90 14.40 24 17.15 15.65 24 18.40 16.90 32 19.65 18.15 32 22.15 20.65 32 23.40 21.90 44 number. (1000 pcs. per reel) B247 DF13 Series●1.25mm Pitch Miniature Crimping Connector ■Double Row Straight Pin Header (SMT) ■(Four-Wall/Correspond to Vacuum Absorption) BPCB mounting pattern Note 1.Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. [Specific No.] - **, (**) (95): Tin-copper plated embossed tape packaging (91): Gold plated embossed tape packaging Unit: mm Spec No. Spec No. Emboss Number of A B C 10 12.10 5.00 536-0605-2-** DF13A-30DP-1.25V(**) DF13A-40DP-1.25V(**) Part Number CL No. DF13A-10DP-1.25V(**) 536-0600-9-** DF13A-20DP-1.25V(**) Contacts (26) (56) Width 8.70 K K 24 20 18.35 11.25 14.95 K K 32 536-0610-2-** 30 24.60 17.50 21.20 – K 44 536-0615-6-** 40 30.85 23.75 27.45 – K 44 Note 1.Please order the tube packaging product, multiplying the tube packaging quantity. Note 2.Please order the embossed tape packaging product according to reel number. (1 reel: 1000 pcs.) Note 3.The absorption cap is attached to the embossed tape packaging product. B248 RoHS Yes DF13 Series●1.25mm Pitch Miniature Crimping Connector ■Crimping Contact Part Number DF13-3032SCF DF13-3032SCFA(04) DF13-2630SCF DF13-2630SCFA(04) DF13G-2630SCF DF13G-2630SCFA KDF13 CL No. Packaging Type 536-0299-8 536-0641-6-04 Reel 536-0300-5 536-0298-5-04 Reel 536-0643-1 536-0642-9 (Low insertion/extraction) Quantity 10,000 10,000 Finish Tin plating Gold plating Tin plating Gold plating Tin plating Gold plating ●Applicable Cable (Tin Plating Annealed Copper Wire) Conductor Size (Wire construction) Jacket Diameter AWG26(7 cores./0.16mm) AWG28(7 cores./0.127mm) Ø0.65 to Ø1.0mm AWG30(7 cores./0.1mm) AWG32(7 cores./0.08mm) Note:If other cables are used instead of the applicable cable, please contact the Hirose sales department. ●Recommended Cable KDF13G UL1571, UL1061 1 0.8 1.5 BApplicable Crimping Tool Part Number CL No. AP105-DF13-2630S 901-4531-9 AP105-DF13-3032S Press Main Unit CM-105 Manual Crimping Tool DF13-TB2630HC 901-4552-9 901-0005-4 550-0256-1 0.9 3.7 3.3 2 Applicator 0.5 1.2 to 1.9mm 0.15 Type 7.2 ●Strip Length Extraction Tool DF-C-PO(B) 550-0179-2 Applicable Contact DF13-2630SCF/SCFA DF13G-2630SCF/SCFA DF13-3032SCF/SCFA --------------DF13-2630SCF DF13-2630SCF/SCFA DF13G-2630SCF/SCFA DF13-3032SCF/SCFA Note 1.If a trouble has occurred due to other tools, which are not designated by Hirose, Hirose won't guarantee any product. Note 2.The manual crimping tool is used to sequentially cut the reel contact with carrier. BApplication Pattern Through hole (Single Row Product) SMT (Double Row Product) Straight Right Angle SMT (Single Row Product) B249 DF13 Series●1.25mm Pitch Miniature Crimping Connector BEmbossed Carrier Tape Dimensions KDF13B-*P-1.25V With boss KDF13C-*P-1.25V Without boss KDF13-*P-1.25H KDF13A-*P-1.25H Unit: mm Product Type DF13B-*P-1.25V DF13C-*P-1.25V DF13-*P-1.25H DF13A-*P-1.25H Note:The 13 contacts is not serialized. B250 Number of Contacts A B C D 2, 3 16 ––––––– 7.5 16.4 4 to 10 24 ––––––– 11.5 24.4 11 to 14 32 28.4 14.2 32.4 15 44 40.4 20.2 44.4 DF13 Series●1.25mm Pitch Miniature Crimping Connector BPrecautions 1. Recommended Temperature Profile (SMT) ■ DF13A-*P-1.25H ■ DF13C-*P-1.25V Temperature 10s max. 250ç Max. 230 200ç 60s max. Soldering 180±10 150ç 60 to 120s Preheating 100ç Time ■ DF13A-*DP-1.25V Note 1.Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2.The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. Note 3.Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. 2. Recommended Soldering Condition (SMT) 3. Recommended Screen Manual soldering: 290±10ç for 2 seconds max. 0.15 to 0.2mm Thickness (SMT) 4. Board Warpage (SMT) Max 0.03mm in the connector center area, based on both connector edges 5. Recommended Soldering Flow: 250±5ç for 3 seconds 5. Condition (Through hole) Manual soldering: 290±10ç for 2 seconds 6. Cleaning Condition Refer to Nylon Connector Use Hand book. 7. Connection Condition Refer to Nylon Connector Use Hand book. ■Carefully carry out the crimping operation according to "Crimping Condition Sheet" and "Crimping Quality Standard", because the crimping contact is an extremely small style. 8. Cautions ■Be careful for the excessive scoop insertion/extraction, which will cause damage to the product. 9. Precautions Refer to Nylon Connector Use Hand book. B251 DF13 Series●1.25mm Pitch Miniature Crimping Connector BPrecautions Align with the connector form and press down continue pressing until there is a tactile click. Handing Align with the connector form and press down continue pressing until there is a tactile click. Handing Method: Lightly grasping the base the cable, press the connector with your finger and insert it. Insertion Angle Method: Grasp the cable so that the entire cable is pulled evenly and it out. Angle of Removal Caution: Do not insert at an angle of 30° or greater. Doing so will cause contact deformation or case damage. Method: Insert with the connector parallel. B252 Caution: Do not remove at an angle of 30° or greater. Doing so will cause contact deformation or case damage. Method: Remove with the connector parallel. Parallel Diagonal Parallel Diagonal Parallel Diagonal Parallel Diagonal
DF13-4P-1.25V 价格&库存
很抱歉,暂时无法提供与“DF13-4P-1.25V”相匹配的价格&库存,您可以联系我们找货
