FH53M-7S-0.25SHW(99)
    HRS(广濑)
    SMD,P=0.25mm,卧贴(交错脚)
    FPC/FFC连接器 间距:0.25mm 7Pin 卧贴
FH53M-7S-0.25SHW(99) 数据手册
ITS-P-12018FH_1.1 FH53/FH53M Series Powered by TCPDF (www.tcpdf.org) 0.2 mm Pitch High Density FPC Connector  Features 1. Reduced mounting space by narrow pitch(FH53: 0.2mm/FH53M: 0.25mm,0.3mm) 2. 3.2 2 Short depth: 3 2 mm (locked position) 3. FPC thickness at contact area: 0.12  0.02 mm (top contact) 4. Multi-functional chucking metal for FPC temporary holding and improved connection reliability 5. Movable lock metal allows horizontal FPC insertion/withdrawal *This product satisfies halogen free requirements 6. Wide tapers for smooth FPC insertion defined as 900 ppm maximum chlorine, 900 ppm maximum bromine, and 1500 ppm maximum total 7 Solder wicking and flux penetration prevention 7. off chlorine and bromine. 8. Board area under the connector is available for PCB patterning 9. Outer lead design for visual check 10. RoHS compliant, halogen-free product* 0.65 mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.2/0.25/0.3mm Pitch, 0.65 mm Height, Top Contact, Back Flip FPC Connector  Dimensions (41 pos.) Pitch/Mounting pitch: FH53 : 0.2mm / 0.4mm FH53M(0.25mm) : 0.25mm / 0.5mm FH53M(0.3mm) : 0.3mm / 0.6mm FPC thickness:0.12mm Light weight:0.034g  Chucking metals provide multi-functions in addition to metal hold down. [During FPC Insertion/withdrawal] Chucking Metal Movable chucking metal allows tabbed FPC in back flip design. FPC Tab [FPC in Place] FPC Insertion Support & Temporary Hold Clear tactile click by inserting FPC [Locked Condition] - Clear tactile click completes correct FPC positioning and prevents FPC mis-insertion. - Provides FPC temporary hold before locking operation. High FPC Retention Force Chucking metal closes along with the lock operation and firmly holds the FPC tab. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. Issued: Sep. 28, 2017
FH53M-7S-0.25SHW(99) 价格&库存
很抱歉,暂时无法提供与“FH53M-7S-0.25SHW(99)”相匹配的价格&库存,您可以联系我们找货
