FX2B-68SA-1.27R(4件套)
    HRS(广濑)
    P=1.27mm
    特性:多种产品线的各种连接方式。带状电缆连接类型,可单手轻松一键操作。直通孔类型在浸焊时从电路板背面采取完全防焊剂膨胀措施,有是否需要清洗的对应类型。板堆叠高度可在 12mm 至 16mm 之间以 1...
FX2B-68SA-1.27R(4件套) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 1.27mm Pitch Multi-function Two Piece Connector FX2 Series Stacking connection (Stack height: 12~16mm) 12mm~16mm Horizontal Connection Vertical Connection 25mm ■Features 1. Various connection with various product line 2. Easy One-Touch Operation The ribbon cable connection type allows easy one-touch operation with either single hand. Stacking connection Vertical type Cable connection Through hole type SMT type Through hole type SMT type Insersion and Extraction qPick internal locks with thumb and the index finger. Through hole type SMT type Through hole type Cable only Horizontal type SMT type wWith unique and preferable click feeling, the cable and connector can be inserted or withdrawed. Vertical type Through hole type SMT type Cable only Cable connection (For insertion, the operation proceeds from procedure (2) to (1).) A142 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 3. Board to board type 4. Board to cable type q Flux swell prevention q Complete lock with easy operation The straight through hole type takes the complete flux tight action from the board back side at solder dipping. The type is prepared, corresponding to whether or not cleaning is required. Employing the inner lock system, complete lock and eject actions can be performed with easy operation. w Applicable cable The applicable cable is the AWG#28 flat cable (7/0.127mm), and the jacket size is 0.9±0.1mm. w Stack height 12mm to 16mm The board stack height can be set to every 1 mm unit up to 12 to 16mm. 5. SMT type Strength security with metaltab e Mis-insertion preventive mechanism The mating area is designed in a mechanism so as to prevent mis-insertion, and complete countermeasures have been taken against wrenching. The right angle type is equipped with metaltab to secure soldering strength, and constructed so as to fix by screws. The straight type can choose whether or not metaltab are required. ■Applications Computers, peripheral equipments, various machines etc. ■Product Specifications Current rating 0.5A Rating Operating Temperature Range -55ç to +85ç (Note 1) Storage Temperature Range -10ç to +60ç (Note 2) Voltage rating 125V AC Operating Humidity Range 40 to 80% Item Storage Humidity Range 40 to 70% Specification (Note 2) Condition 1. Insulation Resistance 1000M ohms min 250V DC 2. Withstanding Voltage No flashover or insulation breakdown. 300V AC/1 minute 3. Contact Resistance 45m ohms max. 100mA 4. Vibration No electrical discontinuity of 1µs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Contact resistance: 55m ohms max. Insulation resistance: 100M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% Contact resistance: 55m ohms max. 6. Temperature Cycle (-55ç: 30 minutes→15 to 35ç: 2 to 3 minutes → Insulation resistance: 100M ohms min. (-85ç: 30 minutes→15 to 35ç: 2 to 3 minutes) 5 cycles No damage, cracks, or parts looseness. 7. Durability (Mating/un-mating) Contact resistance: 55 m ohms max. 500 cycles 8. Resistance to soldering heat No deformation of components affecting performance. Reflow: At the recommended temperature profile Manual soldering: 260ç for 10 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. ■Material Parts Insulator Contact Material Finish Dip type Polyamid Socket PBT/Polyamid SMT type PPS Receptacle Black UL94V-0 Light brown Phosphor bronze Socket Header Remark Selective gold plated ________ Phosphor bronze or brass ■Stacking Variation Header Dip type SMT type Unit:mm Dip type SMT type Receptacle FX2C-*S-1.27DSA(L) FX2C2-*S-1.27DSA(L) FX2-*S-1.27SV(L) FX2CA-*S-1.27DSA(L) FX2CA2-*S-1.27DSA(L) FX2C-*P-1.27DSA(L) 12.2 14.0 12.0 FX2CA-*P-1.27DSA(L) 13.2 15.0 13.0 FX2CA1-*P-1.27DSA(L) 14.2 16.0 14.0 FX2CA2-*P-1.27DSA(L) 12.3 14.1 12.1 FX2-*P-1.27SV(L) A143 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Ordering Information ●Board to Board Receptacle FX2 CA 2 - * S - 1.27 DSA L q w e r t y u i q Series Name :FX2 r Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100, 120 w Blank: Right angle type t Connector type: S: Receptacle C : Straight non-cleaning type y Contact pitch: 1.27mm CA : Straight cleaning type u Contact type e Product height variation (DSA only) DS DSA : Straight type Blank : Standard product 2 : Right angle type i L: Board prefixed pin : +2mm ●Board to Board Header FX2 CA 1 - * P - 1.27 DSA L q w e r t y u i q Series Name :FX2 r Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100, 120 w None : Right angle type t Connector type: P: header C : Straight non-cleaning type y Contact pitch: 1.27mm CA : Straight cleaning type u Contact type: e Product height variation (DSA only) DS DSA : Straight type Blank : Standard product 1 : Right angle type i L: Board prefixed pin : +1mm 2 : +2mm Note 1. C and CA take complete countermeasures against flux. Note 2. Cleaning type: the liquid escape hole is added at dip cleaning. Note 3. No-cleaning type: no liquid escape hole is added at dip cleaning. ●Board to Cable Socket FX2 BA - * S A - 1.27 R q w r t y u q Series Name : FX2 r S: Socket wB : Lock cable type t A: Contact material: phosphor bronze : No lock cable type y Contact pitch: 1.27mm BA e Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100 A144 e u R: Insulation displacement The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ●Board to Cable Header FX2 BA - * P A - 1.27 DSA L q w e r BA y u i t None : Contact material: phosphor bronze q Series Name : FX2 wB t A : Lock straight no cleaning type : Contact material: brass : Lock right angle type y Contact pitch: 1.27mm : Lock straight cleaning type u Contact type: e Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100 DS r Connector type: P: header DSA : Straight type : Right angle type i L: Board prefixed pin Note 1. Cleaning type: The liquid escape hole is added at dip cleaning. Note 2. No cleaning type: No liquid escape hole is added at dip cleaning. Note 3. Straight 20 and 32 contact types use phosphor bronze for contact material. ●Straight SMT Type FX2 - * P - 1.27 SV L q w e r t y r Contact pitch: 1.27mm q Series Name :FX2 w Number of contacts: 20, 32, 40, 52, 60, 68, 80, 100, 120 t Contact type: e Connector type: P: Header SV: Straight SMT type y L: Board prefixed pin S: Receptacle ●Header Right Angle SMT Type FX2 A - * P - 0.635 SH q w e r t y q Series Name :FX2 r Connector type: P: Header w Blank: With boss t Mounting area pitch: 0.635mm A : Without boss e Number of contacts: 20, 40, 52, 60, 80 y Contact type SH: Right angle SMT type A145 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BFX2 Functional Flow Chart Board to Board Cable Type Header Side A146 Receptacle and Socket Side FX2-*P-1.27DS (L) Right angle type FX2-*S-1.27DS (L) Right angle type FX2(A)-*P-0.635SH Right angle type SMT type FX2C-*S-1.27DS (L) Straight type No cleaning type, flux tight FX2C-*P-1.27DSA (L) Straight type No cleaning type, flux tight FX2C-*S-1.27DS (L) Straight type Cleaning type, flux tight FX2CA-*P-1.27DSA (L) Straight type Cleaning type, flux tight FX2CA-*S-1.27DSV (L) Straight type SMT type FX2-*P-1.27DSA (L) Straight type SMT type FX2BA-*SA-1.27R No lock cable type The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BFX2 Functional Flow Chart Board to Board Cable Type Header Side Receptacle and Socket Side FX2B-*PA-1.27DS (L) Lock right angle type FX2B-*PA-1.27DSA(L) Lock straight type No cleaning type, flux tight FX2BA-*SA-1.27R Lock cable type FX2BA-*PA-1.27DSA(L) Lock straight type Cleaning type, flux tight A147 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BThrough hole Type Application Pattern FX2-*P-1.27DS(L) Header Stacking height Receptacle B 12 14 Receptacle FX2C(A) -*S A FX2CA-*P 18.5 12 FX2CA1-*P 13 15 FX2C(A)2-*S 20.5 14 FX2CA2-*P 14 16 Header FX2CA-*S FX2CA2-*S Receptacle Receptacle FX2-*P-1.27DS(L) FX2-*S-1.27DS(L) A B FX2C(A) -*P 18.5 12 FX2C(A)1-*P 19.5 13 FX2C(A)2-*P 20.5 14 Header A148 Header FX2-*P-1.27DS(L) FX2B(A)-*SA-1.27R FX2B(A)-*SA-1.27R FX2B(A)-*P(A)-1.27DSA(L) FX2B-*PA-1.27DS(L) The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BSMT Type Application Pattern FX2-*P-1.27SV(L) FX2-*S-1.27SV(L) FX2-*S-1.27SV(L) FX2C(A)-*P-1.27DSA(L) FX2-*P-1.27SV(L) FX2-*S-1.27SV(L) FX2C(A)-*S-1.27-DSA(L) FX2C(A)1-*P-1.27DSA(L) FX2-*P-1.27SV(L) FX2-*S-1.27SV(L) FX2C(A)2-*S-1.27DSA(L) FX2C(A)2-*P-1.27DSA(L) FX2-*P-1.27SV(L) FX2-*S-1.27SV(L) FX2-*S-1.27DS(L) FX2-*P-1.27DS(L) A149 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BSMT Type Application Pattern FX2(A)-*P-0.635SH A150 Receptacle A FX2C(A)2 14.7 FX2C(A)2 16.7 FX2(A)-*P-0.635SH FX2C(A•2)-*S-1.27DSA(L) FX2-*S-1.27SV(L) FX2(A)-*P-0.635SH FX2(A)-*P-0.635SH FX2-*S-1.27DS(L) FX2BA-*SA-1.27R The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Receptacle No Cleaning Type ●Straight Type BPCB mounting pattern Unit:mm Part Number CL No. FX2C-020S-1.27DSA 572-2401-7 FX2C-020S-1.27DSAL 572-2451-5 FX2C-032S-1.27DSA 572-2402-0 FX2C-032S-1.27DSAL 572-2452-8 FX2C-040S-1.27DSA 572-2403-2 FX2C-040S-1.27DSAL 572-2453-0 FX2C-052S-1.27DSA 572-2404-5 FX2C-052S-1.27DSAL 572-2454-3 FX2C-060S-1.27DSA 572-2405-8 FX2C-060S-1.27DSAL 572-2455-6 FX2C-068S-1.27DSA 572-2406-0 FX2C-068S-1.27DSAL 572-2456-9 FX2C-080S-1.27DSA 572-2407-3 FX2C-080S-1.27DSAL 572-2457-1 FX2C-100S-1.27DSA 572-2408-6 FX2C-100S-1.27DSAL 572-2458-4 FX2C-120S-1.27DSA 572-2409-9 FX2C-120S-1.27DSAL 572-2459-7 Number of Contacts A B C 20 22.75 11.43 17.63 32 30.37 19.05 25.25 40 35.45 24.13 30.33 52 43.07 31.75 37.95 60 48.15 36.83 43.03 68 53.23 41.91 48.11 80 60.85 49.53 55.73 100 73.55 62.23 68.43 120 86.25 74.93 81.13 D ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 A151 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Receptacle Cleaning Type ●Straight Type BPCB mounting pattern Unit:mm A152 Part Number CL No. FX2CA-020S-1.27DSA 572-2501-1 FX2CA-020S-1.27DSAL 572-2551-0 FX2CA-032S-1.27DSA 572-2502-4 FX2CA-032S-1.27DSAL 572-2552-2 FX2CA-040S-1.27DSA 572-2503-7 FX2CA-040S-1.27DSAL 572-2553-5 FX2CA-052S-1.27DSA 572-2504-0 FX2CA-052S-1.27DSAL 572-2554-8 FX2CA-060S-1.27DSA 572-2505-2 FX2CA-060S-1.27DSAL 572-2555-0 FX2CA-068S-1.27DSA 572-2506-5 FX2CA-068S-1.27DSAL 572-2556-3 FX2CA-080S-1.27DSA 572-2507-8 FX2CA-080S-1.27DSAL 572-2557-6 FX2CA-100S-1.27DSA 572-2508-0 FX2CA-100S-1.27DSAL 572-2558-9 FX2CA-120S-1.27DSA 572-2509-3 FX2CA-120S-1.27DSAL 572-2559-1 Number of Contacts A B C 20 22.75 11.43 17.63 32 30.37 19.05 25.25 40 35.45 24.13 30.33 52 43.07 31.75 37.95 60 48.15 36.83 43.03 68 53.23 41.91 48.11 80 60.85 49.53 55.73 100 73.55 62.23 68.43 120 86.25 74.93 81.13 D ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Receptacle No Cleaning Type ●Straight Type BPCB mounting pattern Unit:mm Part Number CL No. FX2C2-020S-1.27DSA 572-2421-4 FX2C2-020S-1.27DSAL 572-2471-2 FX2C2-032S-1.27DSA 572-2422-7 FX2C2-032S-1.27DSAL 572-2472-5 FX2C2-040S-1.27DSA 572-2423-0 FX2C2-040S-1.27DSAL 572-2473-8 FX2C2-052S-1.27DSA 572-2424-2 FX2C2-052S-1.27DSAL 572-2474-0 FX2C2-060S-1.27DSA 572-2425-5 FX2C2-060S-1.27DSAL 572-2475-3 FX2C2-068S-1.27DSA 572-2426-8 FX2C2-068S-1.27DSAL 572-2476-6 FX2C2-080S-1.27DSA 572-2427-0 FX2C2-080S-1.27DSAL 572-2477-9 FX2C2-100S-1.27DSA 572-2428-3 FX2C2-100S-1.27DSAL 572-2478-1 FX2C2-120S-1.27DSA 572-2429-6 FX2C2-120S-1.27DSAL 572-2479-4 Number of Contacts A B C 20 22.75 11.43 17.63 32 30.37 19.05 25.25 40 35.45 24.13 30.33 52 43.07 31.75 37.95 60 48.15 36.83 43.03 68 53.23 41.91 48.11 80 60.85 49.53 55.73 100 73.55 62.23 68.43 120 86.25 74.93 81.13 D ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 A153 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Receptacle Cleaning Type ●Straight Type BPCB mounting pattern Unit:mm A154 Part Number CL No. FX2CA2-020S-1.27DSA 572-2521-9 FX2CA2-020S-1.27DSAL 572-2571-7 FX2CA2-032S-1.27DSA 572-2522-1 FX2CA2-032S-1.27DSAL 572-2572-0 FX2CA2-040S-1.27DSA 572-2523-4 FX2CA2-040S-1.27DSAL 572-2573-2 FX2CA2-052S-1.27DSA 572-2524-7 FX2CA2-052S-1.27DSAL 572-2574-5 FX2CA2-060S-1.27DSA 572-2525-0 FX2CA2-060S-1.27DSAL 572-2575-8 FX2CA2-068S-1.27DSA 572-2526-2 FX2CA2-068S-1.27DSAL 572-2576-0 FX2CA2-080S-1.27DSA 572-2527-5 FX2CA2-080S-1.27DSAL 572-2577-3 FX2CA2-100S-1.27DSA 572-2528-8 FX2CA2-100S-1.27DSAL 572-2578-6 FX2CA2-120S-1.27DSA 572-2529-0 FX2CA2-120S-1.27DSAL 572-2579-9 Number of Contacts A B C 20 22.75 11.43 17.63 32 30.37 19.05 25.25 40 35.45 24.13 30.33 52 43.07 31.75 37.95 60 48.15 36.83 43.03 68 53.23 41.91 48.11 80 60.85 49.53 55.73 100 73.55 62.23 68.43 120 86.25 74.93 81.13 D ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Receptacle ●Right Angle Type BPCB mounting pattern Unit:mm Part Number CL No. FX2-020S-1.27DS 572-2701-0 FX2-020S-1.27DSL 572-2751-9 FX2-032S-1.27DS 572-2702-3 FX2-032S-1.27DSL 572-2752-1 FX2-040S-1.27DS 572-2703-6 FX2-040S-1.27DSL 572-2753-4 FX2-052S-1.27DS 572-2704-9 FX2-052S-1.27DSL 572-2754-7 FX2-060S-1.27DS 572-2705-1 FX2-060S-1.27DSL 572-2755-0 FX2-068S-1.27DS 572-2706-4 FX2-068S-1.27DSL 572-2756-2 FX2-080S-1.27DS 572-2707-7 FX2-080S-1.27DSL 572-2757-5 FX2-100S-1.27DS 572-2708-0 FX2-100S-1.27DSL 572-2758-8 FX2-120S-1.27DS 572-2709-2 FX2-120S-1.27DSL 572-2759-0 Number of Contacts A B C D 20 22.75 11.43 17.63 18.05 32 30.37 19.05 25.25 25.67 40 35.45 24.13 30.33 30.75 52 43.07 31.75 37.95 38.37 60 48.15 36.83 43.03 43.45 68 53.23 41.91 48.11 48.53 80 60.85 49.53 55.73 56.15 100 73.55 62.23 68.43 68.85 120 86.25 74.93 81.13 81.55 A155 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header ●Right Angle Type BPCB mounting pattern Unit:mm Part Number A156 CL No. FX2-020P-1.27DS 572-2601-6 FX2-020P-1.27DSL 572-2651-4 FX2-032P-1.27DS 572-2602-9 FX2-032P-1.27DSL 572-2652-7 FX2-040P-1.27DS 572-2603-1 FX2-040P-1.27DSL 572-2653-0 FX2-052P-1.27DS 572-2604-4 FX2-052P-1.27DSL 572-2654-2 FX2-060P-1.27DS 572-2605-7 FX2-060P-1.27DSL 572-2655-5 FX2-068P-1.27DS 572-2606-0 FX2-068P-1.27DSL 572-2656-8 FX2-080P-1.27DS 572-2607-2 FX2-080P-1.27DSL 572-2657-0 FX2-100P-1.27DS 572-2608-5 FX2-100P-1.27DSL 572-2658-3 FX2-120P-1.27DS 572-2609-8 FX2-120P-1.27DSL 572-2659-6 Number of Contacts A B C 20 22.75 11.43 18.05 32 30.37 19.05 25.67 40 35.45 24.13 30.75 52 43.07 31.75 38.37 60 48.15 36.83 43.45 68 53.23 41.91 48.53 80 60.85 49.53 56.15 100 73.55 62.23 68.85 120 86.25 74.93 81.55 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header No Cleaning Type ●Straight Type BPCB mounting pattern Unit:mm Part Number CL No. FX2C-020P-1.27DSA 572-2201-8 FX2C-020P-1.27DSAL 572-2251-6 FX2C-032P-1.27DSA 572-2202-0 FX2C-032P-1.27DSAL 572-2252-9 FX2C-040P-1.27DSA 572-2203-3 FX2C-040P-1.27DSAL 572-2253-1 FX2C-052P-1.27DSA 572-2204-6 FX2C-052P-1.27DSAL 572-2254-4 FX2C-060P-1.27DSA 572-2205-9 FX2C-060P-1.27DSAL 572-2255-7 FX2C-068P-1.27DSA 572-2206-1 FX2C-068P-1.27DSAL 572-2256-0 FX2C-080P-1.27DSA 572-2207-4 FX2C-080P-1.27DSAL 572-2257-2 FX2C-100P-1.27DSA 572-2208-7 FX2C-100P-1.27DSAL 572-2258-5 FX2C-120P-1.27DSA 572-2209-0 FX2C-120P-1.27DSAL 572-2259-8 Number of Contacts A B 20 22.75 11.43 32 30.37 19.05 40 35.45 24.13 52 43.07 31.75 60 48.15 36.83 68 53.23 41.91 80 60.85 49.53 100 73.55 62.23 120 86.25 74.93 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 A157 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header Cleaning Type ●Straight Type BPCB mounting pattern Unit:mm A158 Part Number CL No. FX2CA-020P-1.27DSA 572-2301-2 FX2CA-020P-1.27DSAL 572-2351-0 FX2CA-032P-1.27DSA 572-2302-5 FX2CA-032P-1.27DSAL 572-2352-3 FX2CA-040P-1.27DSA 572-2303-8 FX2CA-040P-1.27DSAL 572-2353-6 FX2CA-052P-1.27DSA 572-2304-0 FX2CA-052P-1.27DSAL 572-2354-9 FX2CA-060P-1.27DSA 572-2305-3 FX2CA-060P-1.27DSAL 572-2355-1 FX2CA-068P-1.27DSA 572-2306-6 FX2CA-068P-1.27DSAL 572-2356-4 FX2CA-080P-1.27DSA 572-2307-9 FX2CA-080P-1.27DSAL 572-2357-7 FX2CA-100P-1.27DSA 572-2308-1 FX2CA-100P-1.27DSAL 572-2358-0 FX2CA-120P-1.27DSA 572-2309-4 FX2CA-120P-1.27DSAL 572-2359-2 Number of Contacts A B 20 22.75 11.43 32 30.37 19.05 40 35.45 24.13 52 43.07 31.75 60 48.15 36.83 68 53.23 41.91 80 60.85 49.53 100 73.55 62.23 120 86.25 74.93 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header No Cleaning Type ●Straight Type BPCB mounting pattern Unit: mm Part Number CL No. FX2C1-020P-1.27DSA 572-2211-1 FX2C1-020P-1.27DSAL 572-2261-0 FX2C1-032P-1.27DSA 572-2212-4 FX2C1-0Z32P-1.27DSAL 572-2262-2 FX2C1-040P-1.27DSA 572-2213-7 FX2C1-040P-1.27DSAL 572-2263-5 FX2C1-052P-1.27DSA 572-2214-0 FX2C1-052P-1.27DSAL 572-2264-8 FX2C1-060P-1.27DSA 572-2215-2 FX2C1-060P-1.27DSAL 572-2265-0 FX2C1-068P-1.27DSA 572-2216-5 FX2C1-068P-1.27DSAL 572-2266-3 FX2C1-080P-1.27DSA 572-2217-8 FX2C1-080P-1.27DSAL 572-2267-6 FX2C1-100P-1.27DSA 572-2218-0 FX2C1-100P-1.27DSAL 572-2268-9 FX2C1-120P-1.27DSA 572-2219-3 FX2C1-120P-1.27DSAL 572-2269-1 Number of Contacts A B 20 22.75 11.43 32 30.37 19.05 40 35.45 24.13 52 43.07 31.75 60 48.15 36.83 68 53.23 41.91 80 60.85 49.53 100 73.55 62.23 120 86.25 74.93 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 A159 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header Cleaning Type ●Straight Type BPCB mounting pattern Unit: mm Part Number A160 CL No. FX2CA1-020P-1.27DSA 572-2311-6 FX2CA1-020P-1.27DSAL 572-2361-4 FX2CA1-032P-1.27DSA 572-2312-9 FX2CA1-032P-1.27DSAL 572-2362-7 FX2CA1-040P-1.27DSA 572-2313-1 FX2CA1-040P-1.27DSAL 572-2363-0 FX2CA1-052P-1.27DSA 572-2314-4 FX2CA1-052P-1.27DSAL 572-2364-2 FX2CA1-060P-1.27DSA 572-2315-7 FX2CA1-060P-1.27DSAL 572-2365-5 FX2CA1-068P-1.27DSA 572-2316-0 FX2CA1-068P-1.27DSAL 572-2366-8 FX2CA1-080P-1.27DSA 572-2317-2 FX2CA1-080P-1.27DSAL 572-2367-0 FX2CA1-100P-1.27DSA 572-2318-5 FX2CA1-100P-1.27DSAL 572-2368-3 FX2CA1-120P-1.27DSA 572-2319-8 FX2CA1-120P-1.27DSAL 572-2369-6 Number of Contacts A B 20 22.75 11.43 32 30.37 19.05 40 35.45 24.13 52 43.07 31.75 60 48.15 36.83 68 53.23 41.91 80 60.85 49.53 100 73.55 62.23 120 86.25 74.93 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header No Cleaning Type ●Straight Type BPCB mounting pattern Unit: mm Part Number CL No. FX2C2-020P-1.27DSA 572-2221-5 FX2C2-020P-1.27DSAL 572-2271-3 FX2C2-032P-1.27DSA 572-2222-8 FX2C2-032P-1.27DSAL 572-2272-6 FX2C2-040P-1.27DSA 572-2223-0 FX2C2-040P-1.27DSAL 572-2273-9 FX2C2-052P-1.27DSA 572-2224-3 FX2C2-052P-1.27DSAL 572-2274-1 FX2C2-060P-1.27DSA 572-2225-6 FX2C2-060P-1.27DSAL 572-2275-4 FX2C2-068P-1.27DSA 572-2226-9 FX2C2-068P-1.27DSAL 572-2276-7 FX2C2-080P-1.27DSA 572-2227-1 FX2C2-080P-1.27DSAL 572-2277-0 FX2C2-100P-1.27DSA 572-2228-4 FX2C2-100P-1.27DSAL 572-2278-2 FX2C2-120P-1.27DSA 572-2229-7 FX2C2-120P-1.27DSAL 572-2279-5 Number of Contacts A B 20 22.75 11.43 32 30.37 19.05 40 35.45 24.13 52 43.07 31.75 60 48.15 36.83 68 53.23 41.91 80 60.85 49.53 100 73.55 62.23 120 86.25 74.93 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 A161 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header Cleaning Type ●Straight Type BPCB mounting pattern Unit: mm Part Number A162 CL No. FX2CA2-020P-1.27DSA 572-2321-0 FX2CA2-020P-1.27DSAL 572-2371-8 FX2CA2-032P-1.27DSA 572-2322-2 FX2CA2-032P-1.27DSAL 572-2372-0 FX2CA2-040P-1.27DSA 572-2323-5 FX2CA2-040P-1.27DSAL 572-2373-3 FX2CA2-052P-1.27DSA 572-2324-8 FX2CA2-052P-1.27DSAL 572-2374-6 FX2CA2-060P-1.27DSA 572-2325-0 FX2CA2-060P-1.27DSAL 572-2375-9 FX2CA2-068P-1.27DSA 572-2326-3 FX2CA2-068P-1.27DSAL 572-2376-1 FX2CA2-080P-1.27DSA 572-2327-6 FX2CA2-080P-1.27DSAL 572-2377-4 FX2CA2-100P-1.27DSA 572-2328-9 FX2CA2-100P-1.27DSAL 572-2378-7 FX2CA2-120P-1.27DSA 572-2329-1 FX2CA2-120P-1.27DSAL 572-2379-0 Number of Contacts A B 20 22.75 11.43 32 30.37 19.05 40 35.45 24.13 52 43.07 31.75 60 48.15 36.83 68 53.23 41.91 80 60.85 49.53 100 73.55 62.23 120 86.25 74.93 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 ________ 82.55 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Receptacle SMT Type ●Straight Type Note: The 120 contacts type differs in the style. BPCB mounting pattern Unit: mm Part Number CL No. FX2-020S-1.27SV 572-2101-3 FX2-020S-1.27SVL 572-2151-1 FX2-032S-1.27SV 572-2102-6 FX2-032S-1.27SVL 572-2152-4 FX2-040S-1.27SV 572-2103-9 FX2-040S-1.27SVL 572-2153-7 FX2-052S-1.27SV 572-2104-1 FX2-052S-1.27SVL 572-2154-0 FX2-060S-1.27SV 572-2105-4 FX2-060S-1.27SVL 572-2155-2 FX2-068S-1.27SV 572-2106-7 FX2-068S-1.27SVL 572-2156-5 FX2-080S-1.27SV 572-2107-0 FX2-080S-1.27SVL 572-2157-8 FX2-100S-1.27SV 572-2108-2 FX2-100S-1.27SVL 572-2158-0 FX2-120S-1.27SV 572-2109-5 FX2-120S-1.27SVL 572-2159-3 Number of Contacts A B C D 20 22.75 11.43 17.63 16.51 32 30.37 19.05 25.25 24.13 40 35.45 24.13 30.33 29.21 52 43.07 31.75 37.95 36.83 60 48.15 36.83 43.03 41.91 68 53.23 41.91 48.11 46.99 80 60.85 49.53 55.73 54.61 100 73.55 62.23 68.43 67.31 120 86.25 74.93 81.13 80.01 E ________ F ________ 25.75 ________ 21.15 ________ 33.37 ________ 28.77 ________ 38.45 ________ 33.85 ________ 46.07 ________ 41.47 ________ 51.15 ________ 46.55 ________ 56.23 ________ 51.63 ________ 63.85 ________ 59.25 ________ 76.55 ________ 71.95 ________ 89.25 84.65 A163 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header SMT Type ●Straight Type BPCB mounting pattern Unit: mm Part Number A164 CL No. FX2-020P-1.27SV 572-2001-9 FX2-020P-1.27SVL 572-2051-7 FX2-032P-1.27SV 572-2002-1 FX2-032P-1.27SVL 572-2052-0 FX2-040P-1.27SV 572-2003-4 FX2-040P-1.27SVL 572-2053-2 FX2-052P-1.27SV 572-2004-7 FX2-052P-1.27SVL 572-2054-5 FX2-060P-1.27SV 572-2005-0 FX2-060P-1.27SVL 572-2055-8 FX2-068P-1.27SV 572-2006-2 FX2-068P-1.27SVL 572-2056-0 FX2-080P-1.27SV 572-2007-5 FX2-080P-1.27SVL 572-2057-3 FX2-100P-1.27SV 572-2008-8 FX2-100P-1.27SVL 572-2058-6 FX2-120P-1.27SV 572-2009-0 FX2-120P-1.27SVL 572-2059-9 Number of Contacts A B C 20 22.75 11.43 16.51 32 30.37 19.05 24.13 40 35.45 24.13 29.21 52 43.07 31.75 36.83 60 48.15 36.83 41.91 68 53.23 41.91 46.99 80 60.85 49.53 54.61 100 73.55 62.23 67.31 120 86.25 74.93 80.01 D ________ E ________ 25.75 ________ 21.15 ________ 33.37 ________ 28.77 ________ 38.45 ________ 33.85 ________ 46.07 ________ 41.47 ________ 51.15 ________ 46.55 ________ 56.23 ________ 51.63 ________ 63.85 ________ 59.25 ________ 76.55 ________ 71.95 ________ 89.25 84.65 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header SMT Type ●Right Angle Type BMounting Example (Reference) Since bosses are located symmetrically on the right and left sides, connectors can be mounted on both sides of board as shown above. Note: The FX2A type does not have bosses as shown in the illustration. BPCB mounting Pattern BRecommended Screw Clamp Use M2 screw for fixture. Recommended torque is 0.15(N•m). Unit: mm Part Number CL No. FX2-20P-0.635SH 572-2761-2 FX2A-20P-0.635SH 572-2771-6 FX2-40P-0.635SH 572-2763-8 FX2A-40P-0.635SH 572-2773-1 FX2-52P-0.635SH 572-2764-0 FX2A-52P-0.635SH 572-2774-4 FX2-60P-0.635SH 572-2765-3 FX2A-60P-0.635SH 572-2775-7 FX2-80P-0.635SH 572-2767-9 FX2A-80P-0.635SH 572-2777-2 Number of Contacts A B C D E F G 20 22.75 12.065 18.05 6.85 ________ 8.85 ________ 15.7 ________ 21.15 40 35.45 24.765 30.75 13.2 ________ 15.2 ________ 28.4 ________ 33.85 52 43.07 32.385 38.37 17.01 ________ 19.01 ________ 36.02 ________ 41.47 60 48.15 37.465 43.45 19.55 ________ 21.55 ________ 41.1 ________ 46.55 80 60.85 50.165 56.15 25.9 ________ 27.9 ________ 53.8 ________ 59.25 A165 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Socket Type ●Lock Cable Type Combination View Unit: mm Part Number CL No. Number of Contacts A FX2B-020SA-1.27R 572-0621-2 20 27.83 FX2B-032SA-1.27R 572-0622-5 32 35.45 FX2B-040SA-1.27R 572-0623-8 40 40.53 FX2B-052SA-1.27R 572-0624-0 52 48.15 FX2B-060SA-1.27R 572-0625-3 60 53.23 FX2B-068SA-1.27R 572-0629-4 68 58.31 FX2B-080SA-1.27R 572-0630-3 80 65.93 FX2B-100SA-1.27R 572-0628-1 100 78.63 ●Unlock Cable Type Combination View Part Number BConnection Tool Type Part Number CL No. Number of Contacts A FX2BA-020SA-1.27R 572-0671-0 20 18.05 FX2BA-032SA-1.27R 572-0672-3 32 25.67 FX2BA-040SA-1.27R 572-0673-6 40 30.75 FX2BA-052SA-1.27R 572-0674-9 52 38.37 FX2BA-060SA-1.27R 572-0675-1 60 43.45 FX2BA-068SA-1.27R 572-0676-4 68 48.53 FX2BA-080SA-1.27R 572-0677-7 80 56.15 FX2BA-100SA-1.27R 572-0678-0 100 68.85 CL No. Guide plate FX2B(A)-GPA 550-0212-6 Connection press Hi-Flex connection press 550-0082-2 Note:HRS6 cable cutter FC601 isn't required for FX2B(A) connection. (Connected without convex-concave cutting.) A166 Unit: mm The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header ●Right Angle Type for Lock BPCB mounting pattern Unit: mm Part Number CL No. FX2B-020PA-1.27DS 572-0721-7 FX2B-020PA-1.27DSL 572-0771-5 FX2B-032PA-1.27DS 572-0722-0 FX2B-032PA-1.27DSL 572-0772-8 FX2B-040PA-1.27DS 572-0723-2 FX2B-040PA-1.27DSL 572-0773-0 FX2B-052PA-1.27DS 572-0724-5 FX2B-052PA-1.27DSL 572-0774-3 FX2B-060PA-1.27DS 572-0725-8 FX2B-060PA-1.27DSL 572-0775-6 FX2B-068PA-1.27DS 572-0726-0 FX2B-068PA-1.27DSL 572-0776-9 FX2B-080PA-1.27DS 572-0727-3 FX2B-080PA-1.27DSL 572-0777-1 FX2B-100PA-1.27DS 572-0728-6 FX2B-100PA-1.27DSL 572-0778-4 Number of Contacts A B C 20 30.33 11.43 18.05 32 37.95 19.05 25.67 40 43.03 24.13 30.75 52 50.65 31.75 38.37 60 55.73 36.83 43.45 68 60.81 41.91 48.53 80 68.43 49.53 56.15 100 81.13 62.23 68.85 A167 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header No Cleaning Type ●Straight Type for Lock BPCB mounting pattern Unit: mm A168 Part Number CL No. FX2B-020PA-1.27DSA 572-0801-4 FX2B-020PA-1.27DSAL 572-0851-2 FX2B-032PA-1.27DSA 572-0802-7 FX2B-032PA-1.27DSAL 572-0852-5 FX2B-040PA-1.27DSA 572-0823-7 FX2B-040PA-1.27DSAL 572-0873-5 FX2B-052PA-1.27DSA 572-0824-0 FX2B-052PA-1.27DSAL 572-0874-8 FX2B-060PA-1.27DSA 572-0825-2 FX2B-060PA-1.27DSAL 572-0875-0 FX2B-068PA-1.27DSA 572-0826-5 FX2B-068PA-1.27DSAL 572-0876-3 FX2B-080PA-1.27DSA 572-0827-8 FX2B-080PA-1.27DSAL 572-0877-6 FX2B-100PA-1.27DSA 572-0828-0 FX2B-100PA-1.27DSAL 572-0878-9 Number of Contacts A B 20 30.33 11.43 32 37.95 19.05 40 43.03 24.13 52 50.65 31.75 60 55.73 36.83 68 60.81 41.91 80 68.43 49.53 100 81.13 62.23 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Header Cleaning Type ●Straight Type for Lock BPCB mounting pattern Unit: mm Part Number CL No. FX2BA-020PA-1.27DSA 572-0901-9 FX2BA-020PA-1.27DSAL 572-0951-7 FX2BA-032PA-1.27DSA 572-0902-1 FX2BA-032PA-1.27DSAL 572-0952-0 FX2BA-040PA-1.27DSA 572-0923-1 FX2BA-040PA-1.27DSAL 572-0973-0 FX2BA-052PA-1.27DSA 572-0924-4 FX2BA-052PA-1.27DSAL 572-0974-2 FX2BA-060PA-1.27DSA 572-0925-7 FX2BA-060PA-1.27DSAL 572-0975-5 FX2BA-068PA-1.27DSA 572-0926-0 FX2BA-068PA-1.27DSAL 572-0976-8 FX2BA-080PA-1.27DSA 572-0927-2 FX2BA-080PA-1.27DSAL 572-0977-0 FX2BA-100PA-1.27DSA 572-0928-5 FX2BA-100PA-1.27DSAL 572-0978-3 Number of Contacts A B 20 30.33 11.43 32 37.95 19.05 40 43.03 24.13 52 50.65 31.75 60 55.73 36.83 68 60.81 41.91 80 68.43 49.53 100 81.13 62.23 C ________ 19.05 ________ 26.67 ________ 31.75 ________ 39.37 ________ 44.45 ________ 49.53 ________ 57.15 ________ 69.85 A169 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BConnection Circuit Diagram n= Number of Contacts 2 Type A, B Connection to Cable 1 A1 B2 bn 1 ······ 1 bn ······ B1 ······ an an ······ A2 Connection to Cable 2 An a1 Bn b1 Type A, A A1 b1 B1 a1 A2 b2 B2 a2 ······ ······ ······ Connection to Cable 2 ······ Connection to Cable 1 An bn Bn an A173 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. BConnecter Use Hand book 1. Selecting connector 1 The FX2 series is the perfect flux tight connector for the straight type in the soldering process, but it depends on the soldering process whether non-cleaning type (FX2C-*, FX2B-*) or cleaning type (FX2CA-*, FX2BA-*) should be selected. Please be sure to clean the right angle type (FX2-*, FX2B-*) connector. To clean the connector, please be sure to use detergent, containing no contaminant. 2 To use the socket cable type, if a vibration or shock load is applied to the cable, select the lock type. In addition, if a load is applied to the cable, please be sure to use the cable clamp. 2. Prefixed Process to Board If the prefixed process is required for mounting the board, please use the prefixed pin type. (Applicable board thickness t = 1.6±0.1) Note: In order to prevent the dip post breakage in the connector installation to the board, please insert the board in parallel to the connector so that the prefixed pin may be forcibly pushed in, after the dip post is guided to the board through-hole. 3. Mating Side Tolerance Clearance (Example) FX2C-*P-1.27DSA and FX2C-*S-1.27DSA Set the tolerance clearance within 1mm to mate the male and female connectors. (Except for the lock cable type) 4. Cautions: for Using Lock Cable Type 1 When the connector is mated, insert the connector by the end so as not to make a clearance. A174 2 When the connector is inserted or extracted, please insert or extract the connector after the both lock levers are laid inside. If the connector is inserted or extracted with either lock lever laid, the connector may be broken. 3 please do not open the lock lever outside. The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. 5. SMT Type Connector Mounting Temperature Profile (Reference) ●IR Reflow Applicable Conditions Reflow system :IR reflow Solder : Paste type 63 Sn/37 Pb (Flux content 11 wt%) Test board : Glass epoxy 110mm x 40mm x 1.6 mm Metal mask thickness : 0.2 mm (Straight type) 0.15mm (Right angle type) Recommended temperature profile. The temperature may be slightly changed according to the solder paste type and amount. 6. SMT Type Connector mated height As shown in the application pattern, the mated height of the male/female connector doesn't contain the solder paste thickness. Thus, after the connector installation in the board, consider that the mated height will be widened in proportion to the solder paste thickness. A175
FX2B-68SA-1.27R(4件套) 价格&库存
很抱歉,暂时无法提供与“FX2B-68SA-1.27R(4件套)”相匹配的价格&库存,您可以联系我们找货
