FLEXIBLE ELEVATED &
SELF-NESTING SOCKETS
(2.00 mm) .0787" PITCH • ESQT/ESQT (-368)/PTHF SERIES
ESQT
Board Mates:
TMMH, TMM, MTMM,
MMT, TW, LTMM, ZLTMM,
ESQT, PTT, TSH, TMMS
Cable Mates:
TCMD
ESQT
-1
NO. PINS
PER ROW
02 thru 50
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (ESQT/TMMH):
4.5 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(2.62 mm) .103" to
(5.03 mm) .198" with
(0.38 mm) .015" wipe
Max Cycles:
100 with 10 µ" (0.25 µm) Au
Lead–Free Solderable:
Yes, for -S, -D & -Q
(Wave only for -T, -5 & -6)
ESQT (-368)/PTHF
Mates:
ESQT, PTHF
SPECIFICATIONS
Insulator Material:
Polymer (ESQT-368)
Black High Temp
Nylon (PTHF)
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
-55 °C to +125 °C
Max Cycles:
Yes (ESQT-368)
LEAD
STYLE
= Single Row
–L
= Double Row
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
Gold on contact,
Matte Tin on tail
No. of
rows
x
(2.00)
.0787
–GF
LEAD
STYLE
A
–03
ESQT
NO. PINS
PER ROW
30
= Solder Tails
PTHF
= Press-fit Tails
F-224
–D
OTHER
OPTION
–“XXX”
= Polarized
Position
(Indicate
position
number)
(7.87 mm) .310"
minimum for
–S, –D, –Q
–T
(9.53 mm) .375"
minimum for
–T, –5, –6
–Q
= Quad Row
No. of
–5
rows
x = Five Row
(2.00)
.0787
–6
.250
A
MAX
TAIL
BODY MAX BODY
(1.27)
TAIL
HEIGHT
HEIGHT
(21.59) (13.72)
.850
.540
(11.63) (3.76)
.458
.148
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
TAIL
(1.27)
.050
MIN
BODY
HEIGHT
A
.050
(20.32)
MIN
.800
(10.36)
.408
PLATING
OPTION
Q
368
–GF
= 15 µ" (0.38 µm)
Gold on contact,
Gold flash on tail
(–02 Lead Style only)
–M
= 20 µ" (0.51 µm)
Gold on contact,
Matte Tin on tail
(–03 Lead Style only)
LEAD
STYLE
–02
(8.00)
.315
–03
ESQT
PTHF
A
B
A
(21.59)
.850
(11.63)
.458
(12.24)
.482
(2.29)
.090
(21.59)
.850
(12.34)
.486
(60.30) 2.374
TOOLING
Note:
This Series is non-standard,
non-returnable.
–“XXX”
= Body Height
(in inches)
= Triple Row
(6.35)
.250
Press-Fit
CAT-PT-PT-130-A-4
For more information, visit
www.samtec.com/tooling
BODY
HEIGHT
= 15 µ" (0.38 µm)
Gold on contact,
= Six Row
Gold flash on tail
(Recommended
for self-nesting)
(–02 lead style only) (6.35)
–02
-1
–S
= Gold flash on contact,
Matte Tin on tail
No. of positions–M
x
(2.00) .0787=+ 20
(0.30)
.012 µm)
µ" (0.51
(6.35)
.250
ROW
OPTION
–F
Specify
LEAD
STYLE
from
chart
No. of positions x
(2.00) .0787 + (0.30) .012
SERIES
PLATING
OPTION
(9.35)
.368
A
A
B
ESQT (—368) SERIES
samtec.com?ESQT or samtec.com?PTHF
B
PTHF SERIES
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
B
(12.24)
.482
(3.00)
.118
ESQT-119-02-G-Q-390 价格&库存
很抱歉,暂时无法提供与“ESQT-119-02-G-Q-390”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 14+174.5919314+22.39329
