ET60S-D03-0-00-000-L-R1-S 数据手册
EXTREME HIGH-POWER
60 A SYSTEMS
FEATURES & BENEFITS
• Up to 60 A per power blade (2 blades powered)
• Low 10 mm profile (right-angle) for enhanced
system airflow
• Power only, or power/signal combinations
• 3 or 5 signal rows in the same form factor
• AC power, DC power, power/signal combinations
and split power options available
• Coplanar and perpendicular applications
• Modules can be configured to accommodate
most any design
MAX
• Rugged guide posts are standard; top design
for board space savings
• Press-fit (ET60S only) and hot swap (ET60T only)
options available
Standard Creepage*
3.02 mm
Standard Clearance*
1.87 mm
60
A
m
p
s
*Selectively loading contacts achieves customer
specific creepage and clearance requrements.
Contact asp@samtec.com
KEY SPECIFICATIONS (ET60T/ET60S)
PITCH
Power
(5.50 mm) .217"
(7.50 mm) .295"
Signal
(2.00 mm) .097" (5 row)
(2.54 mm) .100" (3 row)
INSULATOR
MATERIAL
TERMINAL
MATERIAL
PLATING
OPERATING
TEMP RANGE
VOLTAGE
RATING
MATING
CYCLES
LEAD-FREE
SOLDERABLE
Black LCP
Signal: Phosphor
Bronze
Power: Copper Alloy
Au or Sn over
50 µ" (1.27 µm) Ni
-40 °C to
+105 °C
280 VAC
500
Yes
Notes:
Some lengths, styles and options are non-standard, non-returnable.
*EXTreme Ten60Power™ is a trademark of Molex Incorporated and is dual sourced by Molex®
F-224
samtec.com/extreme-ten60power
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
60 A SIGNAL/POWER COMBO SYSTEM
SERIES
ET60T
Terminal
ET60S
Socket
POWER
OPTION (R)
–AXX
= AC Power
Positions
(02 - 06)
–DXX
= DC Power
Positions
(02 - 10)
–SXX*
= Split Power
–000
= No Power
ROWS
–0
SIGNAL POS.
PER ROW
–00
= No
Signal
= No Signal
–3
= 3 Row only
–5
–08
–01, –02,
–03, –04,
–05, –06,
–07, –08
= 5 Row only
POWER
OPTION (L)
–AXX
= AC Power
Positions
(02 - 06)
–DXX
= DC Power
Positions
(02 - 10)
–SXX*
= Split Power
PLATING
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(Not available
for 5 rows)
–S
= 30 µ" (0.76 µm)
Gold on contact,
Matte tin on tail
TAIL
GUIDE
POST
–R1
= Right-angle
Through-hole
(Use with (1.60 mm)
.062" thick card)
–VP
= Vertical Press-fit
(Not available
with ET60T)
(Required
callout)
–S
= Side
Guide Post
–T*
OPTION
(Leave blank
for no hot
swap)
–H
= Hot Swap
(ET60T only)
= Top
Guide Post
–V1
= Vertical
Through-hole
(Use with (1.60 mm)
.062" thick card)
(–0 and –3 Row only)
(Not available
with ET60T)
–000
= No Power
ET60T
Board Mates:
ET60S
(29.25)
1.152
(77.21) 3.04
(10.00)
.394
(77.21) 3.04
ET60T-D04-5-03-A04-X-R1-S SHOWN
View complete specifications at: samtec.com?ET60T
ET60S
(18.00)
.709
Board Mates:
ET60T
(77.21) 3.04
VERTICAL
ET60S-D04-5-03-A04-X-VP-S SHOWN
(77.21) 3.04
(10.00)
.394
(25.22)
.993
RIGHT-ANGLE
ET60S-D04-5-03-A04-X-R1-S SHOWN
View complete specifications at: samtec.com?ET60S
F-224
ET60S-D03-0-00-000-L-R1-S 价格&库存
很抱歉,暂时无法提供与“ET60S-D03-0-00-000-L-R1-S”相匹配的价格&库存,您可以联系我们找货
