FTS-114-02-L-S
FTS-114-02-L-S
    SAMTEC(申泰)
    插件,P=1.27mm
    排针 间距:1.27mm 1x14P 直插
FTS-114-02-L-S 数据手册
MICRO LOW PROFILE TERMINAL STRIPS (1.27 mm) .050" PITCH • FTS SERIES FTS FTS Board Mates: CLP, FLE Cable Mates: FFSD -1 - NO. PINS PER ROW 02 thru 50 (except –S & –SA option = 05 thru 46) SPECIFICATIONS LEAD STYE - PLATING OPTION –01 –F = (3.05 mm) .120" Post (Mates with FFSD) = Gold flash on post, Matte Tin on tail –02 Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Operating Temp Range: -55 °C to +125 °C Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating: 3.4 A per pin (2 pins powered) = (1.91 mm) .075" Post (Mates with FLE) –03 = (1.65 mm) .065" Post (Mates with CLP) - - ROW OPTION –D (–D & –DV only) –DV = End Shroud with Alignment Pin (05 thru 46 positions. Style -02 & -03 only) = Double Through-hole –SA = Double Vertical SMT –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –S –S = End Shroud (05 thru 46 positions. Style -02 & -03 only) = Single Through-hole –SV –P = Single Vertical SMT –04 = Pick & Place Pad (04 positions min.) = (3.81 mm) .150" Post (–D & –DV only) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: .004" (0.10 mm) max OTHER OPTION –TR = Tape & Reel (-DV only) (Required callout for positions 02 thru 04) 1RRISRVLWLRQV[   –FR         = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (-DV only) ALSO AVAILABLE Alignment pin (MOQ Required) 1RRISRVLWLRQV[      ²6$ 1RRISRVLWLRQV[      ²6 OPTIONS   —TR OPTION     (Shrouded option removed for clarity) Note: Some lengths, styles and options are non-standard, non-returnable. F-224 A –01 (3.05) .120 –02 (1.91) .075 –03 (1.65) .065 –04 (3.81) .150   $ —SA OPTION —P OPTION LEAD STYLE —S —SV $ —DV —D —S OPTION —P OPTION —S OPTION —SA OPTION samtec.com?FTS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FTS-114-02-L-S 价格&库存
很抱歉,暂时无法提供与“FTS-114-02-L-S”相匹配的价格&库存,您可以联系我们找货
