LPAM-50-01.0-L-08-2-K-TR 数据手册
LOW PROFILE
OPEN-PIN-FIELD ARRAYS
(1.27 mm) .050" PITCH
FEATURES & BENEFITS
• 4 mm, 4.5 mm, 5 mm stack heights
• Up to 400 I/Os
• 4, 6 and 8 row designs
• .050" (1.27 mm) pitch
• Dual beam contact system
LPAF
Dual Beam Contact
• Solder crimp termination for ease of processing
• Board stacking standoffs available to assist with
unmating and reduce risk for component damage on board
LPAM
Dual Blade Terminal
MAXIMUM GROUNDING & ROUTING FLEXIBILITY
(32.16) 1.266
(10.72)
.422
LPAM Series; 120 pins
(0.51 mm) .020"
Nominal Wipe
Differential Pair
Single-Ended
Power
KEY SPECIFICATIONS (LPAM/LPAF)
PITCH
TOTAL PINS
INSULATOR
MATERIAL
CONTACT
MATERIAL
PLATING
CURRENT
RATING
WORKING
VOLTAGE
LEAD-FREE
SOLDERABLE
1.27 mm x 1.27 mm
Up to 400 I/Os
Black LCP
Copper Alloy
Au or Sn over
50 µ" (1.27 µm)
Ni
2.2 A per pin
(8 adjacent pins
powered)
250 VAC
YES
F-224
samtec.com/LPArray
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(1.27 mm) .050" PITCH • LOW PROFILE OPEN-PIN-FIELD ARRAYS
SERIES
NO. PINS PER ROW
LPAM
–10, –20,
–30, –40,
Terminal
LPAF
–50
Socket
(-08 rows only)
LEAD
STYLE
–01.0
PLATING
OPTION
NO. OF
ROWS
–L
= (1.0 mm) .039"
(LPAM only)
= 10 µ"
(0.25 µm) Gold
on contact area,
Matte Tin on
solder tail
–01.5
= (1.5 mm) .060"
(LPAM only)
–04
–1
–06
–08
–03.0
–03.5
= (3.5 mm) .138"
(LPAF only)
–2
Board Mates:
LPAF
Standoffs:
JSO, SO
–TR
=Tape & Reel
–FR
=Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
No. of positions x
(1.27) .050 + (6.76) .266
LPAM
= Polyimide film
Pick & Place Pad
= Lead-Free
Solder Crimp
= 30 µ"
(0.76 µm) Gold
on contact area,
Matt Tin on
solder tail
"X"R
–K
= Tin/Lead
Alloy Solder
Crimp
–S
= (3.0 mm) .118"
(LPAF only)
-K-
SOLDER
TYPE
NO. OF
ROWS
B
A
No. of positions x
(1.27) .050 + (3.10) .122
B
–04
(8.18) .322
–06
(10.72) .422
–08
(13.26) .522
LEAD
STYLE
A
-01.0
(3.68) .145
-01.5
(4.19) .165
View complete specifications at: samtec.com?LPAM
No. of positions x
(1.27) .050 + (5.15) .203
LPAF
Board Mates:
LPAM
Standoffs:
JSO, SO
NO. OF
ROWS
B
A
No. of positions x
B
–04
(6.71) .264
–06
(9.25) .364
–08
(11.79) .464
LEAD
STYLE
A
-03.0
(2.79) .110
-03.5
(3.30) .130
MATED HEIGHTS*
LPAF LEAD STYLE
LPAM LEAD STYLE
-03.0
-03.5
–01.0
(4.00) .157
(4.50) .177
–01.5
(4.50) .177
(5.00) .197
*Processing conditions will affect mated height.
Notes:
Some sizes, styles and
options are non-standard,
non-returnable
View complete specifications at: samtec.com?LPAF
samtec.com/LPArray
F-224
LPAM-50-01.0-L-08-2-K-TR 价格&库存
很抱歉,暂时无法提供与“LPAM-50-01.0-L-08-2-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+305.64570
- 10+289.27180
- 国内价格
- 1+287.28000
- 30+275.94000
- 国内价格 香港价格
- 300+209.44940300+27.14863
- 600+160.85055600+20.84930
- 国内价格 香港价格
- 1+236.090091+30.60177
- 10+200.6611410+26.00951
- 25+188.0917525+24.38027
- 50+181.9417550+23.58312
