LSEM-030-04.0-L-DV-A 数据手册
FINE PITCH
SELF MATING CONNECTORS
(0.50 mm) .0197" PITCH
FEATURES & BENEFITS
• Ten stack height options from 5.00 mm to 12.00 mm
• 0.50 mm, 0.635 mm or 0.80 mm pitches
• Audible click when mated
• Mating and unmating forces approximately
4-6x greater than typical micro pitch connectors
• Self-mating system reduces inventory cost
• Parallel, perpendicular and coplanar systems
• Shielded and lubricated options
• Severe Environment Testing qualified
(LSHM); aligns with MIL-DTL-55302.
Visit samtec.com/set
SLIM BODY DESIGNS
(40 total positions each)
5.00
4.60
14.70
17.45
20.40
5.00
LSHM
LSS
LSEM
LSHM
8 mm STACK HEIGHT
LSHM
12 mm STACK HEIGHT
LSHM
5 mm STACK HEIGHT
KEY SPECIFICATIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
SMT
COPLANARITY
LEAD-FREE
SOLDERABLE
Black LCP
Phosophor
Bronze
Au or Sn over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
LSHM: 2.0 A per pin
LSS: 1.7 A per pin
LSEM: 1.8 A per pin
(0.10 mm) .004" max
Yes
F-224
samtec.com/RazorBeam
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
25
G b p s
(0.635 mm) .025" PITCH • RUGGED HERMAPHRODITIC CONNECTORS
LSS
1
NO. PINS PER ROW
LEAD
STYLE
10, 20, 30, 40, 50
PLATING
OPTION
DV
A
OPTION
–F
Specify
LEAD
STYLE
from
chart
–K
= Gold flash
on contact,
Matte Tin on tail
= (3.50 mm) .138" DIA
Polyimide film
Pick & Place Pad
–L
–TR
=10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Tape & Reel
–FR
= Full Reel Tape & Reel
(must order maximum
quantity per reel; contact
Samtec for quantity breaks)
1RRISRVLWLRQV[
LEAD STYLE
A
B
–01
(4.45) .1752
(1.59) .0628
–02
(7.45) .2933
(4.59) .1808
–03
(5.45) .2146
(2.59) .1021
LEAD
STYLE
MATED
HEIGHT *
–01 & –01
(6.00) .236
–03 & –03
(8.00) .315
–01 & –03
–01 & –02
–02 & –03
–02 & –02
(7.00) .276
(9.00) .354
(10.00) .394
(12.00) .472
*Processing conditions will
affect mated height.
View complete specifications at: samtec.com?LSS
(0.80 mm) .0315" PITCH • RUGGED HERMAPHRODITIC CONNECTORS
LSEM
NO. PINS
PER ROW
1
20, 30, 40, 50
LEAD
STYLE
PLATING
OPTION
–F
Specify
LEAD
STYLE
from
chart
= Gold flash
on contact,
Matte Tin on tail
–L
=10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
LEAD
STYLE
A
B
–01
N/A
NA
–03.0
(4.45)
.175
(1.50)
.059
–04.0
(5.45)
.215
(2.50)
.098
–06.0
(7.45)
.293
(4.50)
.177
(–DH only)
No. of positions x
(0.80) .0315 + (4.40) .173
TAIL
OPTION
A
N
–DV
–DH
No. of positions x
B
–DV
View complete specifications at: samtec.com?LSEM
A
“X”R
–TR
= Tape &
Reel
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity
per reel;
contact
Samtec for
quantity
breaks)
LEAD STYLE
MATED
HEIGHT *
–03.0 & –03.0
(6.00) .236
–04.0 & –04.0
(8.00) .315
–03.0 & –04.0
(4.98)
.196
–DH
K
= (3.50 mm)
.138" DIA
Polyimide
film Pick &
Place Pad
= Right-angle
(Lead style
–01 only)
(5.13)
.202
–K
= Vertical
(7.80) .307
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–03.0 & –06.0
–04.0 & –06.0
–06.0 & –06.0
(7.00) .276
(9.00) .354
(10.00) .394
(12.00) .472
F-224
LSEM-030-04.0-L-DV-A 价格&库存
很抱歉,暂时无法提供与“LSEM-030-04.0-L-DV-A”相匹配的价格&库存,您可以联系我们找货
