MMSDT-25-24-L-36.00-S-K 数据手册
(2.54 mm) .100" PITCH • DISCRETE WIRE CABLE & COMPONENTS
SERIES
MMSD
= Double Row PVC Cable
MMSDT
= Double Row Blue *Teflon
Fluoropolymer Cable
(20, 24, 28, 30 AWG only)
MMSS
= Single Row PVC Cable
MMSST
PINS PER
ROW
–02, –03,
–04, –05,
–06, –08,
–10, –12,
–15, –16,
–20, –25
WIRE
GAUGE
= Color
Coded Cable
(MMSD &
MMSS only)
–22, –24
= Color
Coded Cable
(MMSD &
MMSS only)
= Single Row Blue *Teflon
Fluoropolymer Cable
(20, 24, 28, 30 AWG)
–26, –28
MMSD, MMSDT,
MMSS, MMSST
–28C
= Color
Coded Cable
(MMSD &
MMSS only)
Board Mates:
IPL1
(Does not mate with IPT1)
Cable Mates:
MMTD(T), MMTS(T)
–30
SPECIFICATIONS
PIN
COLOR
1
2
3
4
5
6
7
8
9
10
ETC
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GRAY
WHITE
BLACK
REPEAT
No. of positions
x (2.54) .100
*Teflon™ is a trademark
of The
+ (1.40)
.055
Chemours Company
FC,
LLC
used under license by Samtec.
Insulator Material:
Nylon 66
Contact Material:
Phosphor Bronze
Plating: Au or Sn over
50 µ" (1.27 µm) Ni
Voltage Rating: 300 VAC
= Assembly
Length in
Inches
(82.55 mm)
03.25" min.
–20C, –24C, –28C
CABLE COLOR CODING
–24C
ASSEMBLY
LENGTH
–“XX.XX”
= 10 µ"
(0.25 µm)
Gold on
contact,
Tin on tail
–20C
–L
–20
(Standard sizes)
PLATING
OPTION
END
OPTION
–S
K
–K
= Single
Ended
= Keyed
Polarization
–D
(Metal latches for more
rugged environments;
–02, –05 & –10 positions only)
–M
= Single Ended, Metal Latches
(Leave blank for plastic)
= Double
Ended
(Latch
Required)
Double Ended (–D) Crossed
requires MMSD/MMSDT
–LUS
= Plastic Latch up, straight
–LDS
= Plastic Latch down, straight
–LUX
= Plastic Latch up, crossed
–LDX
Assembly
Length
± (3.18)
.125
= Plastic Latch down, crossed
Assembly
–MUS ±Length
(3.18)
= Metal Latch up, straight
.125
–MDS
= Metal Latch down, straight
No. of positions
x (2.54) .100
+ (1.40) .055
(8.97)
Teflon
Fluoropolymer cable
.353
is intended
for crimp only.
Contact Samtec for solderable
cable applications.
LATCH OPTION
–MUX
= Metal Latch up, crossed
–MDX
(8.97)
.353
= Metal Latch down, crossed
View complete specifications at: samtec.com?MMSD, samtec.com?MMSDT, samtec.com?MMSS & samtec.com?MMSST
IPD1
POSITIONS
PER ROW
–02, –03, –04,
–05, –06, –08,
–10, –12, –15,
–16, –20, –25
(Standard sizes)
ROW
OPTION
–S
= Single
Row
K
–K
= Keyed
Polarization
–D
= Double
Row
LATCH
OPTION
SERIES
–M
CC79L
= Metal Latch
(Metal for
more rugged
environments)
(–02, –05 & –10
positions only)
= Contact, Loose
CC79R
= Contact, Full Reel
(12,000 Parts per
Reel)
(Leave blank for
plastic latch)
WIRE
GAUGE
–D
- 01
–2630
PLATING
OPTION
–L
= 26 to 30 AWG
= 10 µ"
(0.25 µm)
Gold on
contact,
Tin on tail
–2024
= 20 to 24 AWG
(12.83)
.505
–S
–M
TOOLING
Hand Tool: CAT-HT-179-2030-13 (20-30 AWG)
Not:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224 (Rev 10NOV23)
Mini Applicator: CAT-MC-179-2024-XX-01 (20-24 AWG)
Mini Applicator: CAT-MC-179-2630 XX-01 (26-30 AWG)
Extraction Tool: CAT-EX-179-01
View complete specifications at: samtec.com?IPD1, samtec.com?CC79L & samtec.com?CC79R
samtec.com/MiniMate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
