GHDR-22V-S-1(F)
GHDR-22V-S-1(F)
    JST
    P=1.25mm
    CONN RCPT HSG 22POS 1.25MM
GHDR-22V-S-1(F) 数据手册
GHD CONNECTOR/TIN-PLATED PRODUCT Emboss Tape 1.25mm pitch/Disconnectable Crimp style connectors • Secure locking structure • Low insertion force • Prevention of contact deformation • Suction area for picking up Specifications ––––––––––––––––––– In order to correspond to the various highdensity PC board designing, this GHD connector is designed as 1.25mm pitch double row type connector. Provide a full lineup of 10 to 40 circuits for top and side entry types. (8 circuits is currently planned.) Its operability is very well, in spite of the small size with tin-plated. • Current rating: 1.25 A AC, DC (AWG #26) 1.0 A AC, DC (AWG #28) 0.8 A AC, DC (AWG #30) • Voltage rating: 50 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ Top entry type: 30 mΩ max. Side entry type: 50 mΩ max After environmental tests/ Top entry type: 50 mΩ max. Side entry type: 70 mΩ max • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #26 Insulation O.D./ 0.4 to 1.0 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. PC board layout and Assembly layout Side entry type 2.8 ±0.1 0.3 Circuit No.1 1.35 ±0.1 1±0.1 Circuit No.N-1 0.6 Circuit No.N 1.25 ±0.05 1.7 ±0.05 Connector outline A ±0.1 ±0.05 Circuit No.1 1.7 ±0.05 1.25 1.7 ±0.05 0.6 Circuit No.N ±0.05 Circuit No.N-1 0.3 ±0.05 7.25 ±0.1 Connector outline A ±0.1 ±0.05 1.7 ±0.05 Circuit No.2 7.55 ±0.05 Top entry type Circuit No.2 (Mating side faces to this side) (8.6) (8.05) (10.1) 1 Note: 1. The above figure is the figure viewed from the connector mounting side 2. Tolerance for the centers of pattern on PCB is ±0.05, and shall be not cumulative more than ±0.1. The dimensions above should serve as a guideline. Contact JST for details. (8.55) (8.5) (9.35) GHD CONNECTOR/TIN-PLATED PRODUCT Contact Applicable wire mm2 AWG# Model No. SGHD-002T-C0.2A SGHD-003T-C0.2A Insulation O.D. (mm) Q'ty/reel 0.05 ∼ 0.13 30∼26 0.76∼1.0 25,000 0.032∼0.08 32∼28 0.4 ∼0.8 25,000 1 Material and Finish Copper alloy, tin-plated (reflow treatment) RoHS compliance 5.8 Contact Crimping machine Crimp applicator MKS-L-10-3 SGHD-002T-C0.2A AP-K2N SGHD-003T-C0.2A   ―   MKS-L-10-3   ―   Applicator Dies Crimp applicator with dies MK/SSHL-002-02 APLMK SSHL002-02 ― ― MK/SGHD-003-02 APLMK SGHD003-02 ― ― Housing A 8.05 B 6.6 Circuit No.1 mark 1.25 A B 8.05 B Q'ty/ box 10 5.00 9.50 1,000 12 6.25 10.75 1,000 14 7.50 12.00 1,000 16 8.75 13.25 1,000 18 10.00 14.50 1,000 20 11.25 15.75 1,000 22 12.50 17.00 1,000 24 13.75 18.25 1,000 26 15.00 19.50 1,000 28 16.25 20.75 1,000 30 17.50 22.00 1,000 32 18.75 23.25 1,000 34 20.00 24.50 1,000 36 21.25 25.75 1,000 38 22.50 27.00 1,000 40 23.75 28.25 1,000 6.6 Circuit No.1 mark 1.25 A RoHS compliance Note: 8 circuits is currently planned. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. GHDR-20V-S-1 (F)S…natural (white) K…black E…blue TR…tomato red 2 GHD CONNECTOR/TIN-PLATED PRODUCT Header Top entry type Circuits Model No. 10 BM10B-GHDS-TF BM12B-GHDS-TF BM14B-GHDS-TF BM16B-GHDS-TF BM18B-GHDS-TF BM20B-GHDS-TF BM22B-GHDS-TF BM24B-GHDS-TF BM26B-GHDS-TF BM28B-GHDS-TF BM30B-GHDS-TF BM32B-GHDS-TF BM34B-GHDS-TF BM36B-GHDS-TF BM38B-GHDS-TF BM40B-GHDS-TF 12 B 6.8 0.55 14 Circuit No.1 mark 16 18 5 20 22 24 6.85 1.25 26 A 28 30 32 B 6.8 0.55 34 36 Circuit No.1 mark 38 Q'ty/ reel 5.00 9.50 1,250 6.25 10.75 1,250 7.50 12.00 1,250 8.75 13.25 1,250 10.00 14.50 1,250 11.25 15.75 1,250 12.50 17.00 1,250 13.75 18.25 1,250 15.00 19.50 1,250 16.25 20.75 1,250 17.50 22.00 1,250 18.75 23.25 1,250 20.00 24.50 1,250 21.25 25.75 1,250 22.50 27.00 1,250 23.75 28.25 1,250 5 40 Dimensions (mm) A B Material Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PA 9T, UL94V-0, natural (ivory) Reinoforcement: Brass, copper-undercoated, tin-plated (reflow treatment) 6.85 1.25 A RoHS compliance This product displays (LF)(SN) on a label. Note: 8 circuits is currently planned. 6.8 B 0.55 Circuit No.1 mark As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. BM20B-GHDS-TFS…natural (ivory) K…black E…blue TR…tomato red 5 ex. 6.85 1.25 A Circuits Model No. Side entry type 10 12 SM10B-GHDS-A-TF SM12B-GHDS-A-TF SM14B-GHDS-A-TF SM16B-GHDS-A-TF SM18B-GHDS-A-TF SM20B-GHDS-A-TF SM22B-GHDS-A-TF SM24B-GHDS-A-TF SM26B-GHDS-A-TF SM28B-GHDS-A-TF SM30B-GHDS-A-TF SM32B-GHDS-A-TF SM34B-GHDS-A-TF SM36B-GHDS-A-TF SM38B-GHDS-A-TF SM40B-GHDS-A-TF 14 B 0.25 5.85 0.75 16 18 Circuit No.1 mark 20 22 6.1 24 26 28 30 1.25 32 A 34 36 38 B 0.25 5.85 0.75 40 Dimensions (mm) A B 5.00 9.50 900 6.25 10.75 900 7.50 12.00 900 8.75 13.25 900 10.00 14.50 900 11.25 15.75 900 12.50 17.00 900 13.75 18.25 900 15.00 19.50 900 16.25 20.75 900 17.50 22.00 900 18.75 23.25 900 20.00 24.50 900 21.25 25.75 900 22.50 27.00 900 23.75 28.25 900 Material and Finish Circuit No.1 mark 6.1 Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: PA 9T, UL94V-0, natural (ivory) 1.25 A RoHS compliance This product displays (LF)(SN) on a label. Note: 8 circuits is currently planned. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 3 Q'ty/ reel SM20B-GHDS-A-TFS…natural (ivory) K…black E…blue TR…tomato red
GHDR-22V-S-1(F) 价格&库存
很抱歉,暂时无法提供与“GHDR-22V-S-1(F)”相匹配的价格&库存,您可以联系我们找货
GHDR-22V-S-1(F)
    • 1+4.06080
    • 10+3.30480
    • 30+2.92680
    库存:27
    GHDR-22V-S-1(F)
      • 1+2.265421+0.29267
      • 10+2.1517110+0.27798
      • 50+1.6181650+0.20905
      • 100+1.25954100+0.16272
      • 500+1.18957500+0.15368
      • 1000+1.137091000+0.14690
      • 2000+1.110852000+0.14351
      库存:105
      GHDR-22V-S-1(F)
        • 1+1.703441+0.22007
        • 100+1.56218100+0.20182
        • 300+1.21318300+0.15674
        • 500+1.14671500+0.14815
        • 1000+1.096851000+0.14171
        • 4000+1.055304000+0.13634
        • 5000+1.055305000+0.13634
        库存:943
        GHDR-22V-S-1(F)
          • 1+2.274171+0.29380
          库存:995
