SEM-145-02-03.0-H-D-A
    SAMTEC(申泰)
    .8MM TIGER EYE MICRO SOCKET
SEM-145-02-03.0-H-D-A 数据手册
RUGGED TIGER EYE™ SYSTEMS (0.80 mm) .0315" PITCH FEATURES & BENEFITS MAX 2.9 • High-reliability, multi-finger BeCu contact A m p s 8 G b p s • Micro pitch and slim body for space savings • 6 mm, 7 mm and 10 mm stack heights • Locking clip, alignment pins and weld tab ruggedizing features • Rugged latching system for increased withdrawal force • Vertical and right-angle mating headers • Discrete wire assembly available with 32 AWG *Teflon™ Fluoropolymer (See page 241). Contact asp@samtec.com for custom solutions. • Extended Life Product™ testing available Locking for increased unmating force (Visit samtec.com?SEML for more information) *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. Components (ISDE/CC396) and tooling available: samtec.com/tooling KEY SPECIFICATIONS (SEM/TEM) STACK INSULATOR HEIGHTS MATERIAL CONTACT MATERIAL BeCu (SEM) 6 - 10 mm F-224 Black LCP Phosphor Bronze (TEM) PLATING OPERATING TEMP RANGE CURRENT RATING Au or Sn over 50 µ" (1.27 µm) Ni -55 °C to +125 °C 2.9 A per pin (2 pins powered) MAX. CYCLES VOLTAGE RATING 100 with 10 µ" 235 VAC/330 VDC (0.25 µm) Au LEAD-FREE SOLDERABLE Yes samtec.com/080mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (0.80 mm) .0315" PITCH • MICRO TIGER EYE™ SOCKET AND HEADER SERIES - SEM Socket SEMS Slim Socket TEM 1 NO. PINS PER ROW - 02 - 05, 10, 15, 20, 25 –03.0 (SEM, SEMS, TEM, TEMS only) (SEM/TEM only) (Standard sizes) TEMS Leave blank for SEMS/TEMS –A –G = 7 mm Stack Height (TEM/TEMS only) = 10 µ" (0.25 µm) Gold on contact, Gold Flash on tail = Alignment Pin (Not available with –LC or –WT) –H = Locking Clip (Not available with –A or –WT) (Manual placement required) –LC = 30 µ" (0.76 µm) Gold on contact, Gold Flash on tail –07.0 = 10 mm Stack Height (TEM/TEMS only) - OPTIONS = Gold Flash –04.0 Slim Header -D- PLATING OPTION –FG = 6 mm Stack Height (–03.0 required for SEM/SEMS Series) 30, 35, 40, 45, 50 Header - STACK HEIGHT –WT = Weld Tab (Not available with –A or –LC) SEM Board Mates: TEM OTHER OPTIONS –K = (3.50 mm) .138" DIA Polyimide film Pick & Place Pad (Required for SEMS) = (5.50 mm) .217" DIA Polyimide film Pick & Place Pad (Required for TEMS) –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (No. of Positions x (0.80) .0315) + (1.60) .063 (No. of Positions x (0.80) .0315) + (4.50) .177 (3.20) .126 SEMS SEMS Board Mates: TEMS (4.50) .177 (3.75) .148 SEM View complete specifications at: samtec.com?SEM & samtec.com?SEMS TEM Board Mates: SEM, SEML TEMS Board Mates: SEMS (No. of Positions x (0.80) .0315) + (3.35) .132 A (No. of Positions x (0.80) .0315) + (9.00) .354 (5.00) .197 (5.50) .217 TEMS TEM MATED HEIGHTS STACK HEIGHT A MATED HEIGHT* –03.0 (5.610) .2209 6 mm –04.0 (6.610) .2602 7 mm –07.0 (9.610) .3783 10 mm SEM MATED HEIGHT TEM *Processing conditions will affect mated height. Note: Some lengths, styles and options are non-standard, non-returnable. View complete specifications at: samtec.com?TEM & samtec.com?TEMS samtec.com/080mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
SEM-145-02-03.0-H-D-A 价格&库存
很抱歉,暂时无法提供与“SEM-145-02-03.0-H-D-A”相匹配的价格&库存,您可以联系我们找货
  • 68+173.0398468+22.35507
