FECONNECTOR
0.3mmピッチ
NON-
1.25 mm pitch/Connectors for FFC
FE CONNECTOR
Specifications
• Current rating: 1.0 A AC/DC
• Voltage rating: 200 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 20 mΩ max.
After environmental tests/ 30 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 500 VAC/minute
• Applicable FFC: Conductor pitch/ 1.25 mm
Conductor width/ 0.8 mm
Mating part thickness/ 0.30 ± 0.05 mm
The FE connector ensures easy, secure
connection of flexible flat cables (FFC).
This compact connector is 4.8 mm wide,
7.5 mm high, and provides high contact
pressure even though little force is required
for insertion. The result is smooth insertion
and reliable contact performance.
The connector is useful in making personal
computers, VCRs and car stereo systems
smaller and lighter.
●L
ow insertion force and high contact
pressure
● Snap-in connection
● Temporary board retention feature
Note: FFC to be actually used should be checked for applicability.
• Applicable PC board thickness: 1.2 to 1.6 mm
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
Standards
Recognized E60389
Certified LR20812
PC board layout and Assembly layout
Top entry type
Side entry type
Contact side
1.25±0.05
+0.1
φ0.8 0
7.5
Contact side
Circuit No.1
2.5±0.05
4.8
7.5
φ0.8 +0.1
2.5±0.05
1.25±0.05
2.5±0.05
4.8
Circuit No.1
2.5±0.05
1.175
6.5
Note: 1. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method.
The dimensions above should serve as a guideline. Contact JST for details.
1
FE CONNECTOR
Connector
Model No.
No. of
circuits Top entry type
Side entry type
4
04FE-BT-VK-N 04FE-ST-VK-N
5
05FE-BT-VK-N 05FE-ST-VK-N
6
06FE-BT-VK-N 06FE-ST-VK-N
7
07FE-BT-VK-N 07FE-ST-VK-N
8
08FE-BT-VK-N 08FE-ST-VK-N
9
09FE-BT-VK-N 09FE-ST-VK-N
10
10FE-BT-VK-N 10FE-ST-VK-N
11
11FE-BT-VK-N 11FE-ST-VK-N
12
12FE-BT-VK-N 12FE-ST-VK-N
13
13FE-BT-VK-N 13FE-ST-VK-N
14
14FE-BT-VK-N 14FE-ST-VK-N
15
15FE-BT-VK-N 15FE-ST-VK-N
16
16FE-BT-VK-N 16FE-ST-VK-N
17
17FE-BT-VK-N 17FE-ST-VK-N
18
18FE-BT-VK-N 18FE-ST-VK-N
19
19FE-BT-VK-N 19FE-ST-VK-N
20FE-BT-VK-N 20FE-ST-VK-N
21
21FE-BT-VK-N 21FE-ST-VK-N
22
22FE-BT-VK-N 22FE-ST-VK-N
23
23FE-BT-VK-N 23FE-ST-VK-N
24
24FE-BT-VK-N 24FE-ST-VK-N
25
25FE-BT-VK-N 25FE-ST-VK-N
26
26FE-BT-VK-N 26FE-ST-VK-N
27
27FE-BT-VK-N 27FE-ST-VK-N
28
28FE-BT-VK-N 28FE-ST-VK-N
29
29FE-BT-VK-N 29FE-ST-VK-N
30
30FE-BT-VK-N 30FE-ST-VK-N
31
31FE-BT-VK-N 31FE-ST-VK-N
32
32FE-BT-VK-N 32FE-ST-VK-N
33
33FE-BT-VK-N 33FE-ST-VK-N
34
34FE-BT-VK-N 34FE-ST-VK-N
35
35FE-BT-VK-N 35FE-ST-VK-N
36
36FE-BT-VK-N 36FE-ST-VK-N
37
37FE-BT-VK-N 37FE-ST-VK-N
38
38FE-BT-VK-N 38FE-ST-VK-N
39
39FE-BT-VK-N 39FE-ST-VK-N
40
40FE-BT-VK-N 40FE-ST-VK-N
Top entry type
7.5
1.125
3.5
2.5
4.8
4.0
1.25
B
C
A
1.5
Circuit No.1
Circuit No.1
Side entry type
9.1
7.5
4.8
4.0
1.25
B
C
A
Circuit No.1
3.1
1.5
2.5
Circuit No.1
Dimensions (mm)
A
B
C
3.75
8.55
6.35
2,350
1,410
5.00
9.80
7.60
2,000
1,200
6.25
11.05
8.85
1,800
1,080
7.50
12.30
10.10
1,600
960
8.75
13.55
11.35
1,500
900
10.00
14.80
12.60
1,350
810
11.25
16.05
13.85
1,250
750
12.50
17.30
15.10
1,150
690
13.75
18.55
16.35
1,100
660
15.00
19.80
17.60
1,000
600
16.25
21.05
18.85
950
570
17.50
22.30
20.10
900
540
18.75
23.55
21.35
850
510
20.00
24.80
22.60
800
480
21.25
26.05
23.85
750
450
22.50
27.30
25.10
700
420
23.75
28.55
26.35
700
420
25.00
29.80
27.60
650
390
26.25
31.05
28.85
650
390
27.50
32.30
30.10
600
360
28.75
33.55
31.35
600
360
30.00
34.80
32.60
550
330
31.25
36.05
33.85
550
330
32.50
37.30
35.10
500
300
33.75
38.55
36.35
500
300
35.00
39.80
37.60
500
300
36.25
41.05
38.85
450
270
37.50
42.30
40.10
450
270
38.75
43.55
41.35
450
270
40.00
44.80
42.60
450
270
41.25
46.05
43.85
400
240
42.50
47.30
45.10
400
240
43.75
48.55
46.35
400
240
45.00
49.80
47.60
400
240
46.25
51.05
48.85
350
210
47.50
52.30
50.10
350
210
48.75
53.55
51.35
350
210
Material and Finish
Contact: Copper alloy, tin-plated (reflow treatment)
Housing: PBT, UL94V-0, white
RoHS2 compliance
Lead section dimensions of FFC
+0.05
1.25×(N+1) -0.2
±0.15
1.25×(N-1)
0.8
±0.1
1.25 ±0.2
0.30 ±0.05
5.0min.
1.25
±0.1
Conductor
Insulator
Note: N --- Number of circuits
2
(7.0)
1.25
±0.2
Reinforcing layer
Insulator
Q'ty/box
Top entry Side entry
type
type
很抱歉,暂时无法提供与“04FE-BT-VK-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.679121+0.08803
- 300+0.58802300+0.07622
- 500+0.52177500+0.06763
- 1000+0.472081000+0.06119
- 4000+0.430674000+0.05583
- 5000+0.430675000+0.05583
- 10000+0.4223810000+0.05475
- 国内价格
- 10+0.47240
- 100+0.37790
- 300+0.33059
- 2350+0.29517
- 国内价格 香港价格
- 1+0.915381+0.11865
- 10+0.6189710+0.08023
- 50+0.5405150+0.07006
- 100+0.48820100+0.06328
- 500+0.46205500+0.05989
- 1000+0.453331000+0.05876
- 2000+0.444612000+0.05763
- 国内价格 香港价格
- 1+0.714871+0.09266
- 300+0.61897300+0.08023
- 500+0.54923500+0.07119
- 1000+0.496921000+0.06441
- 4000+0.453334000+0.05876
- 5000+0.453335000+0.05876
