08FDZ-BT
08FDZ-BT
    JST
    插件,P=2.54mm
    08FDZ-BT
08FDZ-BT 数据手册
FDZ CONNECTOR 2.54mm pitch/Connectors for FPC and membrane switch leads Specifications ––––––––––––––––––– • Current rating: The FDZ connector, a Zero Insertion Force (ZIF) connector, was developed to connect FPC and membrane switch leads. This combination of features allows greater freedom in internal wiring designs. No force is required to insert the leads. Once inserted, the leads are securely held and locked by moving the slide. The contact is double-sided to ensure greater reliability. • Double-sided contact • Zero insertion force and locking mechanism • Temporary board retention feature • Boss for polarity identification • Flux is not a problem Tin-plated copper foil lead/1.0A AC, DC Silver paste carbon-printed lead/50mA AC, DC • Voltage rating: 250V AC, DC • Temperature range: -40˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: lnitial value/30m Ω max. After environmental testing/50m Ω max. lnitial value/10 Ω max. After environmental testing/15 Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,200V AC/minute • Applicable FPC and membrane switch lead: Conductor pitch/2.54mm Conductor width/1.3mm Mating part thickness/125 micron • Applicable PC board thickness: 1.6mm Note: FPC to be actually used should be checked for applicability. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout (viewed from soldering side) and Assembly layout Top entry type Side entry type 7.7 5.3 min 2.54 5.3 min 10.2 7.7 10.2 8.2 2.54 ±0.05 5.1 min 2.54 ±0.05 φ1.8 ±0.05 φ0.9 ±0.05 5.1 φ0.9 ±0.05 8.2 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 FDZ CONNECTOR Connector Top entry type (Before slide lock) Circuits 5 6 B 7.7 8 Hook 9 10 12.7 10.2 Boss 11 12 1.5 13 3.5 φ1.5 2.54 17 2.6 0.6 2.54 A 19 5.3 Model No. Top entry type Side entry type 05FDZ-BT(S) 05FDZ-ST(S) 06FDZ-BT(S) 06FDZ-ST(S) 08FDZ-BT(S) 08FDZ-ST(S) 09FDZ-BT(S) 09FDZ-ST(S) 10FDZ-BT(S) 10FDZ-ST(S) 11FDZ-BT(S) 11FDZ-ST(S) 12FDZ-BT(S) 12FDZ-ST(S) 13FDZ-BT(S) 13FDZ-ST(S) 17FDZ-BT(S) 17FDZ-ST(S) 19FDZ-BT(S) ー 7.7 1.5 2.0 10.2 3.1 2.54 2.6 5.3 Lead section dimensions of FPC (N+1)×2.54 (N−1)×2.54 2.54 1.3 2.54 125μm (75∼200μm) 3.81 1.2 3.0 5.0 2.54 2 100 12.70 26.10 100 17.78 31.18 100 20.32 33.72 100 22.86 36.26 100 25.40 38.80 50 27.94 41.34 50 30.48 43.88 50 40.64 54.04 50 45.72 59.12 50 RoHS compliance This product displays (LF)(SN) on a label. Note: 19FDZ-BT(S) is not UL/CSA approved. φ1.5 Note: N --- Number of circuits 23.56 Material and Finish B A Q'ty / box 10.16 Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Housing: Glass-filled PBT, UL94V-0 Side entry type (After slide lock) 2.54 Dimensions (mm) A B
08FDZ-BT 价格&库存
很抱歉,暂时无法提供与“08FDZ-BT”相匹配的价格&库存,您可以联系我们找货
08FDZ-BT
    • 1000+2.17330
    库存:1222
    08FDZ-BT
      • 100+2.02270
      库存:100
      08FDZ-BT
      • 1+6.082051+0.78835
      • 10+5.1617610+0.66907
      库存:22
