09340062601
09340062601
    HARTING(浩亭)
    INSERT MALE 6+2POS+1GND SCREW
09340062601 数据手册
Han® 6 Hv E/ES Size 16 B 830 V 16 A Number of contacts 6 + + 2 additional contacts for safe high voltage connections Han Hv E Identification Series Cage-clamp terminal Han® Hv ES 1-6 Part number Male insert (M) Female insert (F) 09 34 006 2616 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 006 2716 Cage clamp terminal Screw terminal Crimp terminal 1) Han Hv E® 1-6 Crimp terminal Order crimp contacts separately (see page 04.16) 04 . 06 a 18,4 18,5 18,5 b 33,4 32,4 34,2 c 18,4 18 18 d 35,6 34,6 37 Distance for contact max. 21 mm Contact arrangement (view from termination side) Han® 6 Hv ES 09 34 006 2601 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 006 2701 " Han® 6 Hv E Han Hv E® 1-6 Dimensions in mm " not plug compatible to screw/crimp terminal Screw terminal Drawing 09 34 006 2602 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 006 2702 " ● Working contact ◐ Relay contact ○ Without contact Panel cut out for inserts for use without hoods/ housings Crimp terminal and cage clamp terminal could also be used with 16 B standard hood/housing Stock items in bold type
09340062601 价格&库存
很抱歉,暂时无法提供与“09340062601”相匹配的价格&库存,您可以联系我们找货
  • 1+303.710971+39.20309
  • 1+267.529711+34.53280
  • 10+237.5026510+30.65690
  • 25+220.2567925+28.43080
  • 50+212.5530650+27.43640
  • 100+204.32407100+26.37420
  • 250+194.60686250+25.11990
库存:2
09340062601
    • 1+156.53039
    • 100+148.70960
    • 500+145.73124
    库存:7
