Ha-VIS mCon 3000 Next Generation – Introduction and features
Ethernet Switch
Ethernet Switches, managed, for mounting onto top-hat mounting rail in control cabinets
General Description
Features
The fully Managed Ethernet Switches of the product
family Ha-VIS mCon 3000 enable the connection of
up to 10 network devices (according to type) over
RJ45 ports or SFP modules on lowest area.
• Full managed Ethernet Switch acc. to IEEE 802.3
• Up to 10 ports, managed, non-blocking
Degree of protection, mechanical stability and the
comprehensive management software provide for
high operation safety and meet highest demands.
• Store and Forward Switching Mode
The Ha-VIS mCon 3000 Ethernet Switches are
designed for an effective, industrial and individual use.
• Gigabit Uplink ports, RJ45 and SFP modules
The configuraton via SD card or via the Multifunction
button enables an easy and fast commisioning in the
field.
• Auto-crossing, Auto-negotiation, Auto-polarity
The Ethernet Switches of the Ha-VIS mCon 3000
Next Generation family can be used as PROFINET IO
devices.
• Temperature range -40 °C ... +70 °C
• PROFINET IO device
• Multifunction button for fast commsioning
• SD card slot for storage of the configuration
• Management functions see page 9
Advantages
Application fields
• Small, robust metal housing
• Industrial automation
mCon 3000
Comprehensive possibilities of configuration and
diagnostic are provided easy via web interface or
standardized via SNMP.
• External SD card for storage of the configuration
• Individual pre-configuration via Multifunction button
• Automotive industry
• Fast removable Ethernet data links via SFP
„Hot-Swap“
• Wind power, Solar Power
• Optimised DIN rail fitting
• EMC, temperature range and mechanical stability
meet the highest demands
• Maritime
A·4
11
Technical characteristics
Ethernet interface RJ45
Number of ports
Ha-VIS mCon 3080-A
Ha-VIS mCon 3102-AASFP
8x 10/100Base-T(X)
8x 10/100Base-T(X)
2x 10/100/1000Base-T(X) (Combo ports with SFP slot)
Cable types according
to IEEE 802.3
Shielded Twisted Pair (STP) or Unshielded Twisted Pair (UTP),
Category 5
Data rate
10 Mbit/s, 100 Mbit/s or 1000 Mbit/s (RJ45)
Maximum cable length
100 m (Twisted Pair; with Category 5 cable acc. to DIN EN 50 173-1)
Termination
RJ45 (Twisted Pair)
Diagnostics (via LED)
• Status Link – Green
• Data transfer (Act) – Green flashing
• Data transfer rate (Speed) – 1000 Mbit/s: Green
100 Mbit/s: Yellow
10 Mbit/s: OFF
Topology
Ring, Line, Star or mixed
mCon 3000
Ethernet Interface SFP (mini-GBIC) Fibre Optic and copper
Number of ports
2x 100/1000Base (Combo ports with SFP slot)
Data rate
100 Mbit/s, 1000 Mbit/s
Termination
SFP modules according to MSA (Multi Source Agreement)
(see catalogue „HARTING Smart Network Infrastructure - Intelligent
Network Solutions“)
Diagnostics
Digital Diagnostics Monitoring (DDM) according to SFF-8472
(available with software release 2.4 or higher)
Power supply
Nominal input voltage
24 V
Termination
5-pole screw terminal, pluggable
for redundant power supply
Switch
Devive operates without failures – Green
Power supply in the admissible range – Green
Low voltage – Red
Diagnostics failure – Red
PROFINET failure / diagnosis – Red/Green flashing
Configuration
A·4
12
Slot for SD cards (back side)
• Saving and loading of configuration files
• Licence management for MRP
Individual pre-configuration of software functions
Design features
Housing material
Aluminium, anodized
Dimensions (W x H x D)
44 x 130 x 100 mm (without connectors)
acc. to DIN 60 529
IP 30
Mounting
• 35 mm top-hat rail acc. to EN 60 715
• Panel mounting, vertical assembly
Environmental conditions
Storage temperature
–40 °C … +85 °C
Relative humidity
10 % … 95 % (non-condensing)
Management software
Full managed via web interface and SNMP
Range of functions and detailed description see page 6
Shock
IEC 60 068-2-27
• 15 g
• 11 ms duration
• Shock form: Half sine-wave
Vibration
EN 60 068-2-6
Rail-standard
EN 50 155, Class 1
EMC Interference immunity (EN 61 000-6-2, EN 50 121-3-2)
Industrial
Railway
Maritime
Electrostatic discharge (ESD)
EN 61 000-4-2
Criterion B
Criterion B
Criterion B
Electromagnetic field
EN 61 000-4-3
Criterion A
Criterion A
Criterion A
Fast transients (Burst)
EN 61 000-4-4
Criterion B
Criterion A
Criterion B
Impulse voltages (Surge)
EN 61 000-4-5
Criterion B
Criterion B
Criterion B
Conducted emissions
EN 61 000-4-6
Criterion A
Criterion A
Criterion A
Rail applications
EN 50 121-3-2
mCon 3000
Mechanical solidness
EMC interference (EN 61 000-6-4, EN 55 022, EN 50 121-3-2)
Scope of delivery
• Ethernet Switch
• User manual
• Assembly manual
• CD
• Terminal block
A·4
13
Ha-VIS mCon 3080-A
Ethernet Switch
Ha-VIS mCon 3080-A
8-port Ethernet Switch, full managed
Managed
IP 30
PROFINET compatible
X
EtherNet/IP compatible
X
mCon 3000
Number of ports, Copper / Termination 8x 10/100Base-T(X) / RJ45 (Twisted Pair)
Nominal input voltage range
24 V
Permissible range (min/max)
9.6 V … 60 V
Termination
5-pole screw terminal, pluggable redundant power supply
Input current
approx. 130 mA (at 24 V
Housing material
Aluminium, anodized
Weight
approx. 0.450 kg
Operating temperature
–40 °C … +70 °C
MTBF
678.372 h
Approvals (in preparation)
UL 508 (Safety); UL 60 950-1 (Safety); DNV
Management
fully Managed via Web interface and SNMP
Functions see page 9
Identification
Part number
Ha-VIS mCon 3080-A
8 RJ45 ports
including
Set for assembly on standard rail
20 76 108 4000
A·4
14
Drawing
Dimensions in mm
Ethernet Switch
10-port Ethernet Switch with 2 ports Gigabit Ethernet, full managed
Managed
PROFINET compatible
IP 30
X
X
2x 10/100/1000Base-T(X) / RJ45 (Twisted Pair)
Number of slots SFP / Termination 2x 100/1000Base / Combo ports
24 V
9.6 V … 60 V
Termination
Input current
approx. 250 mA (at 24 V
Housing material
Aluminium, eloxiert
44 x 130 x 100 mm (incl. cap, without connectors)
Weight
approx. 0.485 kg
–40 °C … +70 °C
MTBF
597.974 h
Management
Part number
Drawing
Dimensions in mm
mCon 3000
Identification
8 ports Fast Ethernet RJ45
(combo SFP)
including
20 76 112 4300
A·4
15
很抱歉,暂时无法提供与“20761084000”相匹配的价格&库存,您可以联系我们找货
