20820000003
20820000003
    HARTING(浩亭)
    PRELINKTERMMOD26-27AWG1=10
20820000003 数据手册
RJ45 IP20 connectors preLink ® RJ45 jacks (HIFF) Advantages Technical characteristics • Compact and robust design Connector type • C  ategory of transmission Cat. 6 • S  uitable for solid and stranded wires • Compatible with HIFF dimensions for use in: – Han ® 3 A series with HIFF adapter 09 45 515 0024 Connecting hardware –H  ARTING PushPull (V4) Compact bulkhead mounting housing 09 45 545 0028 EasyInstall bulkhead mounting housing 09 45 545 0032 – Han ® PushPull (V14) Panel feed-through plastic 09 35 012 0331 Panel feed-through metal rectangular 09 35 012 0311 Panel feed-through metal circular 09 35 012 0312 – har-port 09 45 452 0000 • Suitable for PoE (IEEE 802.3af) and PoE+ (IEEE 802.3at) Identification Part number preLink ® set RJ45 jack consists of: • 1x RJ45 module • 1x terminal module • 1x cable tie AWG 22/23 AWG 26/27 preLink ® RJ45 jack module 20 82 001 0001 20 82 001 0002 20 82 000 0002 preLink ® RJ45 terminal module AWG 22/23, yellow1) AWG 26/27, white1) preLink ® protection cover 20 82 000 9915 preLink ® unlocking tool 20 82 000 9916 03 preLink ® assembly tool 36 1) 20 82 000 0001 20 82 000 0003 Packaging with 10 pieces 20 82 000 9901  J45 connector R acc. to IEC 60 603-7 Number of contacts 8 Transmission category Category 6A , Class E A , suitable for 1/10 Gigabit Ethernet Transmission performance Category 6A / Class E A up to 500 MHz acc. to ISO / IEC 11 801:2002, EN 50 173-1 Transmission rate 10/100 Mbit/s and 1/10 Gbit/s Shielding fully shielded, 360° shielding contact Mounting IDC termination Cable termination for preLink ® terminal module, yellow, 20 82 000 0001 Connectable cables – Conductor cross section AWG 23 … AWG 22 (solid and stranded) – Conductor diameter 1.3 … 1.6 mm Cable termination for preLink ® terminal module, white, 20 82 000 0003 Connectable cables – Conductor cross section AWG 27 … AWG 26 (solid and stranded) – Conductor diameter 0.8 … 1.1 mm Cable diameter 5 … 9 mm Degree of protection IP20 Mating cycles min. 750 Temperature range –40 °C … +70 °C Housing material Zinc die-cast, nickel-plated Drawing Dimensions in mm
20820000003 价格&库存
很抱歉,暂时无法提供与“20820000003”相匹配的价格&库存,您可以联系我们找货
    • 1+172.142761+22.37436
