21031112405
21031112405
    HARTING(浩亭)
21031112405 数据手册
Adapter M8/M12 Show navigation HARAX® circular connector Technical characteristics Specifications IEC 60 352-4 IEC 60 9475-2 Approvals HARAX® M8-S/M12-S Rated voltage Rated current Conductor cross section Diameter of individual strands Conductor insulation material Conductor diameter Cable diameter Temperature limits Temperature during connection Degree of protection Reconnection with the same cable cross section 32 V 4A 0,14 mm² - 0,34 mm² AWG 26 - 22 > 0.1 mm PVC / PP M8-S: 1.0 mm - 1.6 mm M12-S: 1.0 - 1.6 mm M8-S: 3.2 - 5.4 mm M12-S: 4 mm - 5.1 mm - 25 °C ... + 85 °C - 5 °C ... + 50 °C IP 67 10 times HARAX® M12 angled Working voltage Working current Wire gauge Diameter of individual strands Conductor insulation material Conductor diameter Cable diameter Temperature limits Temperature during connection Degree of protection Reconnection with the same cable cross section 32 V 4A 0,25 mm² - 0,5 mm² AWG 24/7 - 22 > 0.1 mm PVC 1.2 mm - 1.6 mm 4 mm - 5.1 mm - 25 °C ... + 85 °C - 5 °C ... + 50 °C IP 67 10 times HARAX® M12-L Rated voltage 50 V http://www.harkis.harting.com/WebHelp/GBHanGeraete/WebHelp/HARAX/AdapterM8_M12.htm (1 of 7)14/02/2006 10:31:51 Adapter M8/M12 Rated current Conductor cross section 6A 0.34 mm² - 0.75 mm² AWG 22 - 18 > 0.1 mm PVC 1.6 mm - 2.0 mm 5.5 mm - 8 mm - 25 °C ... + 85 °C - 5 °C ... + 50 °C IP 67 Diameter of individual strands Conductor insulation material Conductor diameter Cable diameter Temperature limits Temperature during connection Degree of protection Reconnection with the same cable cross section 10 times HARAX® M12-L screened version Rated voltage Rated current Conductor cross section Diameter of individual strands Conductor cross section of Solid wire Conductor insulation material Conductor diameter Cable diameter Temperature limits Temperature during connection Degree of protection Coding Reconnection with the same cable cross section Transmission characteristics acc. to Ethernet, D-coded 32 V 4A 0.25 mm² - 0.34 mm² AWG 24-22 > 0.1 mm Result pending Profibus 32 V 4A 0.25 mm² - 0.34 mm² AWG 24-22 > 0.1 mm AWG 22/1 PVC 1.2 mm - 1.6 mm 5.5 mm - 7.2 mm - 25 °C ... + 85 °C - 5 °C ... + 50 °C IP 67 d-coding PVC 2.0 mm - 2.6 mm 7 mm - 8.8 mm - 25 °C ... + 85 °C - 5 °C ... + 50 °C IP 67 b-coding / reverse key 10 times DIN EN 50 173 10 times - Rated voltage Rated current Conductor cross section Diameter of individual strands Conductor cross section of Solid wire Conductor insulation material Conductor diameter Cable diameter Working temperature Temperature during connection Degree of protection Coding Number of terminations with same cable cross section Transmission characteristics acc. to M12-L A-coded Adapter M12-RJ45 32 V 4A 0,25 mm² - 0,34 mm² AWG 24 - 22 > 0.1 mm Works with AWG 22/1 PVC 1.6 mm - 2.0 mm 7.0 mm - 8.8 mm - 25 °C ... + 85 °C - 5 °C ... + 50 °C IP 67 a-coding - 10 - 10 DIN EN 50 173 - 25 °C ... + 85 °C - 5 °C ... + 50 °C IP 65 / 67 - http://www.harkis.harting.com/WebHelp/GBHanGeraete/WebHelp/HARAX/AdapterM8_M12.htm (2 of 7)14/02/2006 10:31:51 Adapter M8/M12 HF Properties acc. to DIN EN 50173 1= 2= 3= Limit acc. to DIN EN 50173, Category 5 Pin allocation diagonal wire pair 1/3 2/4 Pin allocation diagonal wire pair 2/4 1/3 Derating Diagramme The current carrying capacity is limited by maximum temperature of materials for insert and contacts including terminals. The current capacitycurve is valid for continuous, not interrupted current-loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60512-3. M8-S, 4 poles M12-S, 4 poles http://www.harkis.harting.com/WebHelp/GBHanGeraete/WebHelp/HARAX/AdapterM8_M12.htm (3 of 7)14/02/2006 10:31:51 Adapter M8/M12 1 = wire gauge 0,25 mm² 2 = wire gauge 0,34 mm² M12, 4 poles, angled 1 = wire gauge 0,25 mm² 2 = wire gauge 0,5 mm² http://www.harkis.harting.com/WebHelp/GBHanGeraete/WebHelp/HARAX/AdapterM8_M12.htm (4 of 7)14/02/2006 10:31:51 Adapter M8/M12 M12-L, 4 poles M12-L, shielded 1 = wire gauge 4 x 0,34 mm² 2 = wire gauge 4 x 0,75 mm² Assembly manual HARAX® 1. Strip cable 2. Assemble HARAX® elements 3. Cut off cable ends 4. Screw connector (1) Nut (2) Strain relief (3) Insert Screw the nut onto the insert until a stop is noticeable. Note! For reconnection cut off the used cable ends and repeat steps 1 to 4. http://www.harkis.harting.com/WebHelp/GBHanGeraete/WebHelp/HARAX/AdapterM8_M12.htm (5 of 7)14/02/2006 10:31:51 Adapter M8/M12 Assembly instruction for shielded HARAX® M12-L 1. Strip cable 2. Assemble HARAX® elements, twist screening braid and push it into the sealing slot 3. Slide ring over the sealing cut off cable ends and the screening braid. 4. Screw the connector (1) Nut (2) Strain relief (3) Insert Note! For reconnection cut off the used cable end and repeat steps 1 to 4. http://www.harkis.harting.com/WebHelp/GBHanGeraete/WebHelp/HARAX/AdapterM8_M12.htm (6 of 7)14/02/2006 10:31:51 Adapter M8/M12 http://www.harkis.harting.com/WebHelp/GBHanGeraete/WebHelp/HARAX/AdapterM8_M12.htm (7 of 7)14/02/2006 10:31:51
21031112405 价格&库存
很抱歉,暂时无法提供与“21031112405”相匹配的价格&库存,您可以联系我们找货
  • 1+126.595821+15.87536
  • 10+107.6143910+13.49505
  • 25+100.8732125+12.64970
  • 50+96.0598350+12.04609
  • 100+91.47509100+11.47116
  • 250+85.75240250+10.75352
  • 500+81.66353500+10.24077
  • 1000+77.770921000+9.75263
库存:95
21031112405
  • 1+97.28607
  • 10+94.34937
  • 50+91.44391
  • 100+89.25700
  • 250+87.13258
库存:47
21031112405
    • 1+66.00000
    • 10+56.10000
    • 20+55.55000
    • 40+55.27500
    库存:5000
