21350400426010
21350400426010
    HARTING(浩亭)
    M12 System Cables, A-Coding, 4 Poles
21350400426010 数据手册
M12 System Cables, A-Coding, 4 poles Female 4-pole Technical Characteristic(s) Coding Rated voltage Rated current / contact Locking type Contact nut material/plating Shielding Number of contacts Contact material/plating Mating cycles Temperature range (working and storage) Conductor insulation Number of wires / wire gauge Conductor cross-section (mm²) Conductor cross-section (AWG) Cable outer diameter (metric) Cable outer diameter (inches) Recommended torque Wrench size (knurled screw / knurled nut) Degree of protection Jacket material Jacket color Molding material Molding material color Cable Length Configuration Type Part Number PVC A-coding 250 V ‌4 A M12x1 4 poles PUR A-coding 250 V ‌4 A M12x1 TPE A-coding 250 V ‌4 A M12x1 Brass/Nickel Brass/Nickel Brass/Nickel Unshielded 4 Brass/Gold ≥100 Unshielded 4 Brass/Gold ≥100 Unshielded 4 Brass/Gold ≥100 -25 ... +80 °C -25 ... +80 °C -40 ... +80 °C PVC (bn, bk, bu, wh) PP (bn, bk, bu, wh) PP (bn, bk, bu, wh) 4 x 0.34 mm² 4 x 0.34 mm² 4 x 0.33 mm² 0.34 mm² 0.34 mm² 0.33 mm² AWG 22 AWG 22 AWG 22 4.90 mm ± 0.10 mm 4.20 mm ± 0.15 mm 5.08 mm ± 0.25 mm 0.193 in. ± 0.004 in. 0.165 in. ± 0.006 in. 0.200 in. ± 0.010 in. 0.6 Nm 0.6 Nm 0.6 Nm 15 15 15 IP65 / IP67 when mated PVC (UL 758/1581) Yellow TPU Black 1.00 m IP65 / IP67 when mated PUR (UL 758/1581) Yellow TPU Black 1.00 m IP65 / IP67 when mated TPE (UL 758) Yellow TPU Black 1.00 m Angled female to blunt cut Angled female to blunt cut Angled female to blunt cut 21350400416010 21350400406010 21350400426010
21350400426010 价格&库存
很抱歉,暂时无法提供与“21350400426010”相匹配的价格&库存,您可以联系我们找货
